In most front loaders the element it accessable from the back with the back cover removed there will be a nut between two connectors with wires plugged on them.Remove the nut & oval shape washer & with a bit of force pull & riggle the element out.You will see that when the nut is tightend it sqeezes a rubber block sealing & holding the element in position.Hope this helps.Cheers.
get this problem with our very mature 9 yr old machine quite regularly. The answer is relatively simple: You will need a narrow thin bladed straight-head screw driver, your partners toothbrush a bowl of warm water and a dry absorbant rag.
Ok! have you got all that ready? Great!
First remove the soap/softner dispenser drawer from the machine, by pulling forward to the stop, press firmly down on the thumb indentation at the rear of the liquid softner compartment, whilst continuing to pull the drawer to the front. The draw should now slide completely away from the machine and end up in your hand, no you have not done some irrepairable damage so stop panicking.
Place the drawer in the kitchen sink along with last nights dishes for cleaning later.
Now return to the machine and bend down so you can see the water dispenser plate on the roof of the drawer housing.
At this time you may want to bring your dry rag into play, and wipe away any grime (yuk) that you see.
Done that? Great! Now if you look again, closely at the roof of the draw compartment you may notice a groove, and that there are several plastic lips or knotches holding a section of the roof compartment in place.
Now this is the interesting part, because you have to use the thin bladed straight screw driver to wedge inbetween the groove and unclip the roof compartment from the holding knotches. You can be quite firm as the plastic is quite pliable and is not prone to break, however, if you are built like Geoff Capes I take no responsibility.
You should be able to detach the complete upper housing, bearing in mind the roof housing covers not only the softner compartment but all compartments.
Ok that should be done about now and the roof compartment complete with blocked holes should be detached from the machine and in your hand. I know you are thinking "Oh my gosh, what have done, call the engineer, why did I follow that guys instructions'. But once again don't panic, just take the section you have now broken oops sorry detached masterfully to the sink and give it a good clean with your partners toothbrush and some detergent.
Finally, clean the water jet spouts in the machine that you have uncovered with your warm water, toothbrush and dry with your rag.
re-assembly is the reverse of dis-assembly (said in true Haynes Manual tradition)
However, ensure you clip/snap the now very clean roof section back into place securely, and you are done.
Oh! I almost forgot wash the dishes and the drawer and replace.
Was this helpful?
Yes
No
Popular Solutions for Bosch Classixx WFO 2466 Front
There is water dripping on to the floor from the bottom left hand corner, what are the probable...
(More)
There is water dripping on to the floor from the bottom left hand corner, what are the probable causes and solutions to correct the leak? ie removing sides or front panels etc
bosch washing machine , black gunk in my soap drawer and i have to clean it once a month and its...
(More)
bosch washing machine , black gunk in my soap drawer and i have to clean it once a month and its getting annoying, also its starting to get on the clothes if i forget. have been told this is an issue with bosch washing machines. if so is this something bosch should sort out?
bosch maxx washing machine will drain and fill but not spin. also recently clothes are left with...
(More)
BOSCH Maxx washing machine will drain and fill but not spin. Also recently clothes are left with sludge on them. Have put on several cycles with cleaning agent.
For the very first wash, and following the instructions; -- Instead of putting 1 litre of water in...
(More)
For the very first wash, and following the instructions; -- Instead of putting 1 litre of water in the soap dispenser I put it in the washing macine barrel and soap suds are coming out of dispenser and the front of the machine - we paused it and put it to off, then tried rinse - -- BUT now the door won't open at all Thanks very much
