Question about Kelvinator Refrigerators
Why is my Kelvinator 400 twin air no frost fridge leaking water under veg compartment
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 16 Answers
Good morning Barbara, from what you are describing it sounds like the evaporator drain is clogged. You need to empty the freezer and remove any access panels to get to the drain. Get a bowl of hot water and a turkey baster,then use the baster to force the water into the drain to clear the blockage. Not real familiar with that model,so check under the vegetable compartment to see if the drain is under it first. Hope that helps.
Posted on Jan 03, 2018
  • 833 Answers
SOURCE: fridge and freezer will not cool down
69....hard to know from here. What heats up and becomes quite humid? Newly restarted refrigerators take about 12-24 hours to cool down. They should be opened very infrequently during that period, if possible.. Do you hear the compressor and fans? Have you properly set the cooling controls?
Posted on Dec 21, 2007
  • 958 Answers
SOURCE: Candy frost free fridge freezer
you can decrease the setting of your thermostat for a start.
tnx 4 using fixya,
drcool
Posted on Sep 07, 2008
rpbuice
  • 161 Answers
SOURCE: fridge collecting water inside
The drain is clogged.
If you want to DIY then here it goes:
Some models have access to the drain by an elbow on the outside back of the Ref. Disconnect the drain line here and if you find the clog, great. If there is no visible drain line and elbow on the outside then...
Hopefully you can access the drain in the back top center of the fridge. This will require removing plastic covers, usually a few screws is all you have to deal with. You must get everything removed so you can see the drain hole in the back wall then you can use a tube and a little air pressure to clear the drain from that point down. If this is clear and you don't find any cloggs from that point down then the clog is at the top of the drain which is in the freezer.
This is going to require a little more work.
1. Take everything out of the freezer, put it in a cooler or just pile it in the sink.
2. Take the icemaker out.
3. Take out the back panel so you can see the cooling coils.
4. The drain hole is in the center directly under these coils but may not be visible because of ice in the drain pan.
5. Use a hair dryer to melt this ice and clear the drain so water flows down.
Posted on Dec 20, 2008
  • 121 Answers
SOURCE: my no frost is leaking water from under the
You have a clogged drain tube in the freezer . here is how to repairit. take off the ice maker if it has one. then remove the 1/4 ince screws in the back. the whole back panel will come off.depending on the ice build up you might have to defrost the unit. if you would like to easily fix it just unplugg the unit and let it defrost. defrosting will unfreeze the line. this will sovle you problem for a while but it will happen again.
Posted on Oct 20, 2009
localwonder
  • 6784 Answers
SOURCE: kelvinator frost free fridge leaking, pooling
Your refrigerator has a drain that leads to the exterior drain pan beneath the refrigerator. Occasionally this drain can become clogged resulting in standing water inside your refrigerator. A similar drain exists in the freezer, which when clogged results in ice build up on the floor of the freezer.
The drain is located either on the floor of the refrigerator, beneath the vegetable crisper, or in the wall behind a drain funnel.
Clear the drain by forcing a solution of water and bleach or water and baking soda into it with a basting syringe. If the solution will not flow through, slide a length of ¼ inch flexible tubing into the drain tube to push the clog through to the drain pan. Remove the tubing after clearing the clog.
NOTE-(This may be a leveling issue as well)
It is important for the refrigerator to be level. If it is not level, doors may not open or close properly and may not seal tightly. Also, drainage from the defrost cycle might be impaired as might the ice making cycle. The appliance was engineered based on it being installed in a level position. While there may be some tolerance for out-of-level installation, the appliance will operate at its best when properly leveled.
Place a level on top of the refrigerator near the front. Do not put it on the door because the door may not be aligned with the refrigerator case. Check that the refrigerator is level from side to side. Next turn the level to check that it is level from front to back.
If it is not level, adjust one or more of the adjustable leveling feet until it is level. The feet are bolts that can be turned to raise or lower the refrigerator. If they cannot be adjusted with your fingers, use a crescent wrench or pliers.
If you have an ice-maker, it should also be checked for level after first leveling the refrigerator. An ice-maker that is out of level will spill water into the ice bin or into the freezer. It can be repositioned by loosening the mounting screws, adjusting it for level and then re-tightening the screws.
Posted on Jan 06, 2010
Testimonial: "Thankyou so much for such a quick reply to an Australian, can't ask for better service! I will try your suggestions which make perfect sense."
How do I stop food freezing in the main part of my Kelvinator Twin air no frost 500 series refrigerator
there is a dial inside the refrigerator side to turn the temp up or down . rotate the dial to a lower number for warmer
Aug 31, 2016 | Kelvinator Refrigerators
Mw Daewoo fridge freezer FRS-20321BE is leaking water copiously from the refrigerator I cannot see any source for this but puddles form and flow internally under the veg box. Help!
All depends on how much water is collecting. A lot of water indicated a leak from the ice maker. A small amount and it's probably a clogged condensate drain. Here's a YouTube video on a different brand showing a clogged drain, your may be similar (or not), but it might give you an idea as to where to look. Refrigerator dripping water inside FIX
Mar 07, 2016 | Daewoo Refrigerators
Water leaking with icing formation below veg tray. can see flow of water from middle section of the refrigerator,water flowing out of the refrigirator.Model no-RT60KZRIH1
Frost free fridges will periodically allow frost build up to melt and run down the back of the fridge to a small hole which leads the water out and on to the compressor behind the fridge. The water is then evaporated by the heat of the compressor. The hole can get blocked and this leads to the water overflowing and running down to the bottom of the fridge. Clean out the drainage hole regularly.
Jan 30, 2015 | Refrigerators
Water in veg crisper freezing
You have a white cover in the back of your fridge it says twin cool on it. Behind that cover is a drain for your defrost cover that is probably frozen and water is leaking through that cover. Wrap a piece of copper wire around the heater and fish it down the drain and it
will fix the problem
May 09, 2014 | Samsung RF265AA Bottom Freezer French Door...
Kelvinator fridge compressor running constantly, but freezer section barely freezing
CHECK THE CONDENSER COILS UNDER THE UNIT. THEY PROBABLY ARE DIRTY AND CANT REJECT THE HEAT.
Oct 18, 2012 | Kelvinator Refrigerators
Magic chef frost free refrigerator leaking water down the rear appears to be coming from the freezer compartment water puddles under veg. bin and then out onto the floor do not see a drain hole in...
Generally you have to remove the back panel of the freezer. There you will find the freezer coil and fan. the defrost water drips off the coil during defrost and gravity flows down thru the drain. Hole should be in center of unit. Those drains plug up. clear drain.and make sure panels go back on correctly
Jun 25, 2011 | Refrigerators
I have a Kelvinator Opal Fridge/Freezer. The freezer is working fine but the food compartment wont cool. It used to run too cool and freeze stuff on the top shelf. The fridge seals are fine, the fan runs...
The vent from the freezer to the fridge can be blocked with frost and is preventing the flow of cool air to the fridge.
This can happen if there is frost build up due to failure of the auto defrost timer.
So please check on the fan section , remove panel and see if there is frost or block, if so check the timer Heater and the thermostat.
Jan 24, 2011 | Refrigerators
Water gathering at bottom of fridge.
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Aug 25, 2009 | Samsung RB215LASH
Fridge and freezer will not cool down
Dec 21, 2007 | KitchenAid Superba Architect KSCS25INSS...
Refrigerators Logo
Top Kelvinator Refrigerators Experts
Charles T Nevin
Charles T Nevin
Melissa Martin
Melissa Martin
Are you a Kelvinator Refrigerator Expert? Answer questions, earn points and help others
