Question about Garmin nuvi® 200 Car GPS Receiver
Where do I buy new maps ( memory card) for
Where do I buy new maps ( memory card) for nuvi 200. I have 2007 card
  • 162 Answers
Try this link http://www8.garmin.com/support/collection.jsp?product=010-00621-10
Posted on Jul 30, 2009
Need to know how i update the maps card for it
The latest version of Garmin Express provides the ability to install a map update directly to an SD card.
The SD card installation option will only appear when updating a compatible device that does not have sufficient internal memory for the largest allowable map region. When using the SD card installation option, critical files are loaded to the SD card so it must remain in the device after the update to ensure full functionality. For the largest size SD card a device can use, refer to: What is the largest size Secure Digital (SD) card that an automotive device can accept?
The SD card support during the map update will only function with up-to-date software. It may be necessary to update the device's software with Garmin Express prior to updating the maps. These devices do not support the SD card option:
  • Nissan 700
  • nuvi 295
  • nuvi 300 series
  • nuvi 500 series
  • nuvi 600 series
  • nuvi 800 series
  • nuvi 805 series
  • nuvi 5000
  • StreetPilot series
  • zumo 450
  • zumo 550
  • zumo 665
For devices that do not support using the SD card with the map update application, any maps that do not fit in the internal memory can be installed to the SD card manually, using these instructions:
Try the link.it may help.Under support.
Garmin United States Home
Nov 09, 2015 | GPS
Have I stored any maps? can I?
Your question makes no sense. Just buy a new micro SD Memory card either 4 or 8gb and run Garmin express
May 13, 2014 | Garmin nuvi 2455LMT 4.3" GPS Navigator...
I bought a lifetime update from Garmin a few years ago but now my nuvi 270 tells me that I don't have enough memory to install the latest maps and that I must choose only certain regions. I have an 8Gb...
The internal memory of the nuvi is full. Some maps will need to be delete before any new maps can be added. Typically, the map in the nuvi is named GMAPPROM.IMG and a map installed to an SD (or SDHC) memory card is named GMAPSUPP.IMG.
1) Remove the SD card from the memory slot
2) Connect the nuvi to the computer via USB cable.
3) Open the nuvi drive.
4) Locate and delete the GMAPPROM.IMG (or GSUPPROM.IMG) file(s). Optionally copy (instead of deleting) them to your hard drive in case there is a problem wit the new map file(s).
5) Empty the Recycle Bin.
6) Retry the map update of the nuvi.
This method will take some time to perform depending on how many map segments you are sending to the nuvi. Transferring the entire map can take over an hour. A quicker way is to send the maps to the SDHC card directly by inserting the card into a card reader. This eleminates the slow Garmin card reader from the equation and transfers are done in a fraction of the time. No maps will be on the nuvi - they will all be on the memory card instead. To update the SD or SDHC card, do this:
1) Repeat steps 1 thru 5 above. This removes the maps files from the nuvi.
2) Disconnect the nuvi from the computer.
3) Connect a card reader to the computer.
4) Insert the SD or SDHC card into the reader.
5) Locate and delete the GMAPPROM.IMG (or GSUPPROM.IMG) file(s). Optionally copy (instead of deleting) them to your hard drive in case there is a problem wit the new map file(s).
6) Update the map to the SD or SDHC card.
When either method is employed, only one map file set will result. GMAPPROM.IMG or GMAPSUPP.IMG is the name of this file set. You should ensure / change the name to GMAPPROM.IMG. Any subsequent file set added should be named GMAPSUPP.IMG.
I hope this helps & good luck! Please rate my reply - thanks.
Jun 27, 2011 | Garmin nuvi 200W GPS Receiver
Where can i download the philippines map for my garmin nuvi 255W, including street map?
You need to have your satnav registered with garmin. Log into myGarmin and click on the myMaps tab at the top of the screen. If you don't already have a map of the Philippines click on "buy more maps" and follow the prompts. If you already have a map that you just want to update you can get details of how to update it at http://www.fixya.com/support/r5628920-update_garmin_satnav_maps
You can also get details there of how to register your satnav with garmin if you haven't already done so.
Please note that if this is not an update it's unlikely that your nuvi 255W will have enough space to hold a second map. If you're not updating or replacing a map I would advise against buying it as a second map. It is possible to install a second map to a memory card but there is a risk that it may not work. Memory cards in garmin satnavs appear to be very hit and miss. Some work and others don't for no aparent reason.
May 18, 2011 | Garmin nuvi 255W GPS Receiver
How often should you update or is it more practicle to just purchase a new garmin every couple years?
