Fitted new carbon brushes to motor. When looking at the old brushes the man said has the motor flashed over what did he mean. Asko 10625
  • prestocar Aug 05, 2009
    thanks for your reply,motor has no burnt odour at all and the commutator was very clean,I polished the surface with 400,s wet & dry made sure all gaps were clear.
    The machine has relays clicking but no action from the motor 99% but sometimes it will make as if to start momenteraly. Just once the motor ran normally but not since.
    I am trying spin settings 5 & 8 the pump runs to empty and I can find no restrictions in the pipes
  • prestocar Aug 07, 2009
    thanks very much ,I shall give it a try and let you know. most impressed with your comments.
    best regards
  • 86 Answers
He means you would see considerable burning on the commutators where the brushes rub Or burnt windings on the motor.Usually changing of the brushes will fix it .Hope this helps Cheers.
Posted on Jul 30, 2009
  • stefan santuccione Aug 07, 2009
    You can check the relays with a 9 volt battery on the coil of the relay and your meter on the switch contacts(ohmsx1).They may be burn,t away because of the current drain .Also check the field winds for continuity.Hope this helps.
I bought a pride wrangler mobility scooter. Did not move could hear a click coming from left motor. took right motor off and tore it down. It was all glazed over.
If two 24v batteries are the standard fitment it isn't likely it would be fitted with a 36v motor - unless some bright person fitted the wrong one...
I am not sure what you mean by "glazed over" unless it is the commutator you refer to? A commutator made from quality materials and fitted with brushes made from the correct grade of carbon or copper/carbon and being run at approx. the correct voltage is likely to become well polished and may become carbon black in colour but that is without detriment.
It is permissible to clean the commutator. I find spinning the armature in a drill and using a fine emery cloth is adequate.
Once reassembled the motor can be connected directly to 24 volts for testing.
Nov 06, 2016 | Pride Health & Beauty
Tip
Washing machine motor issues with brushes and carbon dust read this if your...
due to carbon dust build up around the drum motor in most washers that have non linear motor that have carbon brushes
you can get a state of error i call a ghost error
as its just due to the build up of carbon powder around the motor its connector and stator coils {speed pickup}
as the brushes deplete you end up with a pile of it building up between the brush contact and the motor housing leading to electricity leaking to earth of the motor metals
so a stiff dry new paint brush and give the motor a good brush around to remove the conduction path the dust creates
this effects the low voltage sensors in the motor like its speed control etc
leading to the mcu controller board miss diag the motor as bad and you get a E or F motor error
also this can and will trip your homes MCB detector and ECLD mains power switch
as i say its a ghost error and easily solved
any engineer worth his salt when fitting new brushes or even looking at this fault
will do this first to try to clear the fault if the brushes are aok
before he condems the controller board ... as bad
a new set of brushes should be part of a service you should carry out
much like an mot when its outside its warrenty period
and brushing out the old dust
should be done anyway when new brushes are fitted when needed
or there condition checked as still ok
basically brushes should be about at least 3/4 " long for a life left of about a year
and have enough preasure on the armature to ensure good current flow too it via the stator
if you have motor F or E fault conditions or a machine that trips your mains on spin etc
this prob needs done anyway
a set of brushes it cheep and a brush is also cheep
so give it a good brush out
then reset the machine
you power off at the mains
you hold in a button or two
you power on at the mains
ive read some machine need the program switch to be placed and then dialed like a safe to reset the main board from some types of motor fault
caused by carbon dust build up typical candy auto washers.. and others
they make it hard to make people money
on Dec 04, 2014 | Washing Machines
Error E30 flashing on washing machine
What brand. Ih it is a hotpoint. I found this on the net from a washer help site in the uk
Error 30 (on Hotpoint) just means the motor isn't working. Several things, including the power module, can cause this. The most common cause though is worn carbon brushes. There is also a 7.5 amp fuse on or near the power module, which can blow. This fuse is on the motor circuit to protect the circuitry of the power module. If it blows, then the motor won't work and you will get error 30.
If it has blown, it's likely to be caused by the motor. I had one last week where the armature in the motor had shorted to earth which blew the 7.5 Amp fuse.
