Question about Harman Kardon AVR 130 Receiver
No sound in hdmi mode unlock flashes on display I get sound in cd
I have a harman kardon 745, receiver worked fine for 2 years now it is in "unlock" mode but only in hdmi, when I place it in cd mode I get sound . I have checked all connections but the unit hasn't been moved, so I don't understand how it could have gotten locked and no sound while it is in hdmi. Any ideas
    Problem Solver:
  • 8 Answers
Its asking your permission to unlock the setup menu. When you hit setup, and it says "unlock," you have to hit one of the navigation arrows on the remote control. Once you have unlocked the menu, you can assign the audio to that HDMI input.
Posted on Sep 07, 2009
Avr 745 goes back in standby mode when I try to turn it on
Please see my other answers for Harman Kardon issues. If you can't find them, please respond back here.
Dec 21, 2013 | Harman Multimedia AVR 745 Receiver
No input to tv
Hi, during the last 3 years, my Harman Kardon AVR3600 has worked perfectly, but suddenly i don't know why does my unit only provide sound, and no video.
That I can do, and reset the unit, change the HDMI cable, etc... but still no video. Tkhs
Mar 19, 2013 | Harman Kardon AVR 3600
I get an unlock display when I change to vid2 input. How can I unlock the input? Thanks
I had this exact issue.
I was using the digital 2 input for sound. (Toslink cable from my cpu).
It seems I inadvertantly muted the sound on the pc, and this caused the "unlock" message with the L-R speakers flashing on the display.
I restarted my pc; and then unmuted the sound.
3 seconds later; the L-R stopped flashing and I now have sound on Vid2.
Jan 04, 2011 | Harman Kardon AVR 635 Receiver
I have a harman kardon avr 745....looks frozen
My device is AVR 645, but AVR 745 has the same power regulator board and you could check, if the problem is there.
(AVR 645 volume blue light was not pulsating)
When device is turned on, it shows all display indicators,
no blue light on volume button and no response to any remote or front panel buttons.
Reason for failure:
No 3.3V and 5VD voltages.
I checked bridge rectifier D701 on power regulator board.
One of the diodes was shorted. Also fuse F702 was blown.
Original D701 is KBU6G, but because regulator board is a bit difficult to get out, I decided to use KBU8G. The only difference is Amps rating 6A versus 8A.
Be sure to use SR-5-3.15A fuse to replace F702 and use heat sink paste (you know where) when board is reinstalled.
There is large heatsink in the middle of the receiver. Power regulator board is mounted on the right side of that heatsink. It is down there near the front panel and to get it out you most probably first have
to remove two PCBs hindering access to some regulator component screws. Here are pictures to clarify situation:
harman-kardon-avr-745-looks-frozen-igzigj2finjgh1nndvq1cugs-5-0.png harman-kardon-avr-745-looks-frozen-igzigj2finjgh1nndvq1cugs-5-1.png
Oct 26, 2009 | Harman Kardon AVR 140 Receiver
No sound,no video,front panel display will display.harman kardon
Check your audio settings on the main menu of the receiver. The audio input should be set to "auto" Next, make sure you don't have the unit in "6 channel input" mode or "direct" mode. This is usually a small button on the front panel. If you check all this and you still have a problem, post a comment and I will help you troubleshoot some more. Hope this helps
Jun 30, 2009 | Harman Kardon AVR 140 Receiver
Harman Kardon AVR 154 OSD setup screen wont display
It will only display via component. Your HDMI firmware is either 1.1 or 1.2 and has HDCP issues (High Definition Copyright Protection) it's a firmware problem that has been fixed on all new receivers, not just a HK issue, all receivers! the new version 1.3a and 1.3b have fixed the issue. Unfortunately you cannot update the firmware on the receiver. Hope this explains it for you, sorry! Lot's of angry people out there!!! myself included.
Jun 27, 2009 | Harman Kardon AVR 235 Receiver
Harman Kardon AVR325 stays in standby mode
Was a solution ever found for this? I have almost the same problem, except that mine makes a horrible sound through the speakers before it shuts off. However, after an attempt or two, mine usually starts working and sounds fine (I love how this thing sounds!). It seems to happen more when I've let it sit for a week or two. When I use it regularly, it usually works fine. It's almost like it knows when I'm about to give in and replace it... because it will start working again! Maybe I just need to make an effort to use it more....
Mar 22, 2009 | Harman Kardon AVR 325 Receiver
Harmon kardon 745 displays "unlock" no sound for tv or movies
I also had this UNLOCK message on my Harman Cardon AVR 130.
The reason for this error was - in a hurry I've plugged the optical input into optical OUT! Double check that your connections in the back are correct and hopefully it fixes your problem.
Cheers,
Sergey
Jan 11, 2009 | Harman Kardon AVR 130 Receiver
Harman Kardon AVR 130 Receiver Logo
1,034 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
