Question about Philips DVP642 DVD Player
My phillips 5.1 dvd player not playing dvd disc, only playing vcd
When i insert the dvd disc, it plays the movies for 10-15 seconds, then hangs dvd player. NO DISC appearing when re-inserting the disc again, no action from dvd player. what should i do.
  • 2,237 Answers
The laser lens on the optical pickup is dirty or scratched. to clean: buy a disk cleaner and use it per instructions. if it doesn't help, you can do it manually. remove the top, remove the top off of the disk assembly (you may have to remove the whole assembly first) until you see the lens. be careful with the cables and wires. use a lint-free swab (not a q-tip and not your finger), gently wipe off the lens. replace the covers and test. if it still doesn't work, it may be scratched or damaged. in which case, it needs to be replaced.
Posted on Jul 30, 2009
How to repair dvd player v zon says wrong disc
Hi Vzon DVD Player,
Before you fix anything, you need to troubleshoot the problem first to know what needs fixing. Since DVD players can play different kind of media formats like Audio CD, VCD, mp3, etc, please try the following
1. Turn on the DVD player and set the program to DVD. some player needs to be setup due to multiple functionality (can play mp3 on flash drive, etc..)
2. insert different Media CD as mentioned above if your player will play them. (if they play, try to insert the DVD you want to play)
3. Try different DVD disc
4. If all the above don't work, try to clean the laser head using the standard disc cleaner.
5. retry the DVD disc
6. If the player still don't play your DVD, probable issue would be the laser head or the disc motor.
7. Please bring them to you nearest Electronic repair shop for further assessment.
Good luck and thanks!
Aug 20, 2011 | Coby TF-DVD7107 Portable DVD Player
Philips DVP Playing problem
try to clean or change the laser
Mar 11, 2010 | Philips DVP642 DVD Player
CD disc is playing ok. DVD discs not playing comes up on screen saying "wrong disc" when loaded.
double check if it really is a dvd and not a vcd, the latest dvd players only play real dvd's so not the ones you make at home by downloading movies and burning them on empty cd's
Aug 02, 2009 | Alba Televison & Video
DVD player plays VCD/SVCD but not DVD
there is a problem with the disc motor, replace it
Apr 08, 2009 | Philips DVP642 DVD Player
DVD Player D1816 shows Wrong Regional Disc message
Many DVD players are preset to one region and if you use a DVD destined for any other region, the player will refuse to play. Some players have the option to change this to universal mode. Check your player's manual if yours has this facility.
Yes. You can play VCD movies and and Audio CDs on most players.
Mar 18, 2009 | GPX D1816 DVD Player
DVD disappeared in DVD Player after viewing movie
Get the dummy cd disc, put a blue tac on it. Insert it. Then after few seconds, eject it. Your dvd disc should stick with it when they came out. It worked for me and hope it will work for you.
Jan 31, 2009 | Kenwood DV-505 Multi-disc DVD Player
Kenwood DVD player 5 speaker system
There is nothing wrong with it, it is set to only play in the region it was purchased from. That is how all DVD players are made, with regional settings. No repair is going to help, you just need a DVD player from the proper region to play those disc's.
Nov 05, 2008 | Audio Players & Recorders
DVD PLAYER 3166 SHOWING NO DISC
I AM HAVING A DVD PLAYER 3166 . MY DVD PLAYS CD /VCD/MP3/JPEG AND USB. BUT WHEN I INSERT A DVD VIDEO IT SHOWS NO DISC ERROR. BUT CD IT ACCPTING.KINDLY HELP ME OTHER WISE TELL ME WHERE SHALL I GET IT REPAIRED . PLEASE GIVE ME THE PHONE NOS OF PHILIPS CUSTOMER CARE THANKS, G.SEKARAN, CHENNAI
Aug 26, 2008 | Televison & Video
Mp3 disk no audio when playing
First, make sure the CD is an AUDIO CD, and not a DATA CD
If you have recorded a Picture CD or MP3 CD
yourself, ensure that your disc contains at least 10
pictures or 5 MP3 tracks.
MP3(ISO 9660) 96, 112, 128, 256
kbps & variable
bit rate fs, 32, 44.1,
48 kHz
– MP3 discs, picture (JPEG) files
on CD-R(W).
– JPEG/ISO 9660 format
– Maximum 9 characters display.
– Supported sampling frequencies :
32 kHz, 44.1 kHz, 48 kHz (MPEG-1)
16 kHz, 22.05 kHz, 24 kHz (MPEG-2)
– Supported Bit-rates : 32~256 kbps
(MPEG-1), 8~160 kbps (MPEG-2)
variable bitrates
Oct 02, 2007 | Philips DVD 622 DVD Player
"no disc" message
sounds like you have a problem with the laser.laser has to focus a lot sharper to play dvd thus will play vcd but not dvd.Try cleaning first and if this doesnt work would suspect laser faulty,.
May 29, 2007 | Cyberhome CH-DVD 300 DVD Player
Philips DVP642 DVD Player Logo
205 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
