Question about Refrigerators
The temp.control panel for my select chill pantry drawer keeps blinking.
  • 90 Answers
SOURCE: the letters hrs are blinking on the temp control panel
Unplug for 3 minutes. Plug back in see what happens.
Posted on Jan 05, 2008
  • 531 Answers
SOURCE: Food in Chef's Pantry drawer freezes, even on warmest setting
check the cold control or the door is not closing proper
Posted on Apr 01, 2009
SOURCE: control panel blinking
my heater did the same, very frustrating. i have solved this problem.  i took off the plastic cover to expose the electronic circuit board and noticed that there was a white residue on the board. I wiped this clean with rubbing alcohol and put everything back. as of 3 weeks ago i have used the heater frequently as normal and not had any problems. chazdee
Posted on Apr 19, 2009
robmattie
SOURCE: GE French Door Frig control panel blinking temp #s
I had a very similar problem with our GE refrigerator. The main control board looked to be the culprit. I took out the board and did a visual inspection. Upon inspection I discovered that the (2) 470 micro farad capacitors were blown. I checked the power diode near these and it was still ok. I went to Radio Shack and picked up two 470 micro farad - 35V capacitors for and grand total of $2.60 and resoldered them myself. The refrigerator has been running great since. If you want to know more details email me and I will be happy to let you know what I know. I didn't want to pay $100 for a GE guy to replace a board either!
Posted on Aug 10, 2009
woodchuck789
  • 4070 Answers
SOURCE: I have a samsung side by side fridge, and the
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
The chill drawers are probably staying cold because there is a vent to the freezer in the wall for the cold air to seep through.
Posted on Nov 03, 2009
I have a Samsung side by side refrigerator Model No: RS21DCSV. The water and ice dispenser are working. However, the water is no longer chilled?
Water is stored in a tube bundle located behind the crisper drawers (bottom, back of the refrigerator) and is chilled to the temp of the refrigerator (perhaps 40 degrees F). This tubing holds approx. 16-32 ounces (less than a liter) and incoming water pushes the chilled water to the dispenser, but also begins to warm the output water temps.
The only way to get colder water is the set the refrigerator to a lower temperature. But be careful that the temps are not so low as to cause other food items to freeze.
Sep 30, 2016 | Samsung Refrigerators
Can't get rf266abpn cool select pantry drawer back in
There may be guide rails on the underside of the shelf above.
Apr 25, 2016 | Refrigerators
Cool Select Pantry, to relocate per manual instructions, doesn't slide all the way in.
Cool select Pantry
To remove the pantry - Pull the pantry out to full extension. Tilt up the front side of pantry and pull straight out.
To relocate the pantry - Push the rails to the back of the Refrigerator. Place the drawer onto the rails and slide the pantry back until it is in place.
before install they ask to push the rails to the back of the refrigerator
should be no problem
Jul 29, 2014 | Samsung RFG297AARS Bottom Freezer French...
Ice build up under 'pantry' drawer.
Please offer me some information so that I may help, like the manufacturer, model number and how old it is.
Jan 14, 2013 | Refrigerators
The climate control drawers keep running and switching from thaw to chill and we cannot get the climate control drawer to turn off
scroll down and look into the other responses,. there may be some similar one to yours where you will find a better answer than I can give you now.
Best regards,
Ck
Dec 03, 2011 | GE Refrigerators
Can't find temp control food is getting freezer burn
I clicked on the below links to find your manual.
http://www.samsung.com/us/support/owners/product/RFG297AARS/XAA
http://www.samsung.com/us/support/downloads/RFG297AARS/XAA
There are 2 links for manuals on the 2nd link above
(13.53 mb english and spanish) with file name DA68-01820A_v1.3.pdf)
http://downloadcenter.samsung.com/content/UM/201104/20110428084005272/DA68-01820A_v1.3.pdf
The first one is the quick guide (pretty much useless)
Electronic control from outside of Pantry Cover (Left side)
Adjustable temperature control ((around 41F(5C):Deli /around 38F(3C) : Fresh / around 34F(1C) Chilled) Temperature control from outside of the Pantry : user friendly design helps keep foods fresh for longer.
If adjusting the temp to a wamer temp does not correct the problem you may have an air damper or thermistor problem. You must allow 8 - 12 hours between temp changes to know what the stabilized adjusted temp result is.
Thanks for choosing FixYa,
Kelly
Aug 25, 2011 | Samsung RFG297AARS (285 cu ft) Bottom...
I have a samsung side by side fridge, and the fridge side is not staying cool, but the chill drawers are keeping the right temp??? The Model# is RS267LABP
Nov 03, 2009 | Coffee Makers & Espresso Machines
Samsung RFG297AA Thin Film of Ice Forming Under Deli Drawer
My be an air leak,wipe/check all seals on doors and make sure doors are closing tight on seals.
Jul 24, 2017 | Samsung RF265AA Bottom Freezer French Door...
Refrigerators Logo
69 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
