Question about Refrigerators
My CWC600 Wine Cooler does not cool the top half of the cooler, the fan located in this section does not run
Both sections of the cooler are cooling to 13 deg. C
    Dedicated:
    Visited the website for 20 consecutive days.
  • 319 Answers
Replaced the fan and should be fine
Posted on Jan 03, 2018
    Master:
  • 456 Answers
It is telling you its time to get to an AA meeting
Testimonial: "Ha ha"
  • 27 Answers
SOURCE: wine cooler
cheak the machine main on/off switch, cheak the in$out phase line
Posted on Jun 21, 2008
SOURCE: sylvania table top wine cooler
go back where you bought it...buy another one and bring back the one thats flashing,get your refund and walk home with a new cooler
Posted on Jul 03, 2009
garing
  • 998 Answers
SOURCE: admiral refridgerator freezer works fine but
it may be a timer and a timer(timer can be anywhere,inside or out by compressor or behind toe kick it has 5-6 wires and a 1/4 inch hole with a flat screw head in it. use flat screw driver,turn it until it clicks...it will turn one way only...that should put in defrost and in 30 minutes or less the timer should turn compressor back on if not replace timer...when it is in defrost se if element works if not ...check element with meter...also termination switch...open above 32degreeFclose under 32 also ...do not damage coils with freon in them
Posted on Aug 25, 2009
SOURCE: Wine Cooler not Cooling
I think the compressor of the cooling refrigerator is not working. Otherwise the refrigerant gas has escaped from any leakage. Please check two above mentioned things. Gautam Kr. mandal, Durgapur
Posted on Jan 19, 2010
SOURCE: Haier HVTB40DPABS Wine Cooler Top section will
http://www.fixya.com/support/r4476681-haier_thermoelectric_wine_cooler
Posted on Apr 03, 2010
Cuisinart wine cooler not cooling
Hola, buenos dias. Tengo 2 cuisinart cwc600 y no enfrian. Me dijeron que era la tarjeta electonica. Donde puedo comprarlas? Gracias
Oct 06, 2014 | Cuisinart Private Reserve CWC-600 Wine...
Wine fridge is not getting cold anymore
Its really hard to determine without proper diagnosis, but are you sure it indeed has a compressor? does it run ? Does it have a circulating fan inside? A lot of the wine coolers I've dealt with were "Peltier" coolers. They use electronics to cool usually only to about 10deg below room temp. They require a load ( in this case wine bottles ) to operate properly. They don't have a cold control like a refrigerator.
Jun 30, 2014 | Koolatron KWD28SN 28 Bottle Compressor...
Wine cooler not cooling.
Your themostat inside the cooler may be broken.
Mar 19, 2014 | EdgeStar TWR282S Wine Cooler
Take a look at: https://edgestar.zendesk.com/hc/en-us/articles/200604529-My-beverage-cooler-is-not-cooling-below-50-degrees-How-do-I-get-the-temperature-lower-
May 11, 2013 | EdgeStar TWR181ES
Wine cooler doesn't cool
I recommend that you maybe add more details to your question so it will be easier for Experts to understand the question and answer it.
Oct 06, 2012 | Kalorik WCL-20629 18 Bottle Dual Zone Wine...
It just stopt cooling (wgersdorf@yahoo.com)
Turn the temperature dial to the lowest temperature setting. Wait 24 hours for the wine cooler to reach the desired temperature. Also, turn the wine cooler off and inspect the fan. If the fan if it's running or not.
Lastly, check the compressor.
These are the areas that could make your wine cooler stop cooling; the temperatue settings (Thermostat), then Fan and the compressor.
Check these three areas and let me have a feed back.
Bye for now.
Mar 04, 2011 | Haier BC112G Wine Cooler
Kenmore wine cooler 13485 spill wine in the top not cooling
if suction line is warm and pressure line hot . sounds like comp is trying to do its job / ck the fans and they may be slow or not going . spilling of the wine did not cause problem . .. but now is the time to correct the problem .. mm / ps if unit is running like you state the you might look at the ref charge . as it may be low . mm . hope this hs helped . feed back pls .. mm
Jul 22, 2010 | Kenmore 13485 Wine Cooler
Wine cooler doesn't cool properly
Few things to check here. If the compressor is not running then the problem may be a bad thermostat or the compressor start device (ptc starter). Most common would be the thermostat on wine coolers. Also need to check if the fan is running. If everything is running then you have a sealed system problem. If the fan is the only thing that is not running that will cause a no cool situation.
Oct 07, 2007 | Marvel 61WC Wine Cooler
Refrigerators Logo
29 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
