Question about PRINTER Office Equipment & Supplies
C5180 Printer Error Oxc18a0101 - PRINTER Office Equipment & Supplies
    New Friend:
  • 4 Answers
If you get an error message on your printer screen (HP Photosmart C5180) which says " 0xc18a0106 ink system failed ", you'll need to carry out a Master Reset on the printer.
Something usually causes the error to occur and this is usually a failed microchip, out of date chip or interruption when installing a new cartridge and this will have to be rectified before continuing. Most problems are usually from the last cartridge inserted, so start by replacing that cartridge. You will also need to have all cartridges with some ink in them or you'll need to replace any empty ones before continuing. Once the problem cartridge has been replaced, keep it as it may still be ok to use at a later date once the error has been reset.
To reset the printer:
1- Unplug the USB cable from the printer.
2- Press the On/Off button to turn off the printer, unplug the power lead from the printer, press and hold both the "OK" button and the "HELP" button, then plug in the power lead, wait a few seconds and release the two buttons, then press the "On" button.
Your printer will now initialise and you'll need to follow the on-screen instructions and choices on the printer. This may take several minutes to complete. Your error code should now have disappeared and you will now be able to Copy and Print.
3- Replug the USB cable from the printer.
Posted on Jan 10, 2018
APremkumar
  • 564 Answers
SOURCE: my hp printer c5180 has error oxc18a0101
  • Unplug the printer cable from the computer.
  • Unistall the printer drivers from Device manager and also unistall the all the printer appications
  • restart the computer
  • try to download drivers from the website
  • after installing drivers and software it will ask you to connect the printer.
  • then you can connect the printer and and try to Print the test page.
Hope this help. Please Rate My Response! Thanks!
PREM
Posted on Mar 23, 2009
  • 22 Answers
SOURCE: error message shows up on printer screen oxc18a0101
Found this link that tells you how to reset the printer.
http://www.fixyourownprinter.com/forums/printer/39471
Excerpt on resetting the printer from the post linked to above:
These are from the link above:
Reset the system by holding down the OK, Cancel, Black, and Color buttons down at the same time and turn the 3310 off. Keep holding the buttons down until the printer shuts off and then turn it back on.
Posted on Apr 05, 2009
  • 415 Answers
SOURCE: ink system has fialed. Error: Oxc18a0101
Follow the link below.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00489814&cc=us&lc=en&dlc=en&product=1153481
it explains the error message and what to do.
Mark
Posted on Apr 06, 2009
efs_perpends
  • 1996 Answers
SOURCE: I don't know how to find printer documentation on Error Oxc18a0101.
You need to reset the printer. Please follow the instructions in this link, and if that doesn't work, try this link.
If neither is successful, you may have to have the unit serviced, but usually one or the other method will get your printer back online.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on May 19, 2009
smwsolutions
  • 73 Answers
SOURCE: printing error oxc18a0101
Try resetting the printer:
1- Turn off power and unplug from power source.
2- Open right side of printer (looking at the front).
3- Disconnect,by pulling gently, both white flat ribbon cables off the main circuit board.
4- Plug in power source and turn printer on. Wait till you get a error message and push "Ok".
5- Unplug power source.
6- Reconnect the flat ribbon cables by aligning and carefully pushing into the conectors on the main circuit board.
7- Plug in power source and turn printer on.
Posted on Jul 19, 2009
On HP Photosmart C5180 Error Message 0xc18a0201
call hp total care 1800 4746836
u knw i cn tell u the steps but if u do even 1 of the steps wrong ,ur printer wont work anymre so contact them
...hp technicians will be able to take care of u
thanhks
Aug 07, 2009 | HP Photosmart C5180 All-In-One InkJet...
Printing error oxc18a0101
Jul 19, 2009 | HP Photosmart C7180 All-In-One InkJet...
Photosmart 8180 has error message Oxc18a0101
try to follow this instructions to fix the error: Hit * and # at the same time on your printer, then enter code: 123 press right arrow, then go to system configuration and press ok 3x. unplug power from printer and wait 2 minutes, plug the printer again and then it will all be back to normal. hope this helps. Good Day!
Jul 08, 2009 | HP Photosmart C6180 All-In-One InkJet...
HP Photosmart C8180 - Ink System Failure - Oxc18a0101
i had exactly this error message. Rang HP. They said it was a hardware failure, they couldn't fix over phone, would cost 2x cost of new printer to fix, but they offered me 20% discount on new printer if ordered over the phone.
But with some fiddling, problem now resolved. Here's what I did:
- press Red Eye Removal and Print Photos button together
- goes to Mfg Commands -> Enter Special Keys Combo. Press OK
- uaiux Support page (some code) -> click right arrow key until you get to System Configuration Menu - click oK
- should say hardware failure status - click OK
- says hardware failure status: Clear. Press OK to clear
- I clicked OK on this and system reset itself and problem was solved
Jun 24, 2009 | HP Photosmart C8180 InkJet Printer
May 19, 2009 | HP Photosmart 3210 Printer
Error message shows up on printer screen oxc18a0101
Apr 05, 2009 | HP Photosmart 3310 All-In-One InkJet...
Won't print
Ink system has failed. Unable to print. Refer to printer documentation. Error:Oxc18a0101
Mar 29, 2009 | HP Office Equipment & Supplies
My hp printer c5180 has error oxc18a0101
PREM
Mar 23, 2009 | HP Photosmart C5180 All-In-One InkJet...
Oxc18a0101 error message - C6180 All-In-One
Try the following reset:
Hold the OK and the Help button at the same time. While holding them down, plugthe power in. Continue to hold both buttons until the unit shut off.
After shutting down, release both buttons and power on the printer.
Alternatively follow instructions on this document from HP.
Oct 14, 2008 | HP Photosmart C6180 All-In-One InkJet...
Top PRINTER Office Equipment & Supplies Experts
Gene
Hardeepak Bhambh
Hardeepak Bhambh
Are you a PRINTER Office Equipment and Supply Expert? Answer questions, earn points and help others
