Question about Watches
Brocken braclet clasp - Watches
Solved
Posted on Jul 31, 2009
How to open clasp on hugo boss yachting timer ii watch
it has a fold out clasp , holding thumb close to the clasp pull the other side upwards this should open the clasp.
Oct 11, 2017 | Hugo Boss Watches
Clasp on ebel classic ladies watch is worn. Can it be repaired?
Yes it can be. Take it to a reputable watchmaker and they should be able to adjust your clasp. Usually what happens as a watch is worn for a few years the little brackets that lock the clasps down start to push outwards. so they are not fitting snug against the lock bar of the clasp. A watchmaker should be able to use a jeweler pliers to adjust them back to normal. costs about 15 dollars.
Jan 25, 2012 | Ebel Classic Watches
The clasp on my steel watchband pulls away from the band creating a large gap. it looks bad and catches on things. what do i do?
You need to make sure that if you had the watch band adjusted they did not adjust it at the clasp. When you adjust the watchband links should be removed if you adjust it at the clasp the band keeps pulling open. When you open the clasp fully make sure the pins are on the end holes. If the pins are in the end holes then, the clasp is probably sprung somehow and you will need a new one or have a jeweler or watch repairman fix it! You may also be able to order a new clasp from manufacturer! Hope this helps!!
Sep 21, 2011 | Watches
I bought my bulova 96R105 today, the jeweler placed it on my wrist, but now I can't undo it. Please help
It may have buttons on the sides of the clasp that you must press. If you do not see the buttons on the sides of band, it is a friction fitting, and you must pull on one or the other side of the "butterfly" clasp for it to release.
If you see a large outside clasp, there will sometimes be a fold over safety. This is called a tri-fold clasp. You must pull up the hinged clasp one direction, then the main clasp the other direction. A bi-fold clasp has no safety, and can be pulled one direction to open.
Feb 04, 2011 | Bulova Diamond Accented Calendar #96R105...
How can I remove link pins to adjust metal band from Raymond Weil ladies Tango 527462? One side of the pin has a slot head but a very small screw driver fails to turn the head. The other side has a flat...
Raymond Weil watch braclet has a screw. Twist it, and then push from the other side. You may need to buy a set of basic tool for about 10 dollars from Amazon. Good luck and enjoy your watch. Alan Anderson
Nov 09, 2010 | Raymond Weil 5360-STP-00328 Wrist Watch
Braclet has come off watch.
It is difficult to be sure what the problem is without examining the watch but it sound as if the pin spring (which which makes it telescopic) has broken.
It should be possible to get arepalcement from you local watch shop, they usually have a range standard items to fit most watches.
Jun 30, 2010 | Rolex Submariner 16618 Wristwatch
Broken clasp on watch band
The only thing you do is go to service center,maybe they have an extra clasp.Somtimes customer adjusted the size of thier bracelet and when ok they leave their udjusted clasp.That's why some service center had an extra clasp.
Jun 17, 2008 | Watches
Watch clasp on Tag Heuer
http://www.worldofwatches.com/cust/sizingwatch.asp?d=0
Apr 24, 2008 | Tag Heuer WK1111BA0317 wristwatch
Aquaswiss Trax watch band adjustment
VSNDESIGNS SAYS:
You should first try to adjust the band at the Clasp first. The clasp has three holes that you could easily move your band up or down into. If you need to remove one or more of the links, try the following.
http://www.fixya.com/support/t315141-adjust_band_aquaswiss_trax_watch
http://www.rgmarchitect.com
Feb 09, 2008 | Watches
Watches Logo
81 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
