Question about Refrigerators
After several years, my refrigerator water line had a leak. I fixed it with a another braided steel line and it started leaking in about 6 weeks? It leaks from the middle,of the line. Any ideas
  • 5 Answers
Sounds like you need a new line. Are you sure it is leaking from the middle, and not seeping down to the middle from one end? Is one end plastic? And if so, did you use teflon tape?
Posted on Jan 03, 2018
Water is leaking inside the fridge on the one side. Then fridge starts making a noise when closed. Stops when you opeb the door.
has your fridge got a water drain hole at the bottom/back? if so, it might be blocked.
Sep 08, 2014 | Refrigerators
Water leaking from the bottom of the refrigerator
You could have a clogged drain line or a cracked drain pan. I would start with the drain line.
Mar 24, 2013 | Maytag Refrigerators
Fix leaking fuel line
What Vehicle?
What kind of repair-steel tubing,plastic tubing or
braided steel.
Nov 30, 2012 | Cars & Trucks
Our Sub-Zero Mdl 680F is 11 years old, and virtually for its entire existence in our house, the water and ice dispenser has been un-useable because they taste bad. The taste was "oily" almost as...
Hello
Change the supply line to the plastic tube line or copper. Do not use a braided plastic or metal braided line these will make the water taste bad. Changed mine to the plastic line and cured mine, no filters needed.
Replace the water filter cartridge in your refrigerator if the ice tastes bad or the control center display recommends it.
Sep 07, 2011 | Sub-Zero 680 / F
We have the maytag refridgerator that has the ice maker. We had it for 2 years without using the ice maker moved then we decided to get the line to get it up and running. Upon the ice being made we noticed...
I would replace the plastic tubing ASAP. After 8 years using the plastic tubing we found our finished basement ceiling leaking water. When we looked into the source we found a hairline crack spiraling along the plastic tube. This must have leaked for several months. The very fine water spray ran down the wall and through the supply line hole in the floor and onto the ceiling. Replace the plastic line with a steel braided one. You wont have any issues with taste or breaking.
Jun 19, 2010 | Refrigerators
Water is leaking from water hose at bottom of frige when water handle is depressed. Ice maker works.
If your hose is copper or plastic, this is a common problem.
I reccomend replacing it with a stainless steel braided, icemaker line. They are more flexible and less prone to leaks.
Oct 03, 2009 | Kenmore 53542 / 53544 Side by Side...
Automatic water dispenser not working/bypass valve leaking alot
Dear Rodeo mary,
Before you do anything else, please first defrost the fridge. Yes, turn it off and leave it open for a couple of hours until all the ice in all compartments has melted. Clean it and put it on again. Is it ok ? Please let me know.
arturocruz.
abwakhweya@yahoo.com
Jun 02, 2009 | KitchenAid KBRP20ERSS Stainless Steel...
Samsung Ice Maker on Mdl RB215LASH
It is quite possible the water line near the ice-maker is frozen. I would try a warm hair drier to thaw it out.
Apr 21, 2008 | Samsung RB215LASH
Refrigerators Logo
23 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
