This site says 25Mbps. It isn't a router.
https://www.cox.com/residential/support/arris--motorola-tm502g.html
SOURCE: Wi-Fi isn't working
This could be a duplex issue. When you log into the belkin does is assign you an IP address? Have you used a ballpoint pen to reset the EMTA since you have connected the router?
SOURCE: Unable to connect VPN using Arris Modem & Comcast Router
hi, mate check firewall settings of your modem/router. Then contact your IT administrator and he should be able to make changes to configurations for you. In most cases if server classify's your connection as unsafe it rejects it.
SOURCE: i have a arris tm502g
First check all your connections. Reset your internet modem. Unplug and restart your router. Restart your computer system. If you still have a problem, reset your router. There is a small button the back that can be held in with a pin for 20 seconds.
If you stll have a problem, then ope internet explorer, go to Tools, Manage Addons and disable all the addons. Restart explorer. If this works, add each add on and retry. This should isolate the culprit.
Last scenario - you have a bad router. try connecting your computer system direct from modem to computer. If it works fine - you have a problem router - replace it.
SOURCE: i have arris tm502g modem n want to hook up 2nd pc wont work
You need a router or network switch to share the single connection from this cable modem. Wireless router if you're so inclined. Comcast is about to jack the rental rate for that modem from $3.50 to $5 on January 1, at least in Atlanta.
SOURCE: Securing wireless network connection
You need to log into the wireless router either by a computer that successfully connects wirelessly or by physically connecting with an ethernet cable. Once connected, log into the router by open a web browser (Internet Explorer, Mozilla Firefox, Google Chrome, Apple Safari), and typing the router's address (usually 192.168.1.1 or 192.168.0.1) into the Address (or URL) line. The default usernameand password is usually "admin" & "admin" or "admin" & "password". Once successfully logged in, look for a tab or link that says "Wireless" or "Security". You'll be able to change whether security is enabled or disabled, and the password associated with it. Your security options are WEP or WPA (or WPA-PSK). WPA-PSK is the most secure, but WEP is also an acceptable choice. Select the security option of your choice and either enter text into the passphrase generator or choose your own password and type it into one of the security key text fields. If you use a password that is not a plain english combination of letters and numbers, be sure to write it down so that you can enter it as needed on other wireless devices that need to access your router (ie-pda phones, game consoles, laptops, desktops, etc). Be sure to save changes so that the security settings and password is saved.
Let me know how you make out.
