Question about Kenwood Audio Players & Recorders
Ka5010 amplifier dead
Unit dead. 2.5A 250V fuse blown inside unit.R88 and R62 fried. R88 is situated next to Q24.can you help
jamycor
  • 50 Answers
Possibly transistor Q24 may be faulty,replace Q24 plus the associated cmponents that have blown.
Posted on Jul 30, 2009
Can I use a 15A/32V fuse to replace a blown 15A/250V fuse
No! Unless you have read it wrong and it should be 320V. You can go higher than 250 volts but not lower. And you can go lower say to 10A and say up to 16 or 20A, though you should stay around 15A to be safe. If you do fit a 10A fuse at 250 volt and it blows straight away then it won't be the fuse that is faulty, but something inside the amp that has gone. As fitting even a 15A 250V will do the same. A 32 volt fuse in the mains section will burn out in a fraction of a second.
Dec 08, 2012 | Audio Players & Recorders
Fuse type for onkyo a-9555
The main power fuse for most amplifiers is a fast blow, 125 volt fuse for the US and a 250v fuse in countries with 220v. This unit is 125 watt so the main fuse should be 2 amps or so. The correct fuse size is written on the circuit board next to where the internal fuse was located.
Feb 23, 2012 | Onkyo A-9555 2-Channel Amplifier
Actually iSymphony M110 - it doesn't wont to turn on. Just the stand on red lamp is on and no response on any buttons. Does it has sort of reset button or it should be repaired in service center? Do you...
I just bought one of these "dead" units for $15...I replaced the blown 2A 250V fuse with a new 2A fuse and it blew as soon as I plugged it in so then I took one of the 4A 250V fuses from the other side of the unit(located right behind the speaker output terminals) and it works perfectly now.
Sep 18, 2010 | iSymphony M1 Shelf System
Brookstone Wafer-thin CD with MP3 player circuit failure...why?
sure, ur power amp section is completely shorted. meaning it is totally fried. get it repaired. it was a stupid idea to jump the fuse. u cud fry the whole thing!!! i sincerely hope it is only the power amp. if it is more than that u have only urself to blame. remember looks can be deceptive.
Apr 13, 2010 | Brookstone Wafer-Thin CD System with MP3...
No power to Crown XLS 602 Amplifier
Hi...
There may be some internal fuses on that unit.
You can open it by taking the cover off and looking for fuses and discolored parts.
It may have a thermal fuse on the power transformer which then will require service
Check the web for service people in the UK
Mar 31, 2010 | Crown XLS 602 2-Channel Amplifier
Moisture in amp while on, caused a small pop, then no sound outpu
check the fuse between the battery and the amp. (not the fuse in the back of the amp).
if that doesn't work then something on the inside of the amp is fried.
Jan 30, 2009 | Phoenix Gold Xenon-200.4 Car Audio...
MPA-101 Amplifier powers on, receives source signal, the fuse is not blown inside, but no sound comes out of the amplifier. The amp is pretty new, doesn't even have dust inside the unit.
Hello, is this a Radio Shack PA amp or Jamo amp? The unit is probably in "Protect" mode. Is this a PA system or a receiver...receivers have a protection circuit that will not let the speaker relay activate if the amplifier output section is shorted and sending voltage towards the speakers...so they won't fry!!The speaker relay should activate within 3 to 5 seconds if your output section is ok.
barneyluc
Oct 13, 2008 | Audio Players & Recorders
Fuses for P-07
the fuse you need is a t4al 250v
this is a common slow blow 250v 4amp fuse.
You can get them at RadioShack
Oct 03, 2008 | Gemini Sound Products P07 2-Channel...
I think I broke my baby...
If it's dead, it's probably a blown fuse or maybe a blown thermalcouple fuse. a bad magnatron won't make the unit apear dead unless its blowing fuses.
Hope that helps..
Geno
Mar 24, 2008 | GE JES1142SF Microwave Oven
63 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