If you're happy with the satnav you have it's cheaper to update. You have the option of buying a once off map update or a lifetime update. That is for the lifetime of the satnav not your life. With a lifetime update, which costs around 120 euros, you get 4 updates each year. This is the cheapest option. However the only problem with this method is that the maps get bigger each time you update and the space on your satnav stays the same. I started off with a full map of Europe and now I'm only able to store Western Europe on my garmin nuvi 760. You can use memory cards to hold some of the map but older garmin satnavs have a problem recognising the maps on memory cards. If you need the full map you might be better buying a new satnav every few years. If you only use part of the map a lifetime update might be the best option.
If you decide to go for a new satnav I would suggest that you go for one with the biggest storage space possible and then get a lifetime update or get a model that comes with lifetime updates like the 3790LMT. You can judge the storage size by the amount of maps it comes with. The 3790 model has the complete USA + Canada and Mexico or the 2370LT comes with maps of Europe and USA, lifetime traffic updates but not lifetime maps.
Apr 24, 2011 | Garmin nuvi 350 GPS Receiver
Hello how can I update my Carmin nuvi 660 and download the map of new zealand ? thank you
Details of how to update your garmin satnav are at http://www.fixya.com/support/r5628920-update_garmin_satnav_maps
To get a new map of NZ you need to have your satnav registered. Details of how to do so are at the above link also. When you're registered go to www.garmin.com
  • Click on the myGarmin tab
  • Log in using your username and password
  • Click on the myMaps tab
There you'll see the map installed on your satnav. On the left hand side of the screen you'll see in blue writing a link saying "Shop for new maps" and then on "View additional maps for this product"
Scroll down as far as the map of NZ and select it. Follow the prompts.
If the map you already have on your satnav is not NZ and you want to save that too it's unlikely that both will fit on your satnav. If this is the case follow the instructions, at the above link, under the heading If the map is too large to install on your satnav for downloading to your computer and installing from your computer to your memory card rather than the satnav. Be advised maps installed on memory cards will not always work on garmin nuvi satnavs particularly if the memory card is larger than 2 Gb. Please read the article at the link above before buying.
Feb 26, 2011 | Garmin Nuvi 660 GPS Receiver
How instal maps on sd memori card for garmin nuvi 250
Hello
Insert the memory card into the memory card slot on Garmin Nuvi 250 GPS device. The memory card slot is located on the left side of the device. Push the card in until it clicks. (If you inserted a memory card that already has pre-installed maps and files, there is no further action required. The device will access the new maps based on the address you enter.)
Connect the Garmin GPS to the computer using the USB cable. The mini-USB connector will need to be inserted into the rear of the Nuvi 250; the larger end is inserted into the computer's USB port.
Locate the computer file that you want to download to the Garmin memory card. The Nuvi 250 is capable of reading JPEG formatted images and GPX formatted Waypoints and other mapping-related files. Right-click on it. Select "Copy."
Select the "Computer" folder from the computer's desktop Start menu. Double-click on the "Removable Disk" drive that represents the Garmin Nuvi.
Right-click in an empty space within the drive and select "Paste." The files have now downloaded to the memory card and will be accessible through the Nuvi 250 menu options.
Good Luck, and do rate the solution if got help
Dec 06, 2010 | Garmin nuvi 250 GPS Receiver
Can i download maps of germany,switzerland and france onto my Garmin Nuvi 255 now that it already has australia and nz on it
You can, but...
You'll need to load the mapping onto a removable memory card, as your device's memory isn't large enough. Adding a memory card with additional maps really slows the machine down, painfully so. Buying the European mapping pack isn't cheap: you can buy a brand new satnav with full European (including UK and Eire) mapping preinstalled for about the same price. Click here for a current example, but there are cheaper ones if you abandon Garmin in favour of Medion or other brands.
It works out even cheaper if you sell the old satnav to fund the purchase of the new one. When you need the Oz/NZ mapping again you can do the same thing again as by then your original unit will probably have out of date maps anyway.
Please take a moment to rate my answer.
Jul 22, 2010 | Garmin nuvi 255W GPS Receiver
Garmin Nuvi 760 memory card
Does the Garmin Nuvi 760 require an additional memory card for normal use?
The simple answer is : no it does not need and SD card to work
Jan 26, 2009 | Garmin Nuvi 760 Handheld GPS Receiver
Garmin nuvi 610
500Mb internL MEMORY ONLY- LOAD MAPS TO SD CARD TILL 4 gB WORKING
Oct 27, 2008 | Garmin Nuvi 610 GPS Receiver
Garmin nuvi® 200 Car GPS Receiver Logo
60 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
