Question about Sharp Office Equipment & Supplies
There is a way to go to simulation 83 in sharp MX-3640N under service mode..any one know how please?/
Do any one know how to reset the main counter on sharp MX-3640N? THANKS
  • 76 Answers
SOURCE: how to RESET counter
Of course, the printer settings can be changed via the standard print options menu in Windows but to reset the counter is done when a new cartridge is installed. But this is how I would proceed... Since the printer and the cartridge are in "cahoots", I'd not give them the chance to communicate. Do this: Place some tape over the electronic contacts on the cartridge. (This prevents the printer and cartridge communicating) Then... Setup another printer icon using the HP Laserjet 4 (MS) printer driver. (This ensures no communication between the installed software and the printer). This should allow you to print some more, but not duplex of course. Remember to shake the cartridge from side to side in order to loosen impacted toner. ZT3000 "Beta tester of "0"s and "1's
Posted on Aug 19, 2007
SOURCE: Sharp service code H5-01
To enter simulation mode to reset errors enter this sequence on keypad.
P, * , CA , P then enter sim # 14 to reset code.
press " custom settings" button to return to previous menu and CA to exit sim mode.
Posted on Dec 11, 2008
wheatlandsvc
  • 1110 Answers
SOURCE: Reset drum counter on Sharp AL-1644
This works on MOST sharp AL series copiers.
Press these keys in sequence:
Clear → Density select → Clear→ Density select
display should go blank. Then enter:
24 as if you were making 24 copies then press print
then enter 7 as if you were making 7 copies then press print
if successful you should see flashing 000
turn machine off then on again and the drum light should be gone.
Good Luck
Posted on Nov 03, 2009
Testimonial: "Fantastic! The code for the Sharp AL-1644 drum reset worked like a dream! Thank you."
SOURCE: oce tds 800 how do you reset the counter for maintenance and part
hi
you have to go into service first
you have to log on in SDS
WITH user :oceservice
pASSWORD:675756
And there on consumbeles you have to reset by
pressing 0 / enter and than egnoladge with the green V on top
good luck
Yaacov
Posted on Mar 08, 2010
  • 360 Answers
SOURCE: how to reset SHARP AR5320e
hello i think sharp 5316/5320 their have no feature to reset counter
but try this code some time it help you press # ,intrupt button ,C ,intrupt button then you enter to service mode then,
press 24 press start button then press 8 start key then copy coun value is reset to zero and displayed on the 7-seg.then press intrupt key the machine goes to sub code input standby mode.pressed CA key simulation is terminated.
Posted on Jan 18, 2011
Does anyone know service mode Japan for the Sharp mx 3640?? Not #*C*
this is what am looking for..............:)another service mode to get simulation 80..........
Jan 03, 2018 | Sharp Office Equipment & Supplies
HOW DO I FIX ERROR MESSAGE H3-00 ON MY MX M753N
1. Entering the simulation mode
Perform the following procedure to enter the simulation mode.
"#" key "*" key "C" key "*" key
Main code 14 Start key Sub code 0 Start key
OR
"#" key "INTERRUPT" key "C" key "INTERRUPT"
2. Canceling the simulation mode
When the clear all key is pressed, the simulation mode is cancelled.
When the interruption key is pressed, the process is interrupted and the
screen returns to the sub code entering display.
* After canceling the simulation mode, be sure to turn OFF/ON the
power and check the operation.
Note: If the machine is terminated by a jam error or paper empty during copying in the adjustment by the simulation, recopying is required.
DO NOT CONTINUE RESET AS THIS CAN CAUSE A FIRE AND RUIN A PERFECTLY GOOD DAY. REPLACE THE FUSER UNIT
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Feb 25, 2015 | Sharp Mx-M753n mx-M753n
How can I delete the Memory of RESENDFAX for MX-2310?
Try this while you're at it.
# * C * to enter the simulation mode.
Simulation 66-10 is the image memory clear which clears the print/scan/fax memory. DO NOT EXECUTE AND OTHER SORT OF CLEARS IN THE MENU.
