Question about Ricoh Office Equipment & Supplies
I need to replace the green toner lock lever/cam handle on my Ricoh copier. How do you do this?
    New Friend:
  • Ricoh Expert
  • 164 Answers
First buy handle ansd slide holder. What's has happen toner has gotten behind it that's way handle broke or won't close properly. Second there is another lever you push to slide hopper all the way out. Keep it level or you will spill toner every where. Make sure you have a towel or somethings for toner spill to put under toner hopper. Second remove metal bar and then slightly pull up tabs could be three of them be careful is a spring behind it. It will push inter cover out and can spray toner everywhere if you just let it pop out. Once this is done now can remove green handle. And reverse procure
Posted on Feb 12, 2018
SOURCE: Ricoh Aficio 1022 Toner Bleeds
I ended up taking out the toner bottle completely and just running copies (with no toner in place) until they came out crisp. This used up the toner that was floating around. I was able to make about 700 copies before I needed to put the toner back in. But a **** of paper is still much cheaper than getting a service tech.
Posted on Apr 13, 2009
  • 25 Answers
SOURCE: Meade #882 Tripod locking cam
Don't try to...buy a new unit it's cheaper...where are you from ...ALDI has a great unit for less than 15 quid... if you need help contact me and i'll organise ....
Posted on Oct 02, 2009
Copier_God
  • 57 Answers
SOURCE: ricoh 4220 copier. I replaced toner cartridge and
I suggest removing the toner, and visually inspecting it, make sure the sealing tab has been removed, give it a really good shake, as the toner may have settled in storage. re-insert the cartridge making sure it goes in the right way.
If you can hear a slight 'clicking' noise it's adding toner and pumping it into the developer unit, some machines take 2 minutes, some take 6..
Failing that, lift the platen cover and do a few black copies, so you force the machine to add toner.
Goodluck.
Posted on Oct 17, 2009
  • 1297 Answers
SOURCE: I have a problem with a Ricoh Aficio 450 copier. The toner cartridge is full, but the screen says add toner. Now the toner slide out will not close.
Clean the toner hopper section and close correctly the lever.
Posted on Jan 30, 2013
  • 20 Answers
SOURCE: Ricoh 1018d won't add toner after installing toner bottle.
if u sure of the toner u use .may there are a problem with developer unit gears it may need to replace.
Posted on Apr 28, 2014
HOT TO REPLACE THE LANIER LD 122 GREEN TONER LOCK LEVER/CAM HANDLE
Easier to replace hopper P/N B0273501, not too pricey. -Carl
Feb 10, 2015 | Lanier Office Equipment & Supplies
Says that I need to replace toner but there is plenty of toner in the cartridge.
Replace the whole toner holder assembly as the auger inside of it goes bad which causes the user to keep pulling out the toner bottle and checking it which in turn brakes the green handle
Mar 18, 2014 | Ricoh Aficio 2022 All-In-One Laser Printer
How to reset toner on Ricoh Aficio 180
If you want to reset the toner bottle, open the front cover, lift up on the green toner handle, push the lever in to slide out the toner hopper, pull out the toner bottle, give it 1 or 2 gentle shakes, and put it back in the hopper. Then push the hopper closed until it snaps into place, push the handle back down, and close the front door.
May 25, 2010 | Ricoh Aficio 180 Laser Printer
How to install new toner of Ricoh FT 4618 copier
lift release lever Green knob then pull insert toner bottle then push inside the toner, then push down the lever.
Jan 07, 2010 | Ricoh Office Equipment & Supplies
How do I install the toner cartridge?
I reproduce below the content from Ricoh official website. The instructions to install toner cartridge are as follows:
Note: You can make about 50 copies even after the char_ric09.gif Add Toner indicator begins flashing, but replace toner early to prevent poor copy quality.
Please read the following warnings and notes before attempting to add toner.
WARNING
  • Do not incinerate used toner or toner containers. Tonerdust might ignite when exposed to an open flame. Dispose of used tonercontainers in accordance with local regulations.
