SOURCE: Kenwood DDX 7017 bypass code
During code request mode:
Point the remote control to the screen and input this numbers (from the remote control) as faster as you can 55222277
You will not see any change on the screen until you enter the last number.
This will clear the code
If you make a mistake,just reset the unit and start from the top.
Thank you for rating
SOURCE: I can't put my nokia 6300 into restore factory settings mode..
The defaulkt security code for Nokia is 12345. You can reset the security code using : *#7328748263373738#. It works on most nokia phones. Worth giving a try.
And if the phone says simcard rejected, then the most common problem is that the phone probably might have been locked. You can get it unlocked for 5 quids in your local market.
SOURCE: iphone 8G forgotten password to unlock phone
The only way to bypass it is to put it into recovery mode. You can do this by turning it off and then holding the home button down then plugging it into the computer with itunes. The one you sync with. The phone will be in recovery mode, start iTunes and then you will be prompted to restore your phone. If you need further assistance, please ask.
SOURCE: need to reset password for verifone omni 3740
If you press the F2 and F4 buttons and enter 1 Alpha Alpha 66831 and the terminal goes back to the idle screen then the system password has been changed or the battery is bad in the unit and will have to be replaced. Either way it will have to go to a repair facility to be corrected.
SOURCE: I cant restore my nokia 3120 classic to factory settings
If the default code 12345 isn't working anymore, please check out here..
Nokia mobile Codes and tips
Good luck.
Thanks for using FixYa.
