Question about Sewing Machines
Cannot get the tension to work correctly. The lower thread stays loose no matter what tension setting I put it on. Can you help?
  • Sewing Machines Master
  • 1,388 Answers
Please TRY the solution BEFORE giving your considered rating.
Specific detail on bobbin case adjustment (with picture) near halfway down reply, the remainder will help you achieve a balance of top and bottom tensions.
Ensure that all is clean and free of lint and jams, this is the most likely cause....now for tension troubleshooting .......
This solution is for tension problems...if you cannot form any sort of stitch, the issue is quite different, so please let me know if you need a different problem solved.....
It is quite long, but just work through each section in order.
The "knotting up" can reveal a lot. If you have loose threads on one side or the other, the tension on the opposite side will be the culprit.
QUICK SUMMARY FIRST:
Ensure sharp new needle,
Thread guides and Bobbin are Clean & Clear of lint
Set Top Tesion to 4 ....then....
Balance Bobbin to suit.
TOP THREAD TENSION:
If the looping threads are on the underside as you sew, it is the top tension. Top tension ought to be between 4 & 6 (this variation to allow for the different weights of fabric in your projects).
IS YOUR NEEDLE SHARP ?
If you are using a needle that has seen quite a deal of work, or you suspect it may be blunt, change it for a new one !
TOP TENSION & GUIDES:
Make sure that when you thread the machine the presser foot is up so the thread goes between the discs and not to one side, top tension between 4 and 6, and that you have threaded through all the guides, including the last one, usually on the needle arm, just above the needle clamp.
It may be there is lint trapped between the discs, this will keep them slightly apart and reduce the actual tension, sometimes dramatically.
If tensions appear correct, and the thread is definitely in the channel between the discs, but still too loose and looping, try raising presser foot and remove your thread.
Now, with a 2" (50mm) wide strip piece of fabric 8 - 10" (20 - 25cm) moistened with methylated or denatured spirit, gently insert the fabric strip and clean between the discs with a see saw / to and fro action.
In the worst cases, gentle use of a needle to pick & remove the jam may be necessary, but be very gentle and make sure the tension is set at Zero and the presser foot is raised, (to disengage tension plates).... do not gouge or score the plates, they need a polished surface to work correctly.
BOBBIN TENSION:
Far less common, but if the loose threads are on the top, it is bobbin tension that is loose, it too may have lint in the spring and be giving a "false" tension.
I would not recommend fiddling with bobbin tension without good reason, it may end up with missing small screws and spring pieces, however, you can take the needle plate off to clean
the hook race area (where bobbin case sits)
...this is just good housekeeping, my wife does this every time she replaces the bobbin....
just take it out and clean the bobbin case and the fixed metal hook race with a small brush to remove lint. If there is a significant amount of lint, use a vacuum and small brush to get the worst.
Then wipe all this area with a cloth or cotton bud (Q tip) moistened (not soaked) with methylated spirit, especially if there appears to be fine dirty deposits....oil and lint combine to conspire against you.
If it seems likely that you ......really ....do .....actually .....need .....to adjust the bobbin case, first check there is no lint trapped in the metal spring where the thread is tensioned.
TOP LOADER:
Drop-in Bobbin case will look similar to this image with the tension screw in the middle of the metalwork....
cannot get the tension to work correctly. The - 4c76dc1.jpg ...the other screw at one end is holding it all together, so beware....it is not a tragedy to undo the whole lot and clean it, but very gingerly and lay the bits out in sequence and orientation, or you risk tearing your hair out !
FRONT LOADER:
....this is a bobbin case from a front loading machine and works in a very similar fashion to the top loader with drop in bobbin, again, if you dismantle it, take care so you can put it all
back properly.
165ca5c.jpg FINISHING UP
GETTING THE BALANCE RIGHT:
When you are certain there's no trapped lint in top tension or bobbin, set the top tension to 4 and the bobbin tension to a point where you just begin to feel resistance.
Try using good quality thread of contrasting colours so you can more easily spot the changes.
Set your zigzag to one width less than maximum (eg. 5 of 6 ...or... 4 of 5 etc) and sew a sample for a few inches and check the result.... adjust the bobbin tension screw very little at
a time, perhaps 1/16 of a turn.
