Question about Refrigerators
I want to put back the selfs but the fridge does not close when I put them back why
    New Friend:
  • 81 Answers
Even though it may look like you have them in the right place , you do not! every thing must be JUST right for it to all go together to let the door close. try it again.hope this helps!
Posted on Jan 03, 2018
Bosch fridge with freezer on top, when closing fridge door freezer door pops open and does not shut by its self, what adjustments can be made?
The front of the unit needs to be raised so that there is a slight slope from front to back. This can be accomplished by turning the front leveling legs counter clockwise.
Jan 31, 2015 | Bosch Refrigerators
GE profile fridge making loud humming noise
The door being open so long caused warm moist air to collect and freeze inside the unit.
Take everything out, unplug it and let it thaw out for an entire day. All the frost will thaw, and probably run water all over the place so put towels down.
When you plug it back it, it should work fine.
Jul 26, 2014 | Refrigerators
My amana bottom freeze refridgerator door in opening a little when the top door is closed. do i need to adjust the screws or is it something with the seal?
raise the front legs so the machine is tilted back a little,this will help the top door close easier,also most likely you have nothing heavy on the door itself,all a fridge does is move air,the evaporator coil gets cold and the evap. fan blows cold air from the freezer into the fridge side and the air keeps circulating,when you shut the top door it's pushing the air down into the freezer and popping the door open,like i said raise the front legs a little and put stuff on the freezer door so it has some wieght to it and it won't pop open.hope this helps salde
Jul 24, 2012 | Refrigerators
Door not closing
Check there is nothing inside the fridge stopping the door closing. Check the hinges are aligned ok and the door closes without springing back open. If there is a self closing mechanism the pin may have come out of the top of the spring.
Apr 22, 2012 | Hotpoint HSS25GFP Side by Side...
The freezer door opens if the refrigerator door is closed hard
this is quite normal on a lot of fridges ! if it isnt closing again by its self you need to re-level the fridge and have it very slightly backwards . alternatively the fridge is not level side to side !. open the main door a third to halfway open and let it go, it should close under its own weight, if not adjust up on the hinged side leg or down on the opposite side , if the front legs are not not adjustable pull it out and adjust the back legs , a quick fix, is to chock up the front leg and all will be ok ,regards terry ps, clean the seals and the fridge where the seals make contact the seals probably do not need replacing unless the fridge is very very old. a lot of people replace seals when its not needed. regs terry
May 17, 2011 | Frigidaire Refrigerators
I have a new 4 door Samsung Refrigerator. Is there a way to level the fridge from front to back? The fridge slopes back 1" from the bottom to the top. The delivery people said it was tilted back so...
the front supports are threaded to allow for the adjustment and levelling
while you want the appearance to be in line with everything else, the next complaint will be that it is not cooling properly or the door will not close properly
unfortunately fridges do not come with a self closing door and people are forgetful and that is why it is best to have a slight slope to compensate for forgetful people and yes it is good old cheap gravity
Aug 06, 2017 | Samsung RF265AA Bottom Freezer French Door...
My side by side fridge door does not close by itself when released
It is likely that your fridge is tilted left or right, and possibly forward at the same time. Most refrigerator doors will self-close if the fridge is slightly tilted both back and to the handle. The fridge is raised or lowered by adjusting the front feet or rollers.
The problem you'll encounter with a side-by-side fridge is that if you adjust for the right-hand door to self-close, there's a good chance that the left-hand door will want to stay or fully open; if you don't check it while making the adjustments. It can take a little extra time to make sure the adjustments make the front both perfectly level left to right, AND slightly higher in the front than the back.
Please rate this reply if you found it helpful - good luck!
Aug 03, 2010 | Refrigerators
The door won't stay closed the refrigerator seems to be level and nothing is in the way of the door. Does it pay to replace the stripping around the door
no... raise the front of fridg a very little untill door will stay closed all fridgs are a little higher in the front that way when the kids don't close it properly it will close by it self........
Jul 29, 2009 | Refrigerators
Fridge door pops back open
The seal on your door may not be sealing properly, when you close the door the seal helps create a vacuum which keeps your door closed firmly, you might need to replace the door seal, you could also try leveling your fridge by putting shimmys underneath the feet, you might also want to check to make sure there is nothing sticking out of your fridge such as drawers or food racks that may keep the door from closing all the way. good luck.
Mar 16, 2009 | Refrigerators
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
