Question about IBM Computers & Internet
Think pad 2656, after I put password bois appears then it does not start to have normal screen, that is the screen to work with
  • 390 Answers
If i am right to understand then the system starts on the secondary screen attached to the laptop and not on the LCD for this go to bios settings and select primary diplay as onboard AGP instead of the PCI and the system will start on the LCD panel on the Laptop..
once in Windows OS, also check to see that there are a couple of Fn key combinations where you can set the monitor/screen you can work with and this is a toggle key so you can select the output monitor to work with
if there is any other clarification that you would require, then you may add a comment to the same post or you can mail me at
mail2pvs@gmail.com
Posted on Jul 30, 2009
    Scholar:
  • 143 Answers
You seem to forgot your bios password. To reset password to bios you have to take off little battery approximetely 7 minutes and it will reset. But it is hard o reach in notebook PC. It need disassamble of it.
I tried to turn off my fingerprint security from acer travelmate 7730 laptop and now it started ask bios password. I dont know the password(never set it) three times wrong and system disabled and numb
hello try to connect the Acer support or search on Google for bios password. A lot of computer the come with a same bois password that company put on it. For example your Model is Acer may be the Company put Acer password for it . Even if you remove the bois battery from the motherboard and you see same thing again i think you will have to take it to Acer Branch the only help it their. i tried to find the password for you put can't find it. Please rate my comment thanks
Nov 21, 2011 | Acer Computers & Internet
My car was in the shop to get my starter fix when i got my car back i turn on my deck it ask me for my password i put a password 3 time i think its was the wrong password now my deck is lock how could i go...
It appears that that when your car was in the shop to do what ever work, they disconnected the battery, then of course now, that you tried to put in password, after the third time it locked. So, what I would try is disconnecting battery, and maybe that will bring you back to the #key pad. As far as the right password, you would have to contact the manufacturer of your deck, or maybe place like CAR TOYS, they might have a code they know to override yours to reset a new password. I hope this helped you, Mike
Sep 08, 2011 | GPS
Bios password lost
Dear there are three pwd pin on motherboard first you set configration mode 12 then you start you system go into bois setup there is option clear password.click it.f10 save and exit. after doing this now put normal mode pin setting.
now your passward is broken.
enjoy your laptop.
thanks irshad
May 24, 2009 | Acer Aspire 5100 Notebook
Intel mother board d845epi
reset you bois, open the case, remove the battery, make sure the cmos jumper is set to clr cmos, the start up the pc, putt it off, then on again, then remove the power, put on to remove all power, the replace the battery, and the jumper, then the power cord then power on again
push delete or f2 to go into the bois setup screen then select save, and exit
Jan 28, 2009 | Intel D845EPI (INTELKD845EPILPAK10)...
Toshiba agency password
Reset cmos. Remove yje cmos battery from the motherboard for about 5 seconds, replace and reboot. This should reset all passwords. Hope this helps.
Dec 22, 2008 | Toshiba Satellite P25-S507 Notebook
My windows will not open
Seems like you need to re-install Windows or use System Restore. Look in documentation how to do this, or post again for help.
Oct 25, 2008 | HP Pavilion dv4000 Notebook
Toshiba A215 Password Removal
I had the same problem and could not find the pictures either. I still figured it out, so here are more detailed instructions. Please use a combination of the previous instructions and mine. This worked for my computer, but I can't guarantee success everytime since I have only done it once. Just do the best you can.
-Pull off the memory cover on the back of your computer.
-Now, take out any memory cards that are present.
-Look at the circuit board under where the memory was. You should see a rectangular black plastic sticker.
-Pull the sticker up.
-Look VERY closely at the circuit board under where the sticker was. You should find two soldering points close together that are labled with "B500."
-Now put one memory card in the slot that is furthest from the circuit board. DO NOT put a memory card into the inner-most slot at this time.
-Carefully hold a very small straight screwdriver over these two points and turn the power on to your computer.
-The Toshiba boot up screen will appear.
-Continue holding the screwdriver over the two points until the Toshiba screen goes away.
-When the screen goes away, pull away the screwdriver.
-Turn the computer off.
-Put the black plastic sticker back in place on the circuit board.
-Put all memory cards back in the memory slots.
-Put the memory cover back on the laptop case.
-Turn the computer on.
At this point I was asked to start windows normally or start using repair wizard. Normally did not work. So start windows using the repair option. It took about 10 minuts for windows to finally open normally.
100% success in my case! Please be careful when doing this repair because I do not know what damage could be done if you do it wrong. But, after 2 months of not using my laptop, it is finally back in operating condition!
Thanks
Aug 18, 2008 | Computers & Internet
Bois setting
try to return it original setting of the clock.you over clocked it so it seems the monitor cant handle it.but somehow i dont think changing the clock would affect the monitor coz its two separte hardware.
but the important thing to do is return the normal clock setting okey.
god bless
May 30, 2008 | ASUS P4B266 Motherboard
Computers & Internet Logo
42 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
