Its not spining in the rinse cycle,and i replace the dogs in it
  • Mike Smith
    Mike Smith May 11, 2010
    What brand and model number ?
    Sergeant:
  • 363 Answers
It wasn't that to begin with, sorry you did all that for nothing :(
I assume it works in wash cycle, so most likely it's the transmission shaft tube and brake assembly that needs repair/replacement.
If you know how to remove the cabinet, remove the pump and motor. (Just in case you don't, it's the two screws on the head to take out, flip the head back, then remove the clips holding the cabinet down. Pull forward and off, that's it)
Take the agitator out of the basket. Pop the top off, use socket and ext. to remove, pull agitator out
Lay the machine on it's back, remove the three bolts and slide the transmission out
Raise the machine back up, if you can get that 'nut' off the top of the tube assembly, there are tools for that but if you can do it without the trouble of obtaining that tool, you should be ok. Remove the tube assembly, and replace or just replace the brake assy. without removing the tube. Whichever is easier for you, that's the answer, best of my knowledge
Best of luck to you, let me know how it goes
Joe
Posted on Aug 26, 2009
Roper washer new will not fill with warm water on rinse cycle it fills and spins
if its only a new machine make sure transport bolts have been removed
Apr 09, 2014 | Roper Washing Machines
During wash cycle the agitator only goes one way instead of left / right. all washing ends up wrapped round the agitator.
first thing to check would be the agitator dogs on the agitator here is a video on how to replace the agitator dogs in a top load washer click here http://www.youtube.com/user/RepairClinic?v=0GQh8JLqVv8&feature=pyv&ad=5457341621&kw=agitator usually if the agitator is only spining in one direction this would be what you would have to replace if you have any further questions message me back and please remember when our chat has fully concluded to rank how this opinion has helped it allows me to continue helping others in similar situations in the future Thanks
Rick
Jun 04, 2011 | Washing Machines
The cold water keeps running in the rinse cycle. it nrver fills up it drains out as it flows in
you kind of lost me with that one, but the washer should spray in cold water when in the rince cycle , spining , draining, and spray of cold water. Thats a normal rince.
Dec 12, 2009 | Whirlpool LSQ9600L Top Load Washer
Agitator doesn't turn during wash / rinse cycle
top the top off the agitator,remove cap inside,you have 4 plastic dog ears you need to replace,your local appliance store has them for $2,let me know how you do-mike
Mar 24, 2009 | Kenmore Washing Machines
Agitator only turns clockwise (Whirlpool top load)
You will need to replace the dogs under the agitator, they are pretty easy. Just pop the cap, take out the center bolt, remove it the dogs are 4 teeth looking items.
Mar 12, 2009 | Whirlpool LSB6200KQ Top Load Washer
Washer not spining after wash and rinse cycle Nod # NAV800AWW
Look under the machine and check belt for wear. Replace if any signs of cracks or rubber dust.
Jun 15, 2008 | Maytag Washing Machines
Washing machine not spining
You may have a problem with the rotor position sensor. This sensor is situated on the motor windings and should really be replaced by a qualified tech.
Nov 04, 2007 | Fisher and Paykel IWL12 Top Load Washer
Does not spin in most cycles
It sounds like your timer is defective.  If this is the case you will have to replace it.
Oct 17, 2007 | Maytag Performa PAV2200
Wash cycle not working...
Kerbri, it sounds like your pressure switch could be the culprit. Under the top console the switch will be on the left side. There will be a clear tube that runs from the tub to the switch. Take another piece of tubing about the same size in diameter, disconnect the tube to the pressure switch and connect the tube. Blow into the pressure switch and see if the washer starts agitating. If so, replace the pressure switch.. Another thing to check would be the harness to the motor, make sure it is on tight. Good luck
Jun 26, 2006 | Kenmore 23022 Top Load Washer
Washing Machines Logo
27 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
