Question about Mercury P4VM800M7 Motherboard
CPU NOT DETECTING ERROR CODE FF - Mercury P4VM800M7 Motherboard
  • 89 Answers
If you are having trouble booting the system and getting a screen try the following multi-step procedure. Power off your system first before completing any of the following tips.
1) Check CMOS clear jumper JP1 (JBAT1 on some systems). Set for CLEAR for 5 seconds, then move back.
2) Check CPU host clock jumpers (if any) are properly set. Note: does not control memory bus.
3) Check your power supply. Should be 110/115v for North America.
4) Unplug all data cables for IDE and FDD from the motherboard.
5) Unplug all power supply cables attaching to your IDE and FDD drives.
6) Remove all cards and devices EXCEPT for video, RAM, CPU, CPU heatsink/FAN.
7) Move memory into a different bank, if available.
8)Unplug the CPU and reattach.
9) Ensure your CPU heatsink/FAN is attached properly to the CPU.
10) If you use a variable RPM fan ensure its set for full speed.
11) Retest.
12) If 1-11 do not help power off and test the motherboard outside the computer case to eliminate a case/motherboard power short.
13) Retest. If the board now works check for case problems. If the system still is not working continue…
14) You may have a possible hardware problem. Any device in the system may be a possible culprit. Use process of elimination to determine the cause. Swap out as many components as possible starting with RAM, CPU, POWER SUPPLY, VIDEO CARD (if present) and/or MOTHERBOARD.
Posted on Jul 30, 2009
Error code for FF for KingAir air conditioner?
Error code FF means the outdoor DC motor fault.
first check the resistance value of the DC motor port, change the DC motor if short circuit.
Nov 08, 2016 | Refrigerators
Display on motherboard reads FF
THat is the "power on and first initialize CPU" halt code. Most often, if this error occurs, you have a bad CPU. You should also check the JBAT1 jumper to be sure it is installed and on the correct pins. If the CMOS is being held reset or does not have its power source the system cannnot initialize the CPU.
Dec 31, 2011 | MSI 790FX-GD70 AM3 AMD 790FX ATX AMD...
My LG display is reading ER FF what does this mean and what can I do to fix it?
Error Code Er FF
This code is not to be confused with the O FF or demo mode error message. The "Er FF" error code indicates a problem with the unit's freezer fan. The freezer fan controls the temperature in the freezer. The source of this error is most likely ice buildup. As with the Er IF error, allowing the unit to thaw should resolve the issue. Contact customer service if the error code continues to be displayed after having thawed the unit.
Hope helps.
Apr 03, 2011 | Refrigerators
Working with sony pvw-2800 getting an error code 02 with ff and play. what is this error?
error 02 is "slack or breaking of tape is detected in search, fast forward, or rewind mode". usually caused by problems in the reel motor assemblies themselves.
Jan 11, 2010 | Sony PVW-2800 VCR
Ive brought a new gaming rig, as follows CPU: Athlon II X2 240, 2.8Ghz MBD: Biostar TA770E AM3 / DDR2 / SATA RAM: 2GB DDR2 800MHz Case: CoolerMaster Elite 330 PSU: WinPower 450w One 300gb Sata drive One...
These new graphics cards pull a lot of power from the power supply. I know you didn't start off having this issue but given the symptoms you are experiencing I'd take a closer look at the power supply and perhaps replace it with a 650 watt or better.
Nov 16, 2009 | Acer Aspire™ T180 PC Desktop
16-bit ms-dos sub system error while runing graphics programs on ntvdm cpu on amd athlyon processorTurbo c++The NTVDM CPU has encounterd an illegal instructionCS:d3e8 IPc180 OP:ff ff ff ff ff ff
HI,
Navigate to updatemgr.exe in C:\Programs\Common Files. Next, rename the file. Right-click it, select RENAME and rename it to, say, updatemgr.old, save the changes and click on OK. RESTART your computer and the problem should now be solved.
Please post back if you need anymore assistance.
Nov 09, 2009 | HP Computers & Internet
16 bit error while using turbo c graphics...........
Try running Turbo C with administrative priviliges and running it as Windows XP SP2 if you have Vista. Seems to work for me.
Aug 04, 2009 | AMD Sempron LE-1300, 2.3 GHz...
16 -bit error on amd
may be over heating problem
open the pc side panel and clear the dust from pc and cpu fan
Jul 21, 2009 | Computers & Internet
Refrigerator LG LFC25760ST Serial # 701KRUC00022 PROBLEM ERROR CODE: ER FF What is this? How can I solve the problem?
Hi, The FF error code indicates that the freezer fan motor is defective. You could also get this code if ice is preventing the fan from turning. Please set up service for refrigerator before the fan motor gets worse !
It's written like this in the repair manual:
Which means what I just wrote above about the fan motor!!
Error detection category:
Abnormality of BLDC FAN Motor for Mechanic Room
Error Display: FF
Error generation factors:
It is caused when F/B signal isn’t over 115 seconds during BLDC FAN motor operating
Remarks:
Poor BLDC Motor connection, DRIVE IC, and TR.You can check the below trick, if that might work on your model :-
Pull the top and bottom baskets out, and take the back panel out from inside. There would be asolid block of ice built up around both fans and wires. Take a blow dryer and gradually melt the ice around the fans and wires. Then, pull the remaining ice chunks off of the wires. Then put the thing back together and it should clear the message.
Unless call a tech from LG.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Jul 12, 2009 | LG LFC25760ST 25 Cu. Ft. Panorama French...
Is my CPU fried?
if it was your cpyu, you wouldnt get error codes or beeps. perhaps the problem is your power supply or bad ram.
Dec 29, 2008 | Evga (122-CK-NF68-T1) Motherboard
Mercury P4VM800M7 Motherboard Logo
177 people viewed this question
Top Mercury Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
vsri9
Computer Links
Are you a Mercury Computer and Internet Expert? Answer questions, earn points and help others
