Question about Ricoh Aficio Office Equipment & Supplies
Ricoh aficio SP 3510 error code SC 542
Can this be reset or fixed without calling for a service appointment
boyrevel
  • 71 Answers
SOURCE: sc 542 error code
Error SC 542 indicates a fuser temperature problem. Once the error is detected, the printer is toast until you manually clear the error from the keypad. Even though the printer is physically fine, it won?t come ready until the prior error condition is cleared. The magic keystrokes, clear the error code: The Fix In order to clear error SC542, you must perform procedure 5810. Press and hold online + escape, then power on. Use up and down arrow keys to select SP2 Press Enter Use up and down arror to locate SP5 Press Enter Use up and down arrow keys to select 810 Press Enter Confirm the selection Power off and on. The error code is now cleared.
Posted on Aug 14, 2007
Bubbabear64
  • 2794 Answers
SOURCE: ricoh aficio 2027
SC542 is a warm up error from the fuser.
SC 870 is an address book error.
Turn the power off on the copier. Wait 30 seconds and then turn the power back on. See if it goes away.
Let me know if it doesn't.
Posted on Jul 12, 2008
  • 86 Answers
SOURCE: Ricoh Aficio MP 2510 SC 541, SC 542 Errors
To clear level A SC codes such as this SC541, you need to
Enter SP mode, and then turn the main power switch off and on, only.
Please check if the thermistors are the proper ones and are installed correctly in their position properly.
This is also useful for SC542.
Please check the thermostats and fusing lamps for open circuit.
Good luck and please rate me, thanks.
Posted on Jan 17, 2009
jonniewalker
  • 1031 Answers
SOURCE: copier ricoh aficio 450 error code SC 542-00 ?
  • SC542: Fusing temperature warming-up error
  • check the fusing unit -
    The fusing temperature does not reach the fusing standby temperature within
    125 seconds after the main power switch is turned on.
    - Possible causes -·
    Fusing thermistor defective or out of position
    · Fusing lamp open
    · Fusing thermofuse open
    · BICU defective
    · Power supply board defective
    · Poor fusing unit connection
    troubleshooting
  • to reset the error enter the sp mode c 107 ca then use the sp np 5-801 then pres ok
Posted on Mar 18, 2009
  • 95 Answers
SOURCE: Service Code SC 542
That is fuser code and needs to be reset in the service mode, it will not go away by turning the off and back on.
Posted on May 29, 2009
WHY RICOH AFICIO MP 171 SPF IS SHOWING SERVICE CALL SC 542.
Reseting SC 543 error code on Ricoh copier
Press CLEAR MODE(yellow) key,
Press 1 , 0 , 7
Press and hold down CLEAR/STOP (red) key for more 5 sec.
Press in the SP Mode( on the touch pane)
Go to sp5810 and reset SC code
Open the front door turn OFF the power main switch, and turn it ON
Oct 18, 2016 | Ricoh Office Equipment & Supplies
How do I solve the sc 542 error problem on Ricoh aficio sp 3510dn printer when it does not have an online button or a number keypad?
You need to switch the power switch off.
Hold down either the online & escape or stop/start & escape while switching the machine on.
The machine should start up in service mode.
Select 1 for service mode
Select 5 for mode
Scroll to 810 SC reset and select enter
Select execute.
Switch machine off and on again.
Jun 22, 2016 | Ricoh Aficio SP 3510DN
Fix problems for error code sc 542 for ricoh 3510dn printer
1. Switch machine off.
2. Hold up and down arrows in while switching the machine on.
3. Select Service menu and OK.
4. Scroll to 5.Mode and OK.
5. Scroll to 810 SC/Jam reset and press OK.
6. Execute
7. Switch machine off and on again.
If code does not reset you would need to replace the Fusing Unit and follow the above steps again.
Jun 01, 2016 | Ricoh Aficio SP 3510DN
What is error code SC542 for ricoh aficio 9005?
Ricoh Aficio MP2510, 3010 Error code sc542 on Lanier ...
? 6:08
https://www.youtube.com/watch?v=58MQVyjfDyg
Sep 3, 2013 - Uploaded by Used .Copier
Are you getting Error Code sc542 on your Ricoh, Lanier,Savin or Gestetner copiers? ... Ricoh Aficio 1022 ...
How to reset Ricoh Error Code sc542 sc546 sc548 problem ...
? 2:41
https://www.youtube.com/watch?v=3CnGl1Ytp34
Sep 21, 2015 - Uploaded by Copier Liquidation Center
How to reset Ricoh Error Code sc542 sc546 sc548 problem ...Ricoh Aficio copiers : AFICIO 1013 F
Dec 02, 2015 | Ricoh Aficio Office Equipment & Supplies
How do i reset SC542 error in Ricoh Aficio SP300DN?
FOR RICOH AFICIO SP 3400SF follow below steps.
1. To access Service Mode, On Control Panel press following buttons one
by one immediately.
Cancel Button (Red) ---> 1 (Numeric One) ---> 0 (Numeric zero) ---> 7
(Numeric Seven) ---> Copy Button (Green)
2. In Service Menu you will find Engine reset Menu. In that you can reset
SC 545 in Fuser Reset Menu. And you can also reset SC 542.
Feb 23, 2015 | Ricoh Office Equipment & Supplies
Codigo sc 542 en ricoh sp 3510 como resetearlo
Oi por favor. Gostaria de resolver meu problema com minha impressora ricoh 3510sf que estar dando o erro sc542. Me manda resposta. emiliomartinscte@gmail.com
Apr 09, 2013 | Ricoh Aficio SP 3510SF Laser Multifunction...
My printer ricoh aficio SP 3400SF is showing service call error code SC542. kindly help to come out of this error. \r\nvr babu
by one immediately.
Jun 23, 2011 | Ricoh Aficio AP3800C Laser Printer
Service Code SC 542
May 29, 2009 | Ricoh Aficio 1027 All-In-One Laser Printer
Jan 17, 2009 | Ricoh Office Equipment & Supplies
Ricoh aficio 2022 error code sc542
1. Mode(Yellow Button)
2. 107
3. Press STOP Button for 3 second (RED Button)
4. Copy Sp
5. 5810#
6. Excute
7. Power Off
8. Power On
Oct 23, 2007 | Ricoh Aficio 2022 All-In-One Laser Printer
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
fares
Level 1 Expert
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
