Question about Velocity Tablets & eReaders
How can I unlock an 5linx velocity tablet. it has no volume button on its surface
3 Suggested Answers
Fixitman909
  • 430 Answers
SOURCE: how do i unlock my velocity 2 tablet its waiting
for security reasons u need to contact the manufacturer.. could be stolen
Posted on Aug 08, 2014
mike0862
  • 5674 Answers
SOURCE: how do I unlock pattern for android tablet
Factory reset!
Posted on Feb 07, 2015
Returning tablet. How do I erase everything and restore factory reset???
hi Deanna.
this is all i could find.
  1. Power off your Tablet.
  2. Press and hold Volume up and Power button at the same time until you boot into the Android system recovery. ...
  3. Choose Wipe data/Factory Reset with your volume keys and then press the power button to confirm.
More items...
Perform a factory reset on Android Device - VisiHow
visihow.com/Perform_a_factory_reset_on_Android_Device
How do you reset a Windows tablet?Reset from within WindowsPlug in your Surface so you don't run out of power during the refresh.Swipe in from the right edge of the screen, and select Settings > Change PC settings.Select Update and recovery > Recovery.Under Remove everything and reinstall Windows, select Get started > Next.More items...Refresh or reset Surface RT or Surface 2 - Microsoft Supporthttps://support.microsoft.com/en-us/help/.../surface-refresh-or-reset-surface-rt-or-surface...Search for: How do you reset a Windows tablet?
How do you do a hard reset on a Samsung tablet?Method 1: From StartupWith the device off, press and hold the "Volume Up", "Home", and "Power" buttons.Release the buttons when you see the recovery screen and the Samsung logo.Use the volume buttons to navigate the menu and select "wipe data / factory reset". ...On the next screen, press "Volume Up" to continue.Samsung Galaxy Tab 4: Steps For Hard Reset - Technipageshttps://www.technipages.com/galaxy-tab-4-hard-resetSearch for: How do you do a hard reset on a Samsung tablet?
How do you restore a Galaxy tablet to factory settings?In fact, consider finding support before you start the following process:Start the Settings app, found in the Apps Menu.Choose Privacy.Choose Factory Data Reset.Touch the Reset Tablet button.Touch the Erase Everything button to confirm. All the information you've set or stored on the Samsung Galaxy Tab is purged.How to Reset the Samsung Galaxy Tab to Factory Settings - dummieswww.dummies.com/...galaxy.../how-to-reset-the-samsung-galaxy-tab-to-factory-settings/Search for: How do you restore a Galaxy tablet to factory settings?
if none of the above work go to this link might help you out more.
tablet factory reset Google Search
Nov 22, 2017 | Tablets & eReaders
How to Reset the Velocity Cruz Tablet?
A.) With the device powered off, press and hold the volume up button (keep holding), then press and hold the power button at the same time. Keep holding both buttons. The Cruz logo will appear, you may then release the buttons. Then the Android robot and software package icons will appear on the screen.
B.) The moment you see the Android robot, you will need to access the System Recovery menu by pressing and holding the Power button, then tap the volume up button once, releasing both. This is in the opposite order of the sequence in Step A.
NOTE: The volume up button on the T408 is toward the power button, while the volume up button on the T410 is away from the power button.
C.)
In the System Recovery menu, use the volume toggle to navigate up and down through the menu and hightlight your selection. Use the power button to activate your selection. Select the option that corresponds to clearing cache and data. Once completed, select the option to reboot your device.
Oct 17, 2016 | Android Tablets & eReaders
I can't unlock my DOPO DP8856K TABLET
Not sure about Dopo but my Surface tablet has this problem at times and the solution is to press the start button at the same time as holding down the volume button. Hold for 10 seconds. Sounds weird but may be worth a try.
Feb 07, 2015 | Tablets & eReaders
I CANT REMEMBER MY PATTERN LOCK ON MY MICRO CRUZ VELOCITY READER I HAVE PUT IN WRONG PATTERN 40 TIMES N ITS STILL NOTHING.. HELP ME SOMEBODY PLEASE N THANK U
Hi, you will have to factory reset! Follow these instructions:
C.) In the System Recovery menu, use the volume toggle to navigate up and down through the menu and hightlight your selection. Use the power button to activate your selection. Select the option that corresponds to clearing cache and data. Once completed, select the option to reboot your device.
Jan 25, 2015 | Velocity Tablets & eReaders
Tesoar tablet freezing on tesoar screen
Try this:
First, turn your tablet off. Then, power the tablet back up by holding down the volume (either + or - ) and power buttons simultaneously. Continue holding the volume button until the screen says "Booting tablet in recovery mode." This will give you a picture of an Android. Tap the android, and you will be given a screen with several options. Move between the options with the + and -, and select with the power button. Go to the option for Factory Data Reset and select it. Scroll down to `the Yes, and then the tablet will erase its memory back to factory settings. Once it has completed, select Reboot Tablet Normally.
May 17, 2014 | Velocity Micro Cruz Reader R101 Tablet PC
Pattern unlock
If you can't remember the unlock pattern you will need to do a factory reset:
  • Power device off.
  • Press and hold down Up Volume and Power Key for 10 seconds and release after seeing the Cruz logo.
  • You will then be brought to the Recovery System screen with a Android robot and an alert triangle on the background
  • Press the Up Volume Key and the Power Key at the same time once (don't hold them down) then the recovery selections will show up.
  • With the Volume keys scroll and select Wipe data/Factory Reset and make your selection with the Power key
  • With the Volume Keys scroll and select Yes to confirm the action and make your selection with the Power Key
  • Select Reboot system now.
Oct 19, 2013 | Velocity Micro Cruz Reader R101 Tablet PC
How do I do a hard reset on the Cruz T301 Tablet?
Hi.
Press reset hole button using a paperclip, then hold down volume + button until 'Cruz' appears on display. That will reset the tablet.
Apr 29, 2011 | Velocity Micro Cruz Reader R101 Tablet PC
Tablets & eReaders Logo
48 people viewed this question
Top Velocity Tablets & eReaders Experts
General Systems...
ray gallant
 Mikey
Mikey
Are you a Velocity Tablet and eReader Expert? Answer questions, earn points and help others
