Question about Dell Latitude Cp, Cpi, Cpx, C600, C800, Inspiron 3800 8000 4000 601212 CD-ROM Drive
LCD fault the desk top window is not full screen when i start computer
  • luckyones Nov 24, 2007
    the computer is a dell latitude cpi it is old .its for my kids to play basic games on it is runing win 98 thanks for any help
  • Anonymous Feb 01, 2008
    I have the same problem and it also says I have bad display driver but I don't know which one to use.
Hold Fn+F7 (font) and the screen will return to normal size.
Posted on Aug 07, 2008
    Problem Solver:
  • 16 Answers
Try increasng the screen resolution by accessing display propertes in control panel,it could resolve issue if display card supports higher screen resolution
Posted on Feb 13, 2008
How to fix vertical lines on a panasonic viera 3D lcd 55" tv
If you wish to get some details; check the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Sep 01, 2016 | Panasonic 55" L55ET5 Viera 3D Full HD...
Windows 10 screen cut off top and bottom how do I expand my screen?
Use the minu button ?? on your screen to stretch the image ( a square with 4 arrows pointing at corners)
Oct 26, 2015 | Dell Desk Top Computer--and Lcd Monitor 17...
How can i adjust horazantal and vertical screen monitor size so i may fill full screen?
In Windows:
1) Click the "Start" button lower left hand corner of the screen, or the Windows key on the keyboard,
2) Choose "Control Panel",
3) Choose "Display"
4) Choose "Change Resolution", and select one that gets you where you want.
FixedYa !
Feb 25, 2015 | HP Desk Top Access Center DK985A
My dell inspirion 6000 laptop screen goes black but sometimes I can see the windows screen but it's very dark. When I attach it to a desktop monitor it works fine but the laptop is still dark. Sometime the...
The back light is the whole of the screen, the screen is illuminated by a CCFL lamp (fluro tube) on the bottom of the screen. A inverter supplies high voltage to this CCFL lamp.
If your laptop appears to boot up and the hard disk LED flashes, then the problem is probably a back light fault. This can be a faulty inverter or a faulty CCFL lamp. Please click on this link and follow my instructions to identify the fault and possible fix :-
http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Feb 08, 2011 | Computers & Internet
I AM SETTING UP A DESK TOP COMPUTER AND MY MONITOR IS SHOWING ME A MESSAGE THAT SAYS "OVER RESERVE". MY WINDOWS PROGRAM STARTS UP AND THEN THE MONITOR SWITCHES TO THIS MESSAGE. CAN YOU HELP ???
Go in safe mode (tap f8 while booting the pc) and set the resolution of your screen to a lower one. then reboot and you should have a working environment
Oct 20, 2010 | Microtek C593 15" Flat Panel LCD Monitor
New monitor purchased with a package with compaq desk top, but trying to use with a Acer desk top, screen comes on , but then goes completely dark after about two seconds. If switched off then on, again...
Could be a faulty monitor, or could be missing the driver information for the monitor. Usually when you first connect it will use a generic driver to start but then should automatically download and install the correct driver information for the monitor. Could also just be a faulty cable, power or VGA, HDMI, which ever you are using. Try using different cables first, then you can google search for the correct driver and manually install it.
Aug 22, 2010 | HP Compaq Q2159 21.5-Inch Widescreen LCD...
My screen is scrambled don't know if its the
if you can see the windows screen on start up and it looks ok and scambled when on desk top you may fine its needing driver updates,
if the screen is the same scramble at start up as in desktop screen then the lcd panel is at fault ,the videocard in from memory on the motherboard
there are chips along the top of the lcd inside the case,some times they fail and do the same scramble result,replace lcd panel and away you go,
try an external monitor yet?Misterdj
Apr 05, 2010 | Computers & Internet
My monitor say out of range and no in put siginal be for this it said DVI disconnected. I can plug it into 2 other computers and it works. HELP
This problem is the screen resolution that your computer is set at. Start the computer enter safe mode, press and hold F8 as windows starts. change the resolution right hand mouse click on desk top, click on properties, lower the screen resolution, and re start. I hope that helps.
Jul 12, 2009 | Star Logic 17" LCD Monitor
No showing the full screen. Top + bottom 1 and half inches dark
your system display settings are set to a wide screen setting on desk top right click then properties, right had tab display then set the screen size to a square shape like 1024 x 768.
Feb 16, 2009 | Dell E153FP 15" LCD Monitor
Acer Monitor boots up w/computer then "no signal"
you must have disconnected it while the pc was running.damage can occur while doing this as can a keyboard (they are not like USB devices that can be plugged and unplugged while "hot".)
Jul 20, 2008 | Acer AL1916W 19" LCD Monitor
Computers & Internet Logo
82 people viewed this question
Alun Cox
