My acer aspire e500 has no hard disk aactivity
My acer aspire e500 dosent boot, keeps reading the CD drive even when it is blank and there is no display and hard disk activity.
    Scholar:
  • 143 Answers
Try to discinnect CD/DVD driver also when you power on main cor dont instantly power on case, wait 5 minutes and then try. Such kid of failureas are causer by power adaptor system. Also try bios reset put off battery and wait 5 minutes to reset CMOS also power cord must be unpluged. Unplug and plug power sources to mainboard. then turn on.
Posted on Jul 30, 2009
My acer aspire one netbook AOD257 keeps telling me no bootable device insert boot disk
First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty.
Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
Oct 17, 2012 | Acer Aspire One Netbook 8.9" Notebook
How can i reformat my acer aspire 4520 without cd rom?
Try this method it may work.
If you can boot up with the external USB hard drive on your Acer, then use a working computer and copy the Windows installation CD onto the external hard disk then connect the USB externak hard disk to the USB port on your Acer and boot up using the external hard drive.
Feb 18, 2012 | Acer Aspire 4520-5141 Notebook
My acer aspire one has a hard drive failure on the following disks IDE/SATA.I diagnosed it then got the following report. HDD doesn't respond to system commands Boot sector damaged read time...
You need to format your hard disk. Please note that formatting will erase all you data from the hard disk and all the software including the Operating system.
If you have your OS master CD you can insert it in the cd/dvd drive and restart the laptop. This will detect the OS CD and try to install it. In the installation process there is an option "Format your hard drive". You should select that option. Then it will format, mark the bad sectors, create a new boot sector and install the OS. You will be just fine.
Aug 03, 2011 | Acer Aspire One PC Notebook
My laptop keeps sayin disk read error press ctrl alt delete
Usually you get this message when the hard drive has crashed or there's a disc inside the cd / dvd rom.
Check your bios settings to make sure your computer boots to the hard drive itself.
If you have any more questions, feel free to ask ;)
Oct 14, 2010 | Acer Aspire 5315 Notebook
I just installed a new hard drive to the Aspire E500. When i boot with xp os it i says there is not hard drive found. it goes to a blue error screen, what is my problem?
check the juumper setting on the hard disk, the picture is given on the hard disk. set it on the primary, then again connect the hard disk and start your computer again
Sep 14, 2010 | Acer Aspire E500 PC Desktop
I have a acer aspire T180 desktop , on vista , and it dosent start up , when I go to the system recovery options , it says if you dont see your operating system listed , click drivers toload drivers for...
Most times when you see this message it means your computer can not see you hard drive when booting. I am having same problem and i my case is mo mother board has issues with SATA ports. You can try to replace hard drive cable and also try testing it in another computer. other than mother board this can be also hard drive it self. Test in another pc to determine is it or not. If no other pc by a docking station or hard drive enclosure and use it as usb external drive and see can you access it.you can use any computer even your friends. Hope this helps.
Apr 24, 2010 | Acer Aspire™ T180 PC Desktop
How to format acer e500 with partition
its the same way just about with all computers.... do this
restart computer
enter your bios
open your boot options
make sure your boot methods are as follows
1. cd-rom
2. floppy
3. hard drive disk
then you insert your windows OS make sure its a bootable disc then hit F10 for some computers to exit and save changes....
your computer will restart and then go through the loading then prompt you to hit any key to boot from cd.... make sure you dont actually look for the any key button lol!!!
Feb 18, 2010 | Acer Aspire E500 PC Desktop
Why my acer e500 cannot install 64 bit window 7 it say no driver when need to choose hard disk to install
you need to install Uli sata drivers in order for your motherboard to recognize the harddrive and cd drive.
download the drivers here: http://www.soft32.com/download_184082.html
and put them on a cd or memory card, when the system prompts you that you have no harddrive, you can load the drivers from a memory card or cd however if you use a cd you will face other issues. then you will be able to install windows 7 ;)
I did it on my acer e500 and it runs good.
I didn't install the 64 bits version though but the 32 bits.
for all the people saying that his pc is too old: if the pc can run under vista, it runs better under windows 7
Nov 05, 2009 | Acer Aspire E500 PC Desktop
Hard disk drive problems for my acer aspire 4315
Burn this cd on another computer and then boot from it.
The cd contains some hard drive diagnostics and many other useful utilities
Aug 24, 2009 | Acer Computers & Internet
Computers & Internet Logo
102 people viewed this question
David Payne
David Payne
