Question about Hotpoint Refrigerators
My HOTPOINT HTS22GBMARCC stop working when fridge door is close, but when door is open it start working and cooling.
    Top Expert:
  • Hotpoint Master
  • 45,990 Answers
Could be due to a faulty door switch
Posted on Jan 03, 2018
  • 1462 Answers
SOURCE: Hotpoint Fridge freezer FFA90 - Noisy fan top fridge
worthwhile checking closer. noisy fan can be due to fan blade hitting ice if there has been a build-up. otherwise needs replacing
Posted on May 07, 2007
mikedurland
  • 481 Answers
SOURCE: Maytag MSD2651HES fridge not cooling freezer works find
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
Posted on Jul 06, 2008
landsend
  • 1066 Answers
SOURCE: fridge side wont cool unless the freezer door is open
the little fan motor in the freezer is defective.  It may only be stuck.
Posted on Apr 01, 2009
  • 153 Answers
SOURCE: freezer door pops open when fridge door is closed.
well u need to check the rubber of ur freezer ;s door .some damaging in the rubber is causing the problem.
Posted on Jul 21, 2009
aasc
  • 1606 Answers
SOURCE: hotpoint ffa90 fridge freezer
Turn it off , so it can defrost for about 5-8 hrs . Then turn it back on , and it should re-coup , and start working normal . The compressor is not bad .
Posted on Nov 20, 2009
What will cause a damper between the freezer and fridge on a side by side to stop working?
Recheck the board wiring, and make sure the damper has power when the thermostat calls for cooling in the fridge. If there is power, it's the motor or its connection to the baffle plate. If no power, it's the board.
Apr 24, 2014 | Hotpoint Refrigerators
Hotpoint ctx18ea fridge not cooling
Kimberley, try this:
First see any sign of ice build up in the freezer.
1. Switch off power from wall outlet.
2. Open the fridge door and freezer door and keep them open for atleast 5-6 hours. Salvage whatever food you can.
3. You may now see a puddle of water under the fridge. Clean the floor and inside of the fridge if water and other fluids visible .
4. Now re-connect power and set the recommended settings- usually at 4. Close doors.
5. Your fridge will be making a humming sound. Let it begin to cool.
Good luck
Apr 05, 2014 | GE Refrigerators
Why is Fridge not cooling well?
The part number you need is going to be WR09X10050. This is for the damper assembly, but while you are at it change out part number WR55X10150. this is the part that controls the damper and more than likely if one fails the other will be soon to follow
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Jun 05, 2012 | Hotpoint Refrigerators
Door not closing
Check there is nothing inside the fridge stopping the door closing. Check the hinges are aligned ok and the door closes without springing back open. If there is a self closing mechanism the pin may have come out of the top of the spring.
Apr 22, 2012 | Hotpoint HSS25GFP Side by Side...
On my Maytag side by side, stainless steel fridge, Model #: MSD2651KES. The freezer works perfectly, but the fridge will not get cold, but if you open the freezer it will start sending cold air to the...
Its defrost problem.--------- When you open the freezer door, then ice starts getting defrosted, because outside temperature is warm and due to that inside ice gets bit melted.--------- -------------- The working procedure of this unit is as follows: --- The compressor starts then it cools the freezer section. When the freezer reaches its cooling level the defrost cycle starts functioning. In this cycle the fan in the freezer section starts running and the cool air in the freezer section is passed to the fridge section and the fridge section gets cold. The air from freezer to refrigerator passes from the section, in that section the damper is located. ----------- The damper is operated by a motor.Its a complete damper assembly with motor included in it.--The damper has door.Which closes and open with the help of motor.In your case the damper door is blocked by ice, because your refrigerator is not defrosting.But when you open the freezer door, the inside ice gets bit warm and it starts melting and this lets the fridge section get cool.------------------- In this case you will have to manually defrost the ice and inspect, if the problem solves.For manual defrost procedure, click the link below:-------- Click this below for more detail:--- http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html ----------- This will help.Thanks.Helpmech.
Aug 11, 2011 | Maytag MSD2657H Side by Side Refrigerator
I have a hotpoint csx27h side by side refrigerator. the freezer get cold but the fridge part just started to where it wouldnt cool down. any suggestions? maybe the defrost?? the only things i have noticed...
check the operation of your damper door between the freezer and refrige compartments,this door opens and closes to throttle cold air from freezer to refrigerator compartment through the cold control,sometimes they freeze upand can't move,sounds like your door has frozen closed,if so,remove entire damper door unit,clean and deice,replace and see if this rectifies your troubles
Jan 12, 2010 | Hotpoint (HSM25IFTSA) Side by Side...
Hotpoint ffa90 fridge freezer hi the fridge door was left open overnight but has been closed all day,the problem is that the fridge compartment is warm. The freezer seems ok
this is heat likley to be from the compressor,,,it may have burned it out as it was working its hart out trying to cool your house down all last night? never stood a chance did it?
Nov 19, 2009 | Hotpoint FFA90 Bottom Freezer Refrigerator
On my refrigerator hotpoint model hts22gbmarcc is
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Oct 30, 2009 | GE Hotpoint Top-Freezer Refrigerator
GE Profile - Fridge Doesn't Cool But Freezer Works Fine
Had a similar problem with my Kenwood Fridge Freezer
If you're mechanically minded you could check if there's an opening and motorised flap (usually behind a cover) at the top of the fridge - Cold air from the freezer enters the fridge through this flap) The Sound you heard could have been the motor trying to open / close this flap. This flap can become frozen in the closed position - so cold air is unable to enter the fridge compartment) My fix was to thaw it with a hairdryer and reassemble. Another fix would be to empty the freezer and open the doors - it might take more than 24 hours but once completely defrosted if the flap is the issue it will have defrosted. Once plugged in again the door will open and cold air will start to flow into the fridge compartment. I had a quote for €195 for a call out / repair
I fixed it myself in an hour - Hope it works for you ...
Sep 20, 2017 | GE Profile PDS22MHR Bottom Freezer...
Refrigerators Logo
26 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
