Question about Sony KP-46WT510 46" Rear Projection HDTV
All the sudden my picture is bowed in the top left and bottom right
Corners with a reddish tint to it and also seems to have a shadow or double letters when text is displayed. Does anyone know the solution or what has happened? And how much should I expect to have it repaired or could I possibly repair myself? Thanks for any help!
    Novelist:
    Champion:
  • 244 Answers
Snowy or intermittent picture
If you have much experience in dismantle TV set maybe you can do it by yourself. You need to solder all coils in stand up board and tuner.
For best result you can bring that to the TV Repair Shop possible it will only cost less $25.00USD to fix this problem.
Hope this wil work your problem.
Posted on Nov 24, 2007
Samsung TSL2793HF - Slight Right Side Pincushion and Horz Line Bottom to Top Until the TV Warms up
Yes, this is rare but I have seen it before--not fixable if it is what I think it is----It is what is called a Dome effect---the shadow mask in the picture tube is actually contracting and or expanding depending on temperature---
Directly behind the phosphor coating (the stripes that you see on the screen) is a metal screen--the holes or perforations in it line up with the stripes on the phosphor screen.
Some masks either have a material or a defect causing the dome effect----Not likely to be anything else---a Pin amp problem will not usually act the way you describe but a shadow mask inside the picture tube will act exactly that way.
Dec 02, 2012 | Televison & Video
Shadows in top right and left hand corner of picture
If you know what you're doing - why not. Most probably something has got loose inside the lens and needs to be fixed.
May 28, 2010 | Nikon COOLPIX P80 Digital Camera
I have a Hitachi 46F500 tv and the red crt bowed
I just had the convergence replaced and have a great picture
Aug 16, 2009 | Hitachi 46F500 46" Rear Projection...
Sony kp57hw40 tv blurry image,
Yes, you have a bad convergence Ic--set uses two of them---have someone change both and adjust the set in the Tech menu--if you need more information or help email me etower.766@netzero.net---
Aug 09, 2009 | Sony KP-51WS500 51" Rear Projection...
Bottom right corner has a tint projector bulb is good
the colorwheel is collapsing and needs replacing. it's under a metal brace between the colorwheel and the lens. it's a 4-sided mirror tube that is glued together, and the glue wears out after a while.
Jun 18, 2009 | InFocus ScreenPlay 4805 Multimedia...
Pt-47wx49e convergence problem
I just replaced the 2 convergance chips, but it did not seem to fix the problem. I then tested all the resistors that feed the convergence chips anf there was a 2.2 ohm fusable blown. IT was R7050 on mine. That seemed to fix it so that I could adjust all the colors through the convergence 2 screen. There seems to be a slight bow near the bottom when you look at the c2 screen, but not noticable when you are watching a picture. Since I got this broken, I am not sure how perfect it should be.
If anyone can send me the service manual, I would appretiate it. Thanks.
Oct 10, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Projection T.V. Picture
Replace Both of your STK ICs convergence ICs STK392-110 use 150s Better ICs Call Mats 1-800-628-1118 Also RK42 RK46 RK48 RK50 RK54 RK58 RK60 will have to get back to you on resistor values
Jul 21, 2008 | Hitachi 60SX12B/13K 60" Rear Projection...
JVC AV-48WP30 tv(convergence)
This is a convergence board problem. Have a tech replace convergence IC's. The part no. starts with STK. If you are good in soldering and know how to test resistors, you can do it.
Jul 16, 2008 | JVC AV-48WP30 48" Rear Projection...
Picture is bowed down from top left corner to top right corner and bowed up from bottom left corner to botton right corner. Colors are seperated a little in corners and middle top and middle bottom.
Convergence ICs are faulty what is your model number? I can post which ICs you need and where you can get replacements that come with free instalation instructions so you can do the repair yourself
May 07, 2008 | Televison & Video
Sony KP-46WT510 46" Rear Projection HDTV Logo
70 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