Copier Collin Houston TX Copier and Imaging Expert
Feb 08, 2015 | Sharp MX-2310U Color Printer : 2310U
How enter sin simulation mode in sharp MX-M354N
To enter simulation mode you need to press the following 4 buttons in quick succession:
# * C *
The # & * keys are to the left & right, respectively, of the zero key,
the C key is the red C to the right of the number 3 key.
Hope this helps
Jan 14, 2015 | Sharp Mx-M354n Mfp
How to activate simulation mode mx-m264n
OR
When the
Aug 25, 2014 | Sharp M264N Copy Machine
I REPAIR THE MACHINES IN AFRICA SO I NI THE ERROR RESET CODES
"#" key Interrupt key "C" key Interrupt key
Main code Start key Sub code Start key
Usual "reset" codes:
14 - Trouble cancel (except for U2)
16 - U2 trouble cancel
20 - 01 Maintenance counter clear
24 -01 Jam total counter clear
02 Trouble memory clear
04 SPF counter clear
06 Paper feed counter clear
07 Drum counter clear
08 Copy counter clear
09 Printer counter clear
13 Scanner counter clear
14 SPF jam total counter clear
42 01 Developing counter clear
There are codes and subcodes.
example if yiu want to clear the maintenance counter , you have to enter simulation mode and then enter 20 / Copy key /01 /copy key.
I hope it helps you.
regards,
Adi
Nov 05, 2010 | Sharp AR-5316 Advanced Digital Imager...
I just replaced all the moving parts in my Sharp AR-M620 copier including the finisher and drum etc...I have the service codes and sub codes to reset the print counters, drums, developers etc but don't...
* Entering the simulation mode
1) Copy mode key ON ? Program key ON ? Asterisk (*) key ON ?
CLEAR key ON ? Asterisk (*) key ON ? Ready for input of a main
code of simulation
2) Entering a main code with the 10-key ? START key ON
3) Entering a sub code with the 10-key ? START key ON
4) Select an item with the scroll key and the item key.
5) The machine enters the mode corresponding to the selected item.
Press START key or EXECUTE key to start the simulation opera-
tion.
To cancel the current simulation mode or to change the main code
and the sub code, press the user setup key.
* Canceling the simulation mode to return to the normal mode
1) Press CA key.
Sep 06, 2010 | Sharp AR-M620N Copier
Need to reset the drum counter on the AL 1740 sharp while changing to a used drum
Entering in the simulation mode:press Clear - Interrupt - 0 - Interrupt -Main code - Start -Subcode - Start.
When the clear all key is pressed the simulation mode is cancelled.When the interrupt key is pressed,the proces is interrupted and the screen returns to the subcode entering display.After cancelling the simulation mode be sure to turn OFF/ON the power and check the operation.
Main code 20 subcode 1 =Maintenance counter clear.
Main code 21 subcode 1 =Maintenance cycle settimg
subcode 2 =Mini maintenance cycle setting.
Maincode 22 subcode 1 = Maintenance counter display
subcode 2=Maintenance preset value display
subcode 3=Jam memory display
subcode4=Total jam counter display
subcode 5=Total counter display
subcode 6=Developing counter display
subcode 7=Developing preset counter value display
subcode 9=Paper feed counter display
subcode 12=Drum counter display
Maincode 24 subcode 1 =Jam counter clear
subcode 2=Trouble memory clear
subcode 7=Drum counter clear
subcode 8=Copy counter clear
Maincode 26 subcode 22=Language setting
Maincode 42 subcode 1=Developing counter clear
Maincode 43 subcode 1=Fusing temperature setting
Maincode 46 subcode 1=Copy density level adjustment
subcode 19 AE mode picture quality change
Nov 20, 2009 | Sharp AL-1641CS Laser Digital Copier
Sharp mx 2700n how to go SP mode and i get error code h5.01 how i solve this problem
Use SIM14 to
cancel the trouble.
1) Copy mode key ON → Program key ON → Asterisk (*) key
ON → CLEAR key ON → Asterisk (*) key ON → Ready for input of a main code of simulation
enter 14
accpet yes clear..
machine should restart.
You may have to have a tech look into why this is jamming...
Hope that helps
Lbcoaster
Dec 23, 2008 | Sharp MX-2700N Color Copier
Ar5316
May 07, 2008 | Sharp AL-1641CS Color Copier
48 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
