Question about GE (PSS26MSRSS) Side by Side Refrigerator
Fridge and freezer running too warm
I have a GE model number gss20IE and my fridge temp. is at 60 and is turned up all the way and my ice cubes are starting to melt in freezer. I put my hand in between the slot in the middle of fridge and freezer and it was shut. Whats wrong with my fridge? Please help!! Thank you!
  • GE Master
  • 4,654 Answers
You will need to unplug the refrigerator and remove the back panel inside the freezer. Check for ice or a frozen over evaporator coil. If frozen defrost and we will need to examine the defrost heater at the bottom of the evaporator. It may have a glass tube covering the heater element inside. I want you to check to see if it is burned out. The part number for the defrost heater is WR51X10042
You please let me know what you find. If the element is burned out I recommend you replace it and the defrost thermostat part number WR50X10068
You and order the parts by clicking the link below and entering the part number into the part number search feature and click FIND IT. Let me know what you find, Sea Breeze
PART NUMBER AND MODEL SEARCH FEATURE
Here is a photo of the defrost heater.
WR51X10055 Defrost Heater
WR55X10656 Mother Control Board
It is possible that there problems with you mother control board. Need to unplug and examine both sides for burn marks. 5731be3.jpg
If you need help feel free to let me know, Thanks Sea Breeze
appliancepartsse@yahoo.com
Posted on Jul 30, 2009
Sometimes ice melts in ice maker. Water drips down and refreezes.
There is a heater built into the ice maker bottom to help release ice cubes from the machine. Under normal conditions the heater only come on when the ice maker starts to run and then jambs against the frozen cubes. When it stalls and jambs against the frozen ice cubes, the heater comes on to melt the cubes enough. I think you have a defective ice maker and the heater is coming on to much or at the wrong time, Since your temps go back to normal with the ice maker turned off, I am almost sure thats your problem.
Mar 16, 2015 | GE Profile PSC25MSWSS Stainless Steel...
Why do freezer coils ice up on my Stainless Steel Whirlpool refrigerator (model GB2SHDXTS)?
On your model your cntrl board has a relay that can stick causing the compressor to always run even when the unit is turned off or in defrost. turn the fridge off, move the temp of the freezer to it's warmest setting and it should display a line in the freezer and fridge temp display. listen to hear if the compressor is running in back of the unit. if it is you need part number: 12868513
Mar 15, 2013 | Whirlpool Refrigerators
My ge side by side refrig freezer gets on the auto defrost cycle in the freezer and then all the ice cubes in the ice maker freeze into a solid ball of ice. The ice maker does not work after that. Why does...
The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can't flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad, it can prevent the heater from coming on OR it won't turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass(disconnect the two wires plugged into it and twist them together) the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
Nov 02, 2010 | GE Refrigerators
GE TBX21ji Refridgerator/Freezer Factory Icemaker quit making ice
Normally, when the temp of the icemaker gets to about 14 degrees F, the icemaker goes into the harvest mode, turning on the mold heater and attempting to eject the cubes. When the heater has warmed the mold sufficiently to release the cubes, the ejector can continue and push out the cubes, then the icemaker fills with fresh water to beging to make a batch of ice again. Manually starting the cycle as you have done only allows the cycle to start without the temp sensor seeing the 14 degrees. The mold heating generally takes a couple minutes. If your mold heater or the temp sensor are not working, you will have to replace the icemaker, as they are not available as a repair parts.
Jul 04, 2009 | Freezers
GE TFX26KRDA WW 2001 side by side refrig/freezer w warm fridge
Cleaned the condenser coils which were dusty but not severely so. Checked the evaporator coils which were NOT iced. Reset the fridge to coldest setting and freezer to #5 (mid range of temperature) and waited a full 36 hours. Fridge temp is 40 F and freezer is about 0F. Not sure what is different except coldest setting on fridge. Warm weather is here but not warm enough to require AC. Temps in late afternoon in house about 77-80F. Any thoughts are appreciated because I suspect this problem is not completely resolved.
Jun 20, 2009 | GE Hotpoint Top-Freezer Refrigerator
Not cold enough. ice on back of freezer but not making cubes
sounds like you might have a deforst problem or your drain is blocked not allowing the water to drain when the fridge goes into defrost.
Apr 24, 2009 | Freezers
Fridge will not pull down to proper temp
check and srr if you have frost build up in freezer
Apr 03, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
GE side by side - upper freezer warming once a week then freezing
Had the same problem. Bottom of freezer was about the right temp but the upper part was way too warm. Fridge side was fine. Ice maker stopped making ice - it wasn't broken, but it won't run through its cycle if the temp is too high. Cubes already in storage hopper melted and water refroze as it ran to lower, colder part of fridge. Problem: Fan controller for freezer compartment was faulty. The fan itself was fine. Fix: GE replaced the main circuit board that controls everything on this model, including the freezer compartment fan. Once that was done, temp returned to normal, ice maker is happy again. The board had undergone several revisions from the factory installed one (could tell this by comparing the part number on the old and new boards - they increment it when they revise it.) Bad news: the part/labor were expensive and of course failed after the warranty ran out. Good news: the board is now guaranteed for 5 yrs. (Why wouldn't the factory-installed board ALSO be good for five years instead of just one? It's not like the replacement boards are made better.) Labor is covered only for 90 days though so it won't be free if they have to come back after that.
Mar 03, 2009 | GE Profile PSW26P Stainless Steel Side by...
GE Fridge/Freezer Having to turn temp up just to keep it cold
That's a typical sign of the defrost cycle not working and ice is building up on the coils. That prevents proper air flow of cold air around the compartments. As ice builds up you get less air flow and things warm up soooo you turn up the cold which causes more ice to build up and even less air flow soooo you turn up the cold. See where I'm going with this? You'll have to check your defrost timer, defrost t-stat and even the heat element. Look in your owners manual or online for diagrams of where the parts are located on your older unit, then go from there.
Dec 30, 2006 | GE GTH18KBR Top Freezer Refrigerator
GE (PSS26MSRSS) Side by Side Refrigerator Logo
290 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
