Question about Tablets & eReaders
RCA viking pro 2 is stuck in fastboot mode, please help
2 Suggested Answers
rmahershalal
  • 20 Answers
SOURCE: rca tablet how do i get out of fastboot mode
You will be stuck in fastboot if you have failed to flash an img file. You will have to boot a boot.img file using fastboot then download the last update to get your tablet back to normal.
Download the following file onto your computer...
K1_A301_03_03_110829_US.zip
Then unzip on the computer. You will see a file named "boot.img". Make sure your tablet is connected to the computer and you have the fastboot binary. Then run the following command in the directory you just unzipped the file
fastboot boot boot.img
This will allow you to boot up your tablet but the bootloader will STILL be stuck in fastboot. Therefore you will have to update your system. Download the same file above into the Download directory of your tablet. Rename it to update.zip. Dowload the following XML file...
K1_A301_03_03_110829_US.xml
and rename it to update.xml (NOTE: the system file manager won't let you change the extension so just rename to "update". Power off the tablet. Then hold down the Volume + key and hold down power button until it comes on. That will boot the system into recovery and install the update. In a few minutes you will be restored and your tablet will work normally. NOTE: YOU MAY LOSE YOUR DATA and may have to reinstall your apps.
If your boot partition isn't a mess like mine was, you may be able to just flash the system partition from the above zip file by using...
fastboot flash system system.img
fastboot reboot
The key is that a fastboot flash must be successful in order for your device to boot normally.
Source: Lenovo
Posted on Nov 13, 2016
Where can I purchase a pt425080 battery for a rca tablet
Everywhere! :>)
For RCA 7 Tablet RCT6077W2 Battery PT3867103 MH49370 3.7V ...
https://www.rakuten.com/prod/for-rca-7-tablet...battery...3-7v.../274930413.html
Listed is a RCA 7 Tablet RCT6077W2 Battery PT3867103 MH49370 3.7V 2600mAh - Used. Is your battery not holding a charge anymore? Are you just looking ...
RCA RCT6378W2 Battery Replacement - iFixit
https://www.ifixit.com/Guide/RCA+RCT6378W2+Battery+Replacement/40480 RCA RCT6378W2 Battery Replacement: In this guide you will learn how to remove and replace the battery in your tablet.
Battery Tablet 7 ' eBay
www.ebay.com/bhp/battery-tablet-7 3.7V 3000 mAh Polymer Li ion Battery Lipo For GPS PDA PSP iPAQ Tablet 7" 8" ... Battery Type: Li-ion Polymer Battery. 1 x 3000mAh Li-ion Polymer Battery.
RCA 10 Viking Pro 10" RCT6303W87 Internal Battery ' eBay
www.ebay.com > ... > See more RCA 10 Viking Pro 32GB WiFi Tablet Keyboard Bl... Rating: 4 - ‎5 reviews
ITEM DESCRIPTION. Item was pulled from a working unit and is in great condition. THIS BATTERY HAS TO BE SOLDER. Please check the battery in your tablet, ...
Amazon.com: 4200mAh battery for RCA RCT6203W46 10 ...
https://www.amazon.com/4200mAh-battery-RCA-RCT6203W46.../B013HW5E94 Rating: 3.7 - ‎3 reviews
RCA PRO10 Edition RCT6203W46 10" Tablet PC Digitizer Touch Screen New ... $19.99. 3650mAh Replacement Battery for RCA RCT6272W23 7" Tablet PC ...
RCA ' How to take care of your tablet's battery
https://rcaav.com/how-to-take-care-of-your-tablets-battery/ Learn how to take care of your RCA tablet's battery with these simple and helpful tips.
Bulging batteries in RCA tablets ' KOMO
komonews.com/news/consumer/bulging-batteries-in-rca-tablets-11-21-2015 May 19, 2015 - If you have an RCA 7 inch tablet that was purchased last year- keep an eye on the internal lithium battery. There are reports of the battery ...
Jul 29, 2017 | Tablets & eReaders
Is my rca viking 10 tablet conpatble with straight talk service were is serial # @
The RCA tablets are cheap and cheerful entry level tablets. It does not have telephony capability, so you can't get a data plan with it. You can only use at home if you have wifi with a company. 'straight talk' is a cellular provider and the RCA isn't a cellphone. if you have a Straight Talk phone, you can tether the RCA to it using BlueTooth. Without that, you can use it to do anything, but if you want to access the internet, send stuff like email, or chats, you have to be on wifi.
RCA Viking Pro 10 1 2 in 1 Tablet 32GB Quad Core Walmart com
https://www.straighttalk.com/wps/portal/home
Mar 22, 2017 | Tablets & eReaders
Rca tablet how do i get out of fastboot mode
fastboot reboot
Source: Lenovo
Nov 13, 2016 | Tablets & eReaders
Why is my tablet Stuck on entering DnX mode.Waiting for fast boot command...
my next book tablet is stuck in dnx fastboot mode, it will not unlocked, and it stuck on voice command
May 12, 2016 | Nextbook Premium 8 Se Android
Tablet says, Entering DNX Mode: waiting for Fastboot command...
I would book mark these links. Below.
Copied from :
https://www.kingoapp.com/help/fastboot-mode.htm
What is Fastboot for?
While in fastboot, you can modify the file system images from a computer over a USB connection. Fastboot mode can start on your device even before Android loads, even under the circumstance when Android isn't installed at all. And because of that, fastboot mode is useful for quick-updating the firmware, without having to use a recovery mode. In fact, it's the preferred way to initially install the recovery image. Once you set up, you boot to your phone to fastboot and you can flash image files to the internal memory. Flashing a custom recovery like ClockworkMod is a popular use case. The images you flash don't need to be signed with a particular key, and thus you should use care when flashing. It can also be used for developer operations. Things like erasing partitions and overriding kernel command line options can be done. And all this features make the tool very useful for developing hardware and software solutions, like unlocking the Bootloader of Google' Nexus.
https://www.kingoapp.com/help/fastboot-mode.htm http://forums.androidcentral.com/verizon-droid-dna/252896-how-do-i-turn-off-fast-boot-mode.html
May 11, 2016 | Tablets & eReaders
WHAT DOES FASTBOOT MODE MEAN?
Fastboot is associated when you root Android. Here's a site that helps explain it better in detail: The Easiest Way to Install Android ADB and Fastboot Tools on Any OS
Hope this helps you get a better understanding of what it is.
Jan 17, 2016 | Tablets & eReaders
Lenovo Tablet a8-50 is stuck in fastboot mode..can't turn on or off
if you able to take out the battery then remove the battery and reseat the battery, it will fix the issue (hope the battery has outside access). Hope it will help.
Nov 23, 2014 | Lenovo A8 50 8" Android 16GB 1GB
I'm stuck on the fastboot mode. how to turn this off?
Its under system / developer options settings just untick the fastboot option.
May 12, 2014 | ASUS MeMO Pad HD 7
Tablets & eReaders Logo
57 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
