Question about Sewing Machines
Top thread keeps birdnesting in bobbin area. - Sewing Machines
  • Sewing Machines Master
  • 1,049 Answers
Hello, Rhonda -
The problem probably lies with the sewing machine bobbin.
See the information here:
https://www.craftsy.com/blog/2014/01/sewing-machine-thread-bunching-up/
You may find the information here instructive, as well:
http://ohyoucraftygal.blogspot.com/2013/10/sewing-lesson-10-how-to-fix-tension-on.html
Best wishes.
Posted on Jan 03, 2018
SOURCE: tangled bobbin thread
Okay. I had this problem too. try taking the bobbin casing out. I had a bit of thread lintg caught in a remote area of the under-plate area. Blow it out with canned air and oil your machine. That should help. It fixed mine.
Posted on May 09, 2007
SOURCE: bobbin thread getting jammed
kyoungblood4
Are you making sure that your pressure foot is up when you thread the upper thread? If it isn't then your thread is not seating correctly in the tension disks. It will then be loose and make a birds nest(mess) under what you are trying to sew. The other thing to check is which way you are putting the bobbin into the bobbin case, different machines do it different ways. Some want the thread to come out of the case in the same direction as the slot on the case and some want it to come off in the opposite direction.
Guest,
Probably when your son broke the needle he knocked it out of time. You will need to have a sewing machine technician to repair that.
Hope this has been helpful for you bothl Liz M
Posted on Aug 08, 2008
sew dutch
  • 25 Answers
SOURCE: Top thread won't pick up the bobbin thread
re insert the needle, maybe you did not put the needle up as far as it is to go. Make sure the flat side of the needle is to the back of the machine. Without any thread in the machine hand turn the wheel and look to see if the hook of your bobbin would/could catch the thread (to see if timing is right)
then thread the machine and hand turn the wheel and see what it is doing.
Your timing might be off, but I do not think that is likely. Though it is possible that when the needle fell out, it hit something hard, broke, and pushed the machine out of timing. then you need to bring it in.
Posted on May 26, 2009
sew dutch
  • 25 Answers
SOURCE: keeps "birdnesting", besides rethreading, how do I fix?
when you have bunching on the bottom, you have a problem with the top thread: no tension. (and visa versa) Make sure the thread runs through the tension discs, these discs are activated when you put the presser foot down, so you want to thread the machine with the foot up, also feel if there no burrs, hooks, or whatever, so your top thread comes smooth off the spool, no jerking.
  • 1116 Answers
SOURCE: I have a Singer 6105 and the thread is birdnesting
Double check:
Threaded with presser foot up.
Feed dogs are engaged.
Stitch length set at proper length.
Thread is feeding from the bobbin spool in the correct order and through the proper guides.
Problem still there - take the machine and a sample of the stitching back to the repair guy and ask him to check the timing.
When you pick up the machine, take a scrap of fabric and give the machine a thorough test run - threading, bobbin winding, stitching before leaving the shop.
Posted on Feb 21, 2010
Where to apply oil to shuttle on White model 2037. I thoroughly cleaned all parts of the machine, rewound bobbins, made sure presser foot was up and rethreaded machine, still getting birdnesting under
If the birdnesting is on the bottom of fabric it is the top tension. If the birdnesting is in the bobbin area I would check the bobbin tension. When adjusting the bobbin tension make sure you are turning the screw in very tiny increments.
Check to make sure the machine is threaded properly and then check again. It is often times something simple.
Jul 07, 2017 | Sewing Machines
Fixing the problem of birdnesting
Birdnesting is a common but very frustrating problem that can be resolved easily once you know where the problem originates. Remember, if the birdnesting occurs on the underside of the fabric, the problem originates with the upper thread. If it shows on the top of the fabric, the problem is the bobbin.
Very often, the machine is not threaded correctly. Remove all the thread from the machine. Check there are no loose threads or lint stuck anywhere in the machine. Oil as instructed in the manual.
Install a brand new needle! The needle should be suitable for the thread and fabric you are using. All About Needles
ALWAYS RAISE the presser foot and rethread the upper thread. Verify the path is correct.
Check that the bobbin is installed and threaded properly.
Pull the bobbin thread to the top of the fabric.
How and Why to Bring up the Bobbin Thread
Set the upper tension to the midway point.