To check the brushes, with the machine unplugged! Have a look at my Hotpoint and Creda carbon brushes diagnostics You can also Buy Hotpoint & Creda carbon brushes
Jul 18, 2014 | Washing Machines
Mercedes heater blower motor e220 comes on and off when it likes and will not select speeds
Check that the fuse is not loose but I suspect that the carbon brushes on the motor have worn or more likely have become ineffective. You may also notice that the fan engages when you turn in one direction but disengages again when you turn in the other. The motor moves slightly on its bearings due to weight transfer and the armature touches the corresponding brushes. You will need to get the motor out to overhaul it and this often means removing the windscreen wiper motor assembly first. The kitchen table on plenty of newspaper is great place to over-haul electric motors; the paper is to keep the mess down and the wife happy. With the motor out strip out the brushes. If they look to have plenty of carbon on them (5mm+) check out the pressure springs that press them to the motor armature. Carbon black and oxide build up can often render the springs action useless causing the the brushes to become fixed in their galleries. Clean everything, armature facings and brush galleries, with an old tooth brush or some such (my wife's old mascara brush works a treat) and lubricate with a squirt of WD40. With everything clean and lubricated reassemble the motor and it should run like new and for a long time.
Feb 16, 2010 | 2001 Mercedes-Benz E-Class
My wasmachine (asko 10625) doesn't spin at all Not
either motor winding is failed or motor brushes or no power to motor. needs to be tested with a multimeter
Jan 31, 2010 | Asko T711 Electric Dryer
Asko 10625 will not spin
it is probably the belt, take off the back of the machine and look at the black rubber belt that spins the cleaning drum. The belts break after about 5 years, you can get a replacement belt at you local Asko dealer, I recall that is was pretty easy to change, like doing a bike chain, Talk to you Asko dealer about how to change it.
Mar 29, 2009 | Asko Washing Machines
W640T2 (CIRCIUT BOARD)
I am a technician for Asko in Australia.The blackness on the motor control unit(circuit board) is probably carbon dust from the carbon brushes in electric motor.Likely problem is motor brushes have totally worn the armiture in motor or the MCU needs replacing due to earth leakage or short.Purchasing the parts from Asko should be no problem, but if you purchase and install electrical componenents only to find problem unresolved, you can't return installed parts for a refund. Also the breather hose from the detergent dispensor to outer tank can leak from tank connection when spinning load , and result in water running down outer tank and onto the electric motor causing circuit breaker to trip.....possibly damaging motor too. Goodluck!!
Sep 13, 2008 | Asko W6461 Front Load Washer
Asko 12003 washing machine- just replaced brushes as it was not spinining well (growling) They were well worn. I ahve fitted the new ones,washed well but was slow spinning and then began to smell. I have...
if you've replace the brushes, and smells... are you sure you got the correct brushes. If too close, especially if there were already some bad windings... could have physically caught some. Burning smell very bad in DC motor. The internal windings could be melting, which means the end of that motor. I would either look for another motor if you're so inclined... or new washer time. However in looking at the model you reference, it would seem you got a very good run out of that unit. If you can afford it, it might be time to say goodbye to the old friend and move on. Sorry, I hope I'm wrong! Good luck
Nov 07, 2017 | Asko Washing Machines
Do i need to do anything special when replacing the brushes in a lamb ametek 117500 motor? It looks like I can just remove the old brushes and insert the new ones. Is it this simple? Will the motor work...
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=758676
Generic problem for all Vacuums
Do I need to do
Posted by edkraynak on Jul 08, 2008
Do I need to do anything special when replacing the brushes in a lamb ametek 117500 motor? It looks like I can just remove the old brushes and insert the new ones. Is it this simple? Will the motor work again? Thanks
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Make sure they are the right carbon brushes for your particular lamb motor and once you have installed the new ones then there is a seating chalk that you place against the armature to help seat the carbon brushes, you can pick up the seating chalk @ your local vacuum cleaner store or contact Lamb / Ametek listed below. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.ametek.com/contact/index.cfm
Customer Service – 610-647-2121
AMETEK Corporate Office
37 N. Valley Road, Building 4
P.O. Box 1764
Paoli, PA 19301 U.S.A.
Tel: 610-647-2121 Fax: 215-323-9337
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 08, 2008 | Vacuums
Washing Machines Logo
160 people viewed this question
Top Washing Machines Experts