You may find you are playing with this balance for some little while and if you are putting the needleplate on and off each time begin to think it cannot be correct to do this.....BUT....it is,
and eventually, you do get a "feel" for the correct tension and then it happens quite quickly.....as a user you won't be doing it very often unless there is lint built up (or are there small hands at work around the house !?!?!)
OTHER ISSUES:
If you live near the ocean as we do, salt air can play havoc with metalwork inside and out, so to help minimise this, keep a few small packets of dessicant (silica gel) in your machine
case....no case ? then make some sort of cover !
Same applies in any damp or humid environment, keep your machine dry and dust free.
Budget for a proper full service every couple of years (more often if heavily used) and if you don't use your machine for a few years, be aware that old oil will dry out and combining with
dust and form a "clag" like glue (another reason for some sort of cover, even a teatowel !)
FINALLY, A WORD ON THREAD:
If it is worth spending the time, energy and money on making something that you would like to give lasting enjoyment......use quality thread, .......it may seem to cost a little more at the
time, but the results, ease of use and added longevity will be worth the extra, and as a bonus, your tension troubles may be fewer and further between, because there is a more consistent diameter with good thread, and less compensating to be done by your tension plates and less thread breaks !
.bargainbox.com.au
Posted on Aug 02, 2009
When sewing a straight stich The bottom thread is loose.
Your upper and lower thread tensions are out of balance. The upper thread tension is too high or your lower thread tension is too low. Make sure your bobbin thread is correctly routed under the tension spring. There is a small screw on the bobbin case that always you to adjust tension.
Feb 20, 2017 | Sewing Machines
When i sew a test piece of fabric on my sewing machine to check the stitching, the top thread seems fine but the bottom thread is loose and adjusting the tension doesn't seem to help
there are two thread tensioners on a machine
the first one is on the front of the machine for the top thread
the second is the small screw that holds the small flat spring under which you pull the thread after you put the bobbin in the holder
as you put the bobbin in the holder you have to pull the thread around the side until it slips into a small slot then under a retainer spring
that spring is adjustable by that small screw
the amount of tension added or released by that screw is minute so as little as 1/8 turn has a big bearing on the amount of tension of the bobbin thread so turn it just a small bit at a time until the thread tension is correct
Oct 14, 2015 | Sewing Machines
How to adjust the bobbin tension.
According to the manual, you should not need to adjust the bobbin tension (and I located other sites which stated the bobbin tension cannot be adjusted on this machine). Apparently, all the tension adjustment is accomplished through the upper thread::
"EN Thread Tension Upper thread tension Basic thread tension setting: "4". (1) To increase the tension, turn the dial to the next number up. To reduce the tension, turn the dial to the next number down. A. Normal thread tension for straight stitch sewing. B. Thread tension too loose for straight stitch sewing. Turn dial to higher number. C. Thread tension too tight for straight stitch sewing. Turn dial to lower number. D. Normal thread tension for zig zag and decorative sewing. Correct thread tension is when a small amount of the upper thread appears on the bottom side of fabric. Lower thread tension The bobbin tension has been set correctly at the factory, so you do not need to adjust it. Please note: - Proper tension setting is important for strong seams. - There is no single tension setting appropriate for all stitch functions, thread or fabric. - A balanced tension (identical stitches both top and bottom) is usually only desirable for straight stitch construction sewing. - 90% of all sewing will be between "3" and "5". - For zig zag and decorative sewing stitch functions, thread tension should generally be less than for straight stitch sewing. - For all decorative sewing you will always obtain a nicer stitch and less fabric puckering when the upper thread appears on the bottom side of your fabric. 1 A B C 22 D"
Doing further research, I found this statement on a machine review site:
"After reading reviews online from where I've bought my drop-in bobbin machines, I think many of the negative reviews are due to the bobbin thread coming up without laying across the bobbin. It can cause the stitches to look very sloppy and no amount of tension adjusting can fix the stitches."
There are several machine review sites wherein 4423 owners stated their disappointment in the 4423's performance. Some said the machine failed almost immediately and others said the machines developed problems when sewing heavy fabric.
