Question about Dishwashers
Dishlex 500 dishwasher doesn't fill.
I tipped my dishwasher onto its side to replace the leaky inlet and outlet hoses. Now the solenoid on the inlet hose won't open at the start of the cycle. I've tested the solenoid and it's fine. The problem seems to be with the electrical signal that opens it. I suspect that, what looks like a pressure switch at the other end of the wire is getting a bogus signal from some sort of cup looking device, connected to the sump which I have inadvertantly upset by tipping the dishwasher over. I could be completely wrong. Any ideas how to fix the problem?
  • whatisitagai Aug 01, 2009
    Thankyou for your help. The cup like device that I described was not the switch but was connected to the switch by a plastic tube. By disconnecting this tube, blowing through it and also disconnecting the rubber pipe to the sump and drying all water then reconnecting everything, the dishwasher worked again.
    Thanks again for your help.
  • 86 Answers
The cup looking device shoud be a switch that turns the solonoid off if water leaks there ,Try bypassing the switch to see if it works,Also check the door switch to see if it is making,Hope this helps Cheers.
Posted on Jul 30, 2009
Starts to fill on normal cycle then stops and fast cycle light comes on
If it's like a Dishlex 300, the fast cycle light means there is a blockage in the drain line, somewhere. Check and clean your filters. Also, check your drain hose going to the sink for a blockage.
Nov 04, 2014 | Dishwashers
Water fills in the bottom even if the machine isn't on.
Check your inlet washer pressure. Chances of the inlet valve leaky. Check the solenoid valve assembly. For further assistance contact authorized service center. or Close the manual valve at the in let water hose main connection after the job is over.
May 04, 2010 | Dishwashers
Hi, My Dishlex dishwasher DX 302WB ia showing 10
check this
1)blockage in boiler tank.(cleaned)
2)water pressure is less.(check solenoid filter)
if it's programmed in timer mode within the period it must reach the water level in the tank due to this also it may happen.
Jan 06, 2010 | Electrolux Dishwashers
Water does not drain in my kenmore ultra wash iii 16779
Hi!
Thanks for using FixYa. Disconnect the power source to your dishwasher before you conduct this or any other test. Either unplug the unit from the wall outlet, or flip the appropriate breaker in the circuit breaker panel. Locate your dishwasher's water inlet valve. It should be located behind the lower kickplate panel in either the right or left corner. There will likely be two screws either on the top of the panel, or on its bottom. Remove these two screws, and then remove the kickplate. On some dishwasher models, the door has to be opened in order to gain access to, and remove the kickplate’s screws. Close the door before you remove the kickplate panel.
You will be able to identify the water inlet valve by the hoses that connect to it. There will be one hose feeding water from the house to the water valve, and another hose leading from the water valve that carries water away. Now is a good time to inspect your dishwasher's hoses, to make sure they aren't responsible for any water flow problems. Make sure the hoses are securely connected to the valve. Also check to make sure there are not kinks in the hoses. Kinks can impede the flow of water.
There will be two wires connected to the water inlet valve. If your dishwasher's water inlet valve has two solenoids, then there will be four wires. Label the wires so that you will be able to correctly reconnect them later. The wires are connected using slip-on connectors. Grasp the connectors and pull on them firmly in order to disconnect the wires from the valve's terminals. Do not pull on the wires themselves. You may want to use a pair of needle nosed pliers to help you.
Use your multi tester to test the valve for continuity. Set the device to the ohms setting x 1. Touch each of the meter's probes to a terminal. If you receive a reading of infinity, it means the valve's solenoid is faulty and the valve needs to be replaced. If your valve has two solenoids (four terminals), test the second pair of terminals in the same manner. If either pair of terminals receives a result of infinity, replace the water inlet valve.
You do not have to remove the water inlet valve from the dishwasher in order to test it. Just make sure power is not getting to your dishwasher before you conduct the test.
Interestingly enough, it is entirely possible for your water inlet valve to pass the continuity test and still need replacing. This is because sometimes the valve itself is faulty, but its solenoids are not. For instance, a leaky valve may pass the continuity test, but because it is leaking, it should be replaced anyway. The same applies to valves that are filled with debris. The debris may be what is causing the valve to not function properly. If you are unable to clean out a debris-filled water inlet valve, you will have to replace it.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Nov 09, 2009 | Kenmore Dishwashers
Not take in water
Hi!
Thanks
Rylee
Nov 09, 2009 | Dishwashers
I have a Dishlex Global 500 dishwasher (DX500lWW*b). Woke up the other night to find water all over my kitchen floor. The hot water hose connector to the hot water tap split (bursted). The dishwater was...
I found this
"Hi - answer I was given by Electrolux Help was: pull machine out from under bench onto old towel, tip GENTLY onto left hand side (your left as you face the front of the machine) after it has drained, stand up gently, put back & turn on. Apparently it is the overflow trough reading as full ('oF' Overflow). Then run through some dishwasher descaler or Finish dishwasher cleaner. Worked for me."
http://www.howtomendit.com/answers.php?id=79783
Oct 05, 2009 | Dishwashers
I have a dishlex Global 500 which runs for 3-5 minutes then displays nF
nf= not filling. check inlet vale, or fault will be with pressure switch. If you have poor water pressure, you may need to increase the fill time- insructions can be downloaded from:www.electrolux.com.au, click on "customer service", then "download manuals", then Dishwashers-semi integrated, electronic, then download Dishlex Global Part 1 and Part 2.
Information on setting fill time can be found at the back of Part 2, but Part 1 has a list of the fault codes
Aug 05, 2009 | Dishwashers
GU2700XTSB Dishwasher not filling
Here is a tip the will elaborate on your problem more, but the bottom line is that you need to replace that fill valve...
http://www.fixya.com/support/r4021363-dishwasher_trouble_no_water_entering
heatman101
Oct 26, 2008 | Whirlpool GU2700XTSB / GU2700XTSQ /...
My dishlex dishwasher overflows
The only part that physically allows water to enter a dishwasher (upon receiving power from the control) is the inlet water-valve. I would test the inlet water-valve located directly where you in-coming water line is connected to.
Shut-off power to the dishwasher and remove the 2 prong connection to the water-valve solenoid (small, black, batter size). Test the solenoid for continuity; if bad, replace the entire inlet water-valve (cost about $20)
Jun 15, 2008 | Candy 24 in. CD623 Free-standing...
Dishwasher does not fill with water
It sounds to me like the base safety float has been activated. This will cause the unit to cancel the program it is in and activate the drain pump, hence the "run" that you hear, but no water. You need to remove the lid and two side panels. If you see water inside the base, you know that the safety float switch has been activated. Remove plug from outlet and empty water from base (by tilting to left side and using sponge to syphon water) Restart unit and check where water is leaking from. Usually from a filling hose not correctly/tightly fitted; leaky inlet valve; leaky heater asembly. Hope this helps! C.
Jun 22, 2007 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Dishwashers Logo
117 people viewed this question
Top Dishwashers Experts
