Question about Hotpoint Washing Machines
Please tell me how I can set my Hotpoint Aquarious model number WMAQB. 741G UK for a quick clothes wash.i have single items requiring specific temperature settings.
Please tell me how I set my washing machine to wash quickly and not for over 2 hours. Thank you,
SOURCE: Problem with Bosch built-in Dishwasher Model SHU6806UC
I had the same problem and just today replaced the control board module. Purchased the control module online and installed in myself. Was not that difficult. undo the screws (torx screw driver needed) unhook the connections to the board and label all. Pull the board out and open, found burned connectors. Now works like a dream.
Posted on May 30, 2008
ngfam1
  • 639 Answers
SOURCE: Hotpoint WMA31 Washing machine will not spin
Dear friend,
ngfam at you service!
You can not fix this problem your self!!!
This sounds like it will only fixed by service then you will be happy again!!
Yes sounds like you need service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
PS. PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
Posted on Aug 26, 2008
SOURCE: beko AA class washing machine 1000rpm WMA 510W
you put it on a 40 degree on the other side on the top left hand side i had the same problem for ages i couldnt help but laugh when i seen this
Posted on Jan 19, 2009
  • 53 Answers
SOURCE: error code F-05 for hotpoint aquarious washing
your pump/filter/outlet hose is blocked. clean it all out with the power off.
Posted on Oct 30, 2009
  • 1382 Answers
SOURCE: Door will not open
Remove the top cover, and release the door catch from inside the washer, you will probably need a screwdriver or similar to do do this.You will need to replace the door catch and spring, and possibly the door lock, as it may break when you force the door open.
Thank you !!
Posted on Jun 28, 2010
Hotpoint aquarious 1200, not completing a washing cycle
where does it come to a stop
five mins in to progam or at rinse
Jan 13, 2014 | Washing Machines
Hotpoint Ultima WMD942K
Could be a blockage in the sump, small item of clothing (sock etc) stopping the pressure switch activating. The pressure switch itself could be faulty or the hose between the pressure switch and pressure chamber could be broken, causing air to escape and therefore the switch not being activated to switch of valve. Most Hotpoint machine come with 5 years parts cover.check out linkhttp://www.hotpointservice.co.uk/hs/pages/content.do?keys=REGISTER_YOUR_APPLIANCE:PAGE.
Nov 26, 2011 | Hotpoint Washing Machines
Hotpoint Aquarious WF210. Machine stops mid cycle...Reduce Creases and Time Saver lights flashing. On-off flashing quickly. Any suggestions ?
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} For Hotpoint, Creda and Indesit error code definitions use this link. This will give you some idea as to where the fault may be.
Mar 06, 2010 | Hotpoint Aquarius WF210 Front Load Washer
Aquarious wd63 washing getting grey stains at end of wash cycle
Hi.
Can you tell me? Does the washing machine sound noisier than normal in spin? Does it sound rough?
The grey marks could be drum bearing wear causing oil from the bearing to enter the washing machine. Sometimes you may see grey or black dots on your clothing.
If this is the case then repair cost is typically around £100 depending on where you live.
Hope this helps
Aardvark Repairs
Nov 18, 2009 | Hotpoint Aquarius WD63 Front Load...
REQUIRE A COPY OF THE A MANUAL
In your browser bar, type in
HOTPOINT.CO.UK
Click on -----------After sales
Click on------------Download instruction books
Enter model number details in box.
Please rate my solution.
Thanks.
Nov 17, 2009 | Washing Machines
Operating instructions
Hello.
I can help you with your query.
In your browser bar type in hotpoint user manuals
In the drop down list, click on
manuals-user guides-handbooks-hotpoint service
In the search box enter your model number and download the instructions.
Please rate my fixya solution.
Thankyou
Jan 29, 2009 | Hotpoint Aquarius WF220 Front Load Washer
Clothes still wet after fast spin cycle
Belt loose or motor / motor control board possibly defective
Sep 13, 2017 | Hotpoint Aquarius WF000 Front Load Washer
Aquarius 1000 rpm WMA30
One... use this option for...
Washing a single item of clothing, for example, one pair of jeans.
This option will reduce water consumption and washing time.
Note:You can reduce the amount of detergent you use with this wash.
Do not use the ‘One’ option with a full or a half load.
http://www.hotpointservice.co.uk/hs/pages/manual/
try this link for a manual
Aug 20, 2008 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint aquarious washer/dryer, no manual can you help?
I have seen somewhere on the FIXYA pages where you can request a manual, suggest you have a trawl around the site. Do you have a specific problem I can help with?
Oct 24, 2007 | Hotpoint Aquarius WD640 Front Load...
Washing Machines Logo
20 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