Apr 26, 2015 | Singer 4423 Sewing Machine
I have a bernette 134 and the tread keeps breaking , the lower loop thread , no matter how I set the tension , upper or lower this thread keeps breaking , HELP
Serger thread breaks
1. Is the serger threaded correctly?
2. Is the needles inserted correctly?
3. Is one of the needles bent or damaged?
4. Is the tension adjusted too tightly?
5. Is the tension adjusted to accommodate thickness of thread being used?
6. Are you using inferior quality thread?
7. Is the thread feeding of the cone/spool freely?
8. Is the needle size correct for the type of fabric being used?
9. Are the needles being used the correct one for the serger?
10.check in the needle plate area to see if there is a burr
11. Check the looper to see if there is a burr or if it looks damaged
If all of the above suggestions don't help then the serger needs to be checked to see if there is something wrong with the loopers and also see if there is a problem with the tension.
Aug 22, 2013 | Sewing Machines
The stiches at the botton are loose,it sound good at sewing but somehow it still a real mess ,no matter how i tried all different adjustment in the control bottons..
Looping on the underside is an indication that your top thread is not under tension. So you need to check again on the top threading up and make sure the thread is seated into the tension discs. Always thread up with the pressure foot raised to open up the tension device. Make sure the thread goes into the tension device, to test, lower the pressure foot and pull on the thread downwards - it should feel firm and resist pulling. If you can't get any tension onto the top thread, then the tension device may be broken.
You should not need to adjust the bottom tension at all.
If a machine is set up correctly the top tension should only need finessing by half a number at the most.
Sep 24, 2011 | Singer 5050 Mechanical Sewing Machine
Since my needle tip broke, the stiching is loose on the underside. I have replaced the needle, rethreaded it several times, put a new bobbin in and it still has loose threading on the underside. I have...
Loose stitches on underside is a sign that the top thread is not under enough tension. So you need to check that the tension dial is set to correct setting (usually 4 or 5) and that the top thread is actually in the tension discs. Always thread up with the pressure foot raised to ensure the tension discs are wide open so the thread seats in fully.
So unthread top and rethread checking thread goes into the tension device fully. Lower pressure foot and pull on the thread after the tension device - it should feel firm.
Also check thread is lying in the take up lever correctly.
If you can't get it threaded up and feel tension on the top thread, then something is up with the top tension device.
You could try to clean the tension device, how you do this varies with different models but if you can access the discs, then turn tension to zero and 'floss" between the metal discs with a selvage edge of a clean piece of waste cotton fabric, if gunk comes out, keep cleaning. Refer to your manual if you've never cleaned the tension device out before. Remember to reset tension back to normal setting afterwards, rethread and try again.
If after trying these things, you can not feel any tension on the top thread, then the tension device may have broken and you'll need to take it for a service.
Jul 19, 2011 | Sewing Machines
Lower thread tension very loose
is the bobbin threaded correctly? the screw on the bobbin case is the point to adjust its tension.
May 27, 2010 | Brother Sewing Machines
L-344 loose stiching
You need to do a tension assembly test. Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Tension assembly test. To do this test. Pull the thread through the tension assembly and test it to make sure the tension is working correctly.
(To do this test, adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.)
If it doesn’t work this way then you probably have a piece of thread or lint stuck inside the tension discs. To remove it, turn the tension to 0 zero and raise the presser foot.Using a small screwdriver, open the space between the discs and spray with canned or compressed air. The stuff should come out. Do the tension test again to make sure you got everything and then try sewing again.
sewman7
Dec 22, 2008 | Janome L-344 Mechanical Sewing Machine
Stiching
It's very possible the bobbin is in upside down and the thread is coming out of the lower tension. Pull on the thread and the bobbin should turn counter clockwise if it is correct . If it turns clockwise, flip the bobbin over , put the thread through the lower tension and try it again. The topside stitch is loose either because the lower tension is loose(or non-existent) or the top thread is too tight.
sewman7
Jul 06, 2008 | Janome 4623 Mechanical Sewing Machine
Tension on stitches
Loose bottom stitches mean the UPPER tension has a problem. Pull the thread through the tension assembly and test it to make sure the tension is working correctly.
(To do this test, adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.) If it does not work this way( the tension stays loose) you will need to set the tension to Zero, open the discs with a small screwdriver and remove the lint or thread which is stuck in there.
Sewman7
Jul 01, 2008 | Euro-Pro 9120 Computerized Sewing Machine
Sewing Machines Logo
150 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
