Question about Refrigerators
Refrigerator compartment to warm - Refrigerators
  • 162 Answers
Adjust the dial inside the door
Posted on Jul 30, 2009
Why is my refrigerator not cooling?
If your refrigerator freezer compartment is cold, but the refrigerator compartment is warm--It could be a defrost problem. Refrigerator Defrost Parts
Jul 20, 2014 | GE Refrigeration 21.8 Cu. Ft. Top-Freezer...
Refrigerator too warm
If this is a bog-standard fridge... then its the freezer compartment which actually cools the rest of the fridge. Air needs to circulate throughout the fridge... is the freezer compartment full of ice and need defrosting... if so, do not use sharp objects as there is a thermostatic temperature sensor wire in the vicinity of the ice-box.
Mar 06, 2014 | Sanyo Refrigerators
Mod# ABB1922FEW... the freezer works fine but the refrigerator is warm, there is very little food in the freezer.
If the vent from the freezer to the refrigerator is not blocked with food or paper particles, then it's likely the defrost system is not working properly. You will need a technician to determine the cause.
Jan 22, 2013 | Amana AFB2534DE Bottom Freezer French Door...
Have a kenmore refrigerator freezer works but not refrigerator
You mean "How to Fix a Kenmore Refrigerator That Is Not Cold But the Freezer Is Good?"
Well this what i say,
Kenmore combination refrigerator and freezers combine the short- and long-term food storage options in a single unit. There are some occasions when the refrigerator compartment might appear to be malfunctioning while the freezer box stays cool. Ruling out these occasions ensures you have done everything you can to correct the problem before calling for a technician if necessary.
1.Verify that the temperature controls for the refrigerator compartment are properly configured. Tap the "^" or "v" buttons beside the refrigerator's LCD temperature display until "38," the ideal temperature, appears. The compartment could have been set too warm. Allow 24 hours for the the appliance to reach 38 degrees Fahrenheit.
2 Check that the refrigerator compartment door closes completely, objects inside the appliance could be holding the door ajar. When cool air is allowed to escape, the internal temperature rises. Cracked, holed or corroded door seals may also raise the refrigerator temperature.
3 Change how you use the refrigerator compartment; storing hot or warm food strains the appliance and causes a rise in internal temperatures. Do not prop open the door or leave it ajar for more than a few seconds at a time for the reasons outlined in Step 2.
4 Contact Kenmore if the refrigerator compartment remains too warm for your food. There may be a problem with the motor or any one of the other parts that regulate the temperature
If this was helpfu.l please let me know.
Thanks for using FixYa
Sep 06, 2011 | Kenmore Top Freezer Refrigerator
Working fridge, warm freezer.
The fresh food compartment is cooled by air being blown from the freezer compartment into the fresh food compartment.
There is a panel, or door if you will, that separates the freezer and fresh food compartments. The freezer temp control determines how much cold air is allowed to escape into the fresh food compartment by opening or closing this panel.
In your case, the door must be stuck all the way open, allowing all the cold air to be diverted into the fresh food compartment. The compressor cycle is controlled by the thermostat in the fresh food compartment and thus 'short cycles' because the fresh food compartment acheives normal temperature while the freezer is relativel warm.
If the panel is restricted from moving (stuck in the extreme open position, for example), the fresh food compartment will get VERY cold while the freezer will be warm.
Try thoroughly defrosting the refrigerator. Possibly an accumulation of ice is preventing the panel from moving and/or is diverting all the cold air from the freezer into the fresh food compartment. It's a free fix and may solve your problem altogether.
If that doesn't help, or helps only temporarily, you may have a problem with panel/door/flap itself or the linkage that connects it to the control mechanism. Unless you're skilled in appliance repair, checking and repairing these components will require the help of a service technician
Hope this was helpful. Good Luck.
Aug 28, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
Warm refrigerator compartment
There is a fan that blows the cold air down from the freezer to the fridge compartment. It is usually called a freezer fan. Most of them are behind the plastic lining in the freezer. I just noticed that your fridge is a side by side. I have never wored on a side by side but I imagine there is fan in them as well.
Jul 06, 2009 | GE GSH25KGRWW Side by Side Refrigerator
Freezer is cold, bottom compartment warm
check to see if if the back wall of the freezer is full of ice if so this is an automatic defrost problem
timer ,heater or limit switch
Apr 23, 2009 | Frigidaire FRT21H7AS Top Freezer...
Refridg. compartment warm
You may have a problem other than in the refrigerator compartment.
I am in the U.S.A. and am unfamiliar with some of the brands posted on this forum. However designs of refrigerator freezer combinations have a basic relationship. Check your freezer compartment for a frost sign on the back wall. If frost is present on the back wall a defrost problem is evident. This type of problem can be related to a defrost timer, defrost heater or defrost thermostat. If you can located the defrost timer and rotate the dial clockwise SLOWLY until you hear one click. This will put the refrigerator into the defrost mode. After a time event of 18-22 minutes the compressor should restart. After 25 minute if it does not start advance the timer dial SLOWLY one more time and the compressor should start.
May 26, 2008 | Goldstar Refrigerators
Warm refirig compartment
is there a heavy frost build up in the freezer section?? do you hear the fan running?
May 20, 2008 | Kenmore 77870 Top Freezer Refrigerator
Frost in freezer compartment
It is possible to get this build up in the return vents.  Check seals for any possiblilty of warm air getting into the fridge.  Warm air getting in will cause this.  For now use a hair dryer or some hot water to clear the vents.  Let me know what you find.  Would appreciate a solved rating for expert advice.
Oct 17, 2007 | Refrigerators
Refrigerators Logo
88 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