While holding both thread tails lightly in your left hand, begin sewing slowly.
sewing machine birdnesting Google Search
Oct 27, 2016 | Sewing Machines
My bobbin thread continues to bunch up on the back of the fabric.. How can I fix this?
Is it really the bobbin thread that is globbing? Check closely. Usually it is the upper thread accumulating under the fabric.
If it is in fact the bobbin thread, then the bobbin case is not threaded correctly, the bobbin case tension needs adjustment, or it is broken and needs replacement. There are web sites and YouTube videos that show how to adjust the bobbin case tension.
QUICK FIXES: Remove all the thread from the machine. Clean the area around the feed dogs and bobbin area. Oil as instructed in the owner's manual using ONLY fresh, good quality sewing machine oil (only 1-2 drops each spot). Install a brand new needle insuring it is installed correctly. Avoid using fuzzy, old, or bargain bin thread. Rethread: Be sure you raise the presser foot BEFORE threading the upper thread so it will seat properly in the tension disk--and check to make sure you are threading the machine correctly. Check that the upper tension is set properly (the factory standard is usually the halfway point between the high & low number on the selection). Test on a scrap of the fabric you wish to sew. Adjust the upper tension--either tighten to pull the upper thread toward the top of the fabric, or loosen to pull more upper thread down.
Here are some web sites that may help.
Sewing Machine Thread Bunching Up Here Why
https://answers.yahoo.com/question/index?qid=20100303212248AAnRUQA
8 Tips to Fix Birdnesting in Embroidery
Birds nest under the fabric big loops of thread top side looks good...
3 Common Sewing Machine Problems and How to Fix Them
Dec 29, 2015 | Sewing Machines
The thread gets caught up in bobbin area
This mess is commonly referred to as a bird's nest or 'birdnesting' and it's usually caused by incorrect top tension and that's often caused by the top thread not in the correct path. (For me, I occasionally forget to thread through the take-up lever.) A damaged needle can also cause birdnesting.
Aug 02, 2014 | Husqvarna Huskystar 207 Sewing Machine
My topaz 50 keeps birdnesting when trying to sew fmq
Hello
Please re-thread sewing machine from thread spool to needle, making sure that all thread paths are engaged; especially the take up lever and tension area.
Check that the correct bobbin is being used and that it is properly positioned in the bobbin case. Double check that the bobbin thread is in the thread patch and has "clicked" into the spring.
Happy Stitching
Sewingirl/
Jan 27, 2014 | Husqvarna Sewing Machines
The thread is birdnestting where the bobbin is
Birdnesting can be corrected by adjusting the bobbin tension lower. You need to check for threads stuck in the bobbin tension and clean them out. The thread should feed out of the bobbin tension with a small amount of tension. Make sure your bobbin is rotating the right direction; probably counter clockwise. Adjust the top to three and give it a try. You may need to make a small adjustment on the top tension. Your goal is to have the bottom and top tension equal just like a tug of war.
Jan 22, 2014 | Brother PE-500 Embroidery Machine
Birdnesting on singer 1021
Try these suggestions
1. Change needle
2. Rethread the machine--top --make sure to use every thread guide
3. Take the bobbin out --make sure it is inserted correctly into the bobbin
Case, & make sure the bobbin is turned the correct way
4. make sure the thread has not come off the thread take up lever
5. Clean under the needle plate & in the bobbin area for lint or threads
Aug 15, 2012 | Kenmore 11101 Mechanical Sewing Machine
New home model 4018 birdnesting problem help
try changing the needle
rethread the machine top & bobbin
clean under the needle plate & in the bobbin area
check to make sure the thread has not come off the thread take
up lever
Aug 05, 2012 | New Home Sewing Machines
I have a singer-inspiration machine and it appears that the thread keeps getting caught up in the bobbin area so my thread birdnests. I am new to sewing and this is a new machine.
"Birdnesting" occurs when there is no tension on the needle thread to pull the bobbin thread. This is easily corrected by rethreading the machine, following the threading path carefully and making sure the thread is fully engaged in the tension mechanism.
Aug 23, 2008 | Singer 7462 Mechanical Sewing Machine
Tangled bobbin thread
Jan 16, 2007 | Singer CE-200 Quantum Futura Computerized...
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
