Question about Hotpoint Washing Machines
I have the hotpoint wma40 washing machine and it wont spin, it seems like the program gets stuck when it comes to the spin cycle
    Problem Solver:
  • 9 Answers
Its possable the pump or drain hose is blocked.Could also be the pcb (main control board
Posted on Jul 30, 2009
My washing wont spin
this sounds like you need new brushes in the motor ok
Nov 02, 2012 | Hotpoint Aquarius Wma40 Washing Machine...
Machine wot final spin and final spin light flashes
Your problem could be attributed to the electronic control board. I assume that the washer spins up until that point of the cycle.
Feb 22, 2010 | Hotpoint WMA40 Front Load Washer
Hotpoint washer
common problems with timer which work like a clock and goes though the cycle, bad timer will cause it not to go through its cycle. it very cheap and easy to replace everything is all plug in.
Nov 14, 2009 | Hotpoint WMA40 Front Load Washer
Hello i have a hotpoint wma40 the machine will go
Hi, i have a wma40s had it for 7 ears now same thing happended would start a cycle but then stop halfway through make the noise but the drum would not spin etc. i bought some carbon brushes of ebay for 7 quid and it works better than its worked in years bit nosiey for first few washes but after it settles it is as good as new.
Jul 06, 2009 | Hotpoint WMA40 Front Load Washer
My aquarius wma40 hotpoint did not/will not run a spin slow/fast
Sounds like a belt. I would proceed to take apart whatever is needed to get to the pulleys and replace the belt. Did I address your question?
May 07, 2009 | Hotpoint WMA40 Front Load Washer
Hotpoint aquarius extra wma40 wont drain
You can check the drain or the filter. You will have to pull it out of the space it is now to access it. Items will get stuck in the drain clogging it.
Apr 03, 2009 | Hotpoint WMA40 Front Load Washer
Blocked filter
This is for the WD420, but could be useful for you.
The filter is inside the machine. If you machine is still under guarantee I would try and get it done that way. Otherwise turn off the power and pull out the machine to get a the back.
Remove the panel at the bottom where the discharge hose comes out. You should see a black concertina type tube coming from the drum attached by a jubillee clip. The filter is inside. Losen the clip and pull away the tube take out the filter and clean it. When you replace it don't forget to put the ball float back in and check its well fixed by running a spin cycle before sealing up.
(courtesy pollydolly10)
Feb 23, 2009 | Hotpoint WMA40 Front Load Washer
My Hotpoint Aquarius WF210 washing machine drum is not rotating
I think the belt has come off or has been damaged.
To open the machine slide out the machine. On the back panel lower 1/3 you will see a plastic panel remove the screws and the panel will come away. Inside you will see the belt. I suspect you will need to reattach the belt of remove it and buy a replacement.
Sin é
Jan 13, 2008 | Hotpoint Aquarius WF210 Front Load Washer
Stuck in wash cycle
check if heating by putting on as hot wash and feeling the door. if no heat, check continuity thro the heater - modern heaters have a non-resettable cut-out in them which can cause problems. no heat then no program advance
May 08, 2007 | Hotpoint Aquarius WF000 Front Load Washer
Washing Machines Logo
159 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
freddyfox
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
