Question about D-Link DIR-300 Wireless Router
I have activated the nat mode of my dlink dir-300 now i cant open the log in page by entering the ip 192.168.0.1
    President:
  • 2,187 Answers
Check the IP of your computer by going to dos: Run -> CMS -> then type IPCONFIG. If your IP address is not in the 192.168.0.X range then you will not be able to access it. You may have the IP assigned by the ISP or you may have to renew the ip address by restarting your computer. You can use another computer see if gets the 192... range or assign an IP belonging to that range manually.
Posted on Jul 30, 2009
Log in
Open your web browser and type in the IP address of the router (192.168.0.1 by default)
The default user id is: admin and the password is left blank. Once you get into the router go to the wireless setup or tab.
Below is a pdf manual of your router.
ftp://files.dlink.com.au/products/DIR-300/QuickInstallGuide/DIR-300_A1_QIG_v2.00.pdf
Jun 02, 2012 | D-Link DIR-300 Wireless Router
How to connect TP LINK TL-WA901ND with Dlink DIR 615
Have you set the TP Link TL-WA901ND IP to have 192.168.1.1 as the default gateway ?
Also DHCP server is where ?
IN the TP LINK TL-WA901ND or in DLINK DIR 615
Only have one Router running DHCP and set the default gateway in the leases as 192.168.1.1.
What subnet mask are you using is it the same through out all devices ?
Oct 30, 2017 | TP-LINK TP link TL-WA901ND 300 / 11n...
Cant remember wep key
In order to find the wireless security page of your Dlink wireless router DIR-615 , please follow these setps
1. Open up the internet explorer in the comp in which you are online and clear the address bar and type in the number 192.168.0.1 and hit enter.
2. You will be logged into the D-Link router setup page .
3. Under the SETUP tab, in the left hand side, click on WIRELESS SETTINGS? you will find Wireless security Mode under which you can find the password for the wireless settings.
Good Luck!
Thanks in Advance!
With Regards,
Prema.
Jan 11, 2011 | D-Link DIR-615 Wireless Router
Hello support i am trying to ocnfigure Dlink router DIR-615 but not able to acces using 192.168.0.1
I got your issue, If you want to log into 192.168.0.1 , make sure that the computer is connected your router via ethernet cable , then try to open the page using http://192.168.0.1. If still its not opening the page then follow these steps,
1. Click on start--> Go to all Programs--> Accessories--> select command prompt
2. You will get a black window, which is the command prompt and you will find a small cursor blinking there you type in "ipconfig" (without cotes) and then hit enter.
3. Check what is the IP address/ IP v4 ipaddress , which must be in the range 192.168.0.x
4. Then in the next line type "ping 192.168.0.1" (without cotes) then it will give you reply 4 times and then with the ping statistics Packets send=4, Received =4, lost =0.
5. Then type in the next line "start iexplore 192.168.0.1" then you will get Dlink router setup page opened.
Thanks in advance!
Regards,
Prema.
Jan 06, 2011 | D-Link DIR-615 Wireless Router
I am unable to open my nat on my Dlink-Dir 655. I have a static IP configured but am still unable to open Nat. Help.
Thanks for posting your problem with fixya.
I understood your issue and I would request you to follow the below steps 1. Type in 192.168.2.1 on your web browser. 2. At Router's login page, type your username and password(Default Username: admin Password: (blank) ).[ Contact DLINK customer support for details. Toll free number on products box] 3.Once you are in, browse the different tabs and look for UPnP 4.Save and test your XBL connection.
If no go, I would request you to follow the steps on this link. It would be really helpful for you. http://www.mlgpro.com/forum/showthread.php?t=137247
Great time. I appreciate your feedback.
Oct 12, 2010 | D-Link Xtreme N DIR-655 Wireless Router
I have a DLink DIR-300 router and it perfectly functions and connects to internet. When I use my laptop, i have an uncommon problem. The laptop do connect to internet as normal and usual, but when i open...
log in and put in password.
set up router to automatically assign IP addresses and enable DHCP.
make sure your computer is set up to auto detect proxy settings when connecting to the internet.
Nov 26, 2009 | D-Link (DI-711) Router
I want to put password on my router
just open your dlink ip page and type the username as admin and leave the part of password.
it will open a page where there is a palce to add a wifi password
sagar
May 15, 2009 | Directed Electronics Dlink DP-301U PRINT...
Unable to connect to internet
The IP address 192.168.0.1 you use with your browser is not to get into the Dlink WEB page, it is to get into the DLink router configuration, to set up the router and wireless security eg. network SSID, turn off SSID brocast, WEP/WAP encryption, MAC address filtering etc.
Apr 19, 2009 | D-Link RangeBooster G WBR-2310 Wireless...
Need software for dlink dir 301 wireless router
Here is the link to the manual for your router. Follow it's instrunctions to login into the router and from there you can run the setup wizard. If you feel comfortable in doing so, you can set the wireless configuration manually. Please reply if you need specific assistance.
http://74.125.93.104/search?q=cache:FT1VlyIdfuUJ:ftp://ftp.dlink.co.uk/dir_products/dir-301/DIR-301_Manual_English.pdf+dlink+dir+301&cd=5&hl=en&ct=clnk&gl=us
Good luck and thanks for using FixYa!
Apr 09, 2009 | Computers & Internet
Wifi problem of DIR-300 dlink
just open the dlink ip homepage and configure the wireless settings
sagar
Jan 27, 2009 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
D-Link DIR-300 Wireless Router Logo
1,129 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
