Question about Hotpoint Ultima WF860 Front Load Washer
ERROR CODE F-07
I HAVE A WT741 WASHING MACHINE , HEATER RELAY STUCH?
  • 73 Answers
Error code f 07 mid cycle?!?
You do not state your machine or model. The error code F07 that I have states that the Central Control Unit has detected a short in the Motor Control Unit.
Check the wire harness between the Drive Motor and the MCU and between the MCU and the CCU.
Check the MCU.
Check the Drive Motor.
Check the entire wire harness.
Replace any defective parts.
Apr 26, 2011 | Washing Machines
Hotpoint wt741 fault code f08
You need to check all the connections to the pressure switch the heater and the module as generally speaking it is due to a bad connection, you shoul not need to disconnect anything.
Hope this helps.
Jan 16, 2010 | Washing Machines
F03 error message on Hotpoint WT741
Error F03 indicates that the wash thermistor is open or short circuit.
Check the thermistor, heater and connections.
Hope this jelps.
Jan 09, 2010 | Washing Machines
Hotpoint WD860 - Fault Code F-07
F07 indicates heater relay stuck.
You need to check the heater to see if it is faulty, and fit new one if it is.
Please rate my solution.
Thanks.
Jul 10, 2009 | Hotpoint Ultima WF860 Front Load Washer
Error code 07 on my Aqualtis AQXXF
Might be a bit complex but this is your problem and solution
REMEMBER TURN THE POWER OFF
F07: Heater relay stuck or element open circuit
This fault is only signalled when pressure switch is in empty position.
Check the efficiency of edge connector J3 on module.
Check wiring to heater and continuity of element (25 ohms approximately).
Check the efficiency of pressure switch connections and correct operation of pressure switch,
and the pressure chamber is not blocked with sludge.
Remove edge connector J3 and check wiring and contacts at positions 2, 3 and 4 on J3.
If all above OK replace pressure switch, module or eeprom as required.
Jun 10, 2009 | Washing Machines
Fault codes
Fault F07 indicates the heater relay is stuck, this could be due to a faulty heater, you need to test it to be sure, if heater o/k, then main pcb could be faulty.
Please rate my suggested solution.
Thanks.
Feb 19, 2009 | Washing Machines
Wf860 message f-07
Unfortunately, the heater relay is not a replaceable part, as it is part of the main PCB, and these are not repairable, f
Jan 26, 2009 | Hotpoint Ultima WF860 Front Load Washer
Error message f-01 on hotpoint ultima wt741 washing machine
F01 is a motor faulty normally caused by the module,but sometimes thewiring to the motor plug that works loose as its to tight,give them alla good wiggle make sure there all in!
check this link for other error codes of hotpoint machines
http://www.hotpointservice.co.uk/hs/pages/content.do?keys=FAQ:ERROR_CODES
Dec 15, 2008 | Hotpoint Ultima WD72 Front Load...
Hotpoint Ultima WF860 Front Load Washer Logo
233 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
