Question about Nintendo NES Console
N64 wont read games properly.
When i put in a game, there's only a blank screne. help!
  • 149 Answers
There is a possibility that with a 64 being such an old system, the contacts that read the game might be corroded. You can buy a kit from Gamestop that comes with all the tools you need to clean the contacts on the cartridge and the system.
Posted on Aug 09, 2009
How do you erase memory from the memory pak
  • Plug an N64 controller into the "Player 1" port on the Nintendo 64.
  • 2 Place the N64 Controller Pack into the memory card slot on the Nintendo 64 controller.
  • 3 Insert a Nintendo 64 game into the cartridge slot on the N64.
  • 4 Hold down "Start" on the N64 controller.
  • 5 Turn the Nintendo 64 on via the "Power" switch on the device. After the console loads, the Controller Pack menu will appear on the screen.
  • 6 Release the "Start" button on the N64 controller.
  • 7 Browse through the saves listed, using the N64 controller's directional pad.
  • 8 Highlight the game you want to erase.
  • 9 Select the "Delete" option. The pages that were occupied by the game save will be erased from the Controller Pack.
  • 10 Repeat Steps 7 though 9 until you're finished erasing pages on the Controller Pak. Restart the N64 if you wish to play the game that was inserted into the device, or turn the Nintendo 64 off if you are done using the console.
  • Read more: How to Erase Pages on an N64 Controller Pack ' eHow.com http://www.ehow.com/how_6566153_erase-pages-n64-controller-pack.html#ixzz15ZouU9Pe
    Nov 17, 2010 | Nintendo 64 Console
    My N64 isn't working. I put the game in and turn the power on but just get a blank screen. What do i do?
    I would suggest checking all the leads are in properly and securely.
    You may need to tune one of your unused tv channels to play it. Just turn the N64 on (with a game in) and tune the tv until the picture comes up. If this does not work then you might want to clean up the console and games by using a can of air to clean the dust or check the leads (especially the av/aerial/component).
    Hope this helps
    Jan 28, 2010 | Nintendo 64 Console
    Cartdride wont read
    Take a can of air and blow it into the cartridge slot on the N64. Then also whatever game you decide you want to play, take a q-tip and dip it into some water, then clean the contacts on both sides of the cartridge in a sweeping motion. That will remove the dirt thats on the contacts. Then take a dry q-tip and wipe off both sides of the contacts of the cartridge.
    That should resolve it. If it doesn't, try a few more cartridges and clean them and at that point if the system still won't load the cartridges properly then the main board is bad and you would need a new system.
    Nov 26, 2009 | Nintendo 64 Console
    Nothing happens
    is it on the right input channel? either there will be input 1,2 and some times input 3 try cycling through the inputs with the n64 on by pressing the input button on your TV remote
    Aug 18, 2009 | Atlus GBA Game Shark for Nintendo 64
    When i put this one game only in my n64 console,
    You could try giving the contacts on the cartridge a clean with a cotton bud and non-solvent cleaner
    Aug 17, 2009 | Nintendo 64 Console
    Blank screen when I turn on my N64
    The blank screen is usually caused by a faulty connection.
    If you are sure all of your cables and the expansion pack are installed correctly, try removing the pack and blowing on both the expansion bay and the expansion itself to knock any loose dust out.
    If that doesn't help, check the expansion pack and then the the bay for damaged or bent pins. Check the game cart as well.
    If everything appears undamaged, you may have a broken/defective expansion. See if you can get your money back and then try to find another one from a trustworthy retailer or friend.
    Aug 09, 2009 | Nintendo 64 Console
    My n64 wont work
    Well I am currently having a similar problem with my aqua N64 console and my black N64 console. So it could be the ac adapter that could be the issue because Im having the same problem sort of with my SNES console so I brought a new ac adapter for my SNES and it works. It could be the same issue with my N64 consoles every thing looks fine on the inside so it has to be the ac adapter then. Or it might of had died on you. Video games consoles are funny at this they are fine the day before and they are not working the next day.
    Apr 25, 2009 | Nintendo 64 Console
    N64 turns on but nothing shows up on the TV
    I have the same problem and from what I've read elsewhere on the net, it seems to be easily amendable by one of two solutions.
    - You can re-tune a channel on your TV (not one of the main ones) and it will find the frequency for your N64 to run on
    - If you had a gamecube the yellow, red and white output cables that came with that are (apparently) compatible with both the N64 and SNES and that way you wont have to tune your TV.
    Unfortunately for me, I did not have a GC and my TV will not re-tune due to the button on the controller not working! Good luck.
    Feb 11, 2009 | Nintendo 64 Console
    Have a PC and i want to play N64 Games on it????
    If you want to download roms like off a website, get project 64 emulator (the best emulator out there) but i dont know how you can put the actual cartridge in there.
    Jul 15, 2008 | Ubi Soft Entertainment F1 Pole Position...
    Blank screen, please help!
    try cleaning your games, i use peroxide and a q-tip and works fine.just keep cleaning the game contacts with the peroxide on the q-tip then wipe it dry with a dry q-tip.
    Jun 17, 2008 | Nintendo 64 Console
    Nintendo NES Console Logo
    159 people viewed this question
    Top Nintendo Video Game Consoles & Games Experts
    Raj Patel
    Julian Wainwright
    Martin Murray
    Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
