Design amplifier projects - Audio Players & Recorders
  • 73 Answers
What is the low pass filter on my amp for
A subwoofer is a low frequency device so it is designed to amplify low frequencies <200 herts to play on a speaker designed for low frequencies. You want low frequencies to pass to the amplifier while high frequencies do not enter the amplifier to cause damage to your amplifier or sub woofer speakers plus it will sound terrible. Anothher reason may be to not have to worry about a crossover filter on the speaker system..
Aug 08, 2014 | Soundstream P1.210 210W Monoblock Picasso...
Tip
Fixed amp won't turn on and click noise.
The amplifier would sometimes not turn on, when it did there was a loud click from one channel of the amplifier.
Reason.
Inside the amplifier there is a protection board that plugs into the amplifier, the design uses 3 x 25V 47uF capacitors charged up by 22K and 220K resistors.
As the amplifier ages with time, a parasitic resistance across each capacitor gets less and less, this means that the capacitor can not charge fully up and reach thresholds, in the **** design of a delay circuit. The parasitic capacitance is affected by the room temperature making the fault intermittent.
The pop sound is caused by DC offset, it was 25mV, this was nulled using a trimmer on the amp pcb to stop the click-pop sound, this offset could of damaged a loudspeaker.
on Jan 14, 2016 | Marantz PM7200 2-Channel Amplifier
Mitsubishi 72" rear projection. The convergence is misaligned and cannot be adjusted with the remote. I cover the green gun and the picture is better but the color is very bad.
Usually what happens on these is the convergence amplifier(s) go bad. This is a repair that will require removal of the main circuit board and soldering work for replacing parts. Almost every one of these has to have the convergence amps replaced but once in awhile I get by with just soldering the connections on the chips. Most repair shops should charge 200-300 dollars including parts and labor to do this repair. It's also a good idea on this model that they only remove the board to be worked on even though the chassis is designed to be removed as a whole unit. I hope this helped, Russmann.
Aug 17, 2010 | Mitsubishi WS-65807 65" Rear Projection...
Problem in RF Power Amplifier
Look in the "Radio Amateur's Handbook" and past issues of the QST magazine. There have been articles on design including schematics and circuit layout in past issues as well as the Handbook.
Here is a site for a kit for a 10 watt amp... it is for 2MHz to 30MHz, but you can add turns to the transformers to get performance at 1MHz.
http://www.kitsandparts.com/linearamp.php
There is adequate info for design at the site and parts callout and layout.
Jul 28, 2010 | Peavey Pv 2600 Power Amplifier
Color images have shadows ,multiple figures
Replace the convergence amplifiers . These are usually on large heat sins and labled with an STK designation.
Dec 20, 2009 | RCA Televison & Video
Rca r52wh74 bowed picture and 3 d color
Your convergence amplifier has failed.
There are a few things that usually cause that in that particular chassis design, the most likely one being that you have lost part of the power supply to the convergence amplifier power supply board.
You may be able to repair it yourself if you're good at soldering, and dis-assembly / re-assembly.
Look for a 400ma fuse that's opened near the FBT, and re-solder all the connections in that area. Also check to see if any diodes have shorted around it too.
Good luck.
Dec 01, 2009 | RCA Televison & Video
Colors are out of line
When A REAR PROJECTION TV has coloured outlines or a 3D image the Convergence Circuits most likely need attention.
Replacing the output amplifiers (located within the Convergence IC's) allows the pictures to line up correctly, and no more color outlines.
This is the most common fault in all makes of rear projection TVs.
Some models of TV require major disassembly and considerable shop/manufacturer's support to repair because of their design that causes other power supply or vertical deflection problems. The poorly designed products require a "bench" repair that can typically cost from $350 t0 $700.
Some TVs are designed for on-site repair and have more reliable circuit design that does not usually cause damage to other parts of the TV when convergence chips fail. The ones that usually allow reliable on-site repair are JVC, Samsung, Sony and Hitachi.
It is normal to have some resistors in the circuit burn up or increase in value from the heat (from 2.2 ohms to 5 or 10 ohms). These resistors must be replaced with the right value or the chip may fail again.
This is not a simple repair like changing batteries or a fuse. Reading through the other posts shows many that try and end up with bigger problems.
Your JVC uses STK 392-110 IC's. Misinformed people replace the IC's with other "new and improved" IC's, like STK 392-150. These are devices with different characteristics and require different value resistors in the circuit. Replacing with the STK 392-150 will cause overheating of the resistors and a damaged IC.
If you are in Calgary, I can help. If not, get someone that has experience working on your JVC. My website is below with some costs and explanation.
calgaryconvergencerepair.weebly.com/convergence-explanation.html
Good Luck,
Easyab
Jul 11, 2008 | JVC AV-56WP74 56" Rear Projection...
Jvc 65 inch I'art tv
1024x768 Normal 0 When A REAR PROJECTION TV has coloured outlines or a 3D image the Convergence Circuits most likely need attention.
Some TVs are designed for on-site repair and have more reliable circuit design that does not usually cause damage to other parts of the TV when convergence chips fail. The ones that usually allow reliable on-site repair are JVC, Samsung and Hitachi.
Good Luck,
Easyab
Jul 06, 2008 | JVC AV-56WP74 56" Rear Projection...
Jvc convergence
1024x768 Normal 0 Convergence
Good Luck,
Easyab
Jun 18, 2008 | JVC AV-56WP74 56" Rear Projection...
JVC Television
Good Luck,
Easyab
Jun 05, 2008 | JVC AV-56WP74 56" Rear Projection...
 Grubhead
Grubhead