  • Keep toner (used or unused) and toner containers out of reach of children.
  • Iftoner or used toner is inhaled, gargle with plenty of water and moveinto a fresh air environment. Consult a doctor if necessary.
  • If toner or used toner gets into your eyes, flush immediately with large amounts of water. Consult a doctor if necessary.
  • If toner or used toner is swallowed, dilute by drinking a large amount of water. Consult a doctor if necessary.
  • Avoidgetting toner on your clothes or skin when removing a paper jam orreplacing toner. If your skin comes into contact with toner, wash theaffected area thoroughly with soap and water.
  • Iftoner gets on your clothing, wash with cold water. Hot water will setthe toner into the fabric and may make removing the stain impossible.
To replace the toner, follow these steps:
  1. Keep the device switched on and only add toner when "Toner is Almost Empty" is displayed
  2. Open the Front Cover
  3. Lift the large green handle up to its full extent
  4. Press and hold down the green lever to the left of the green handle
  5. Use the green handle to pull out the Toner Tray slightly then release the green lever
  6. Pull out the Toner Tray to its full extent
  7. Push the neck of the Toner Bottle back towards the device until you can see the top of the bottle
  8. Lift out the Toner Bottle by the neck - being careful not to scatter loose toner
  9. Dispose of the Toner Bottle in accordance with your local environmental instructions
  10. Obtain a new Toner Bottle and shake it gently from side to side at least 5 times
  11. Remove and discard the black cap and place the Toner Bottle in the tray with the neck towards you
  12. Push the neck back into the black housing of the tray
  13. Push the whole assembly back into the device until it clicks into place
  14. Push the green handle down fully and close the Front Cover
  15. The device will perform a few seconds of internal checks before it is ready for use again
Important:
  • Fault may occur if you use toner other than the recommended type.
  • When adding toner, do not turn off the operation switch. If you do, settings will be lost.
  • Always add toner when the device instructs you.
  • When a message "Add toner." is shown on the display panel, replace the toner.
  • Store the toner bottles in a cool, dry place free from direct sunlight.
  • Store on a flat surface.
  • Do not repeatedly install and remove toner bottles. This will result in toner leakage.
  • Do not shake the removed toner bottle. Remaining toner might scatter.
Aug 17, 2009 | Ricoh Aficio 1515 All-In-One Laser Printer
Apr 08, 2009 | Ricoh Aficio 2022 All-In-One Laser Printer
How do I change the waste toner bottle for a ricoh sp c410?
Drill a 3/4" hole in lower left side of waste toner bottle. Waste toner is very fine and will get all over the place – you also may want a breathing mask. Take outside and dump waste in large ziplock bag and dispose properly. Put a large piece of shipping tape and cover hole. Put back into ricoh c410. This wi;; save you about $50 and less plastic in our landfills. SG
Jan 13, 2009 | Ricoh Aficio SP C410DN Laser Printer
Waste toner disposal procedure
It's not recommended to empty this as it contains 4 colored toners and you would heve to ensure that the light sensor sees completely clear in the view area. Replace the bottle with type 155 waste toner bottle (about $25) from on line supplier. To do this is simply a matter of opening the right side cover and sliding the green lock lever to the unlock position. Then remove the bottle and replace. Don't forget to slide the green lock lever to the lock position and close the cover.
Nov 18, 2008 | Ricoh Aficio CL2000 Laser Printer
Savin Copier 3515
Hmmm.. try this
  1. Open the Front Cover
  2. Lift the large green handle up to its full extent
  3. Press and hold down the green lever to the left of the green handle
  4. Use the green handle to pull out the Toner Tray slightly then release the green lever
  5. Pull out the Toner Tray to its full extent
  6. Push the toner bottle towards the front of the black housing where the green lever is located
  7. Push the green lever down while continuing to hold the toner bottle towards it.
  8. Slide the whole assembly back into the device until it clicks into place
  9. Close the Front Cover
  10. The device should now attempt to Add Toner
  11. If the Add Toner indicator light does not go out repeat
Oct 31, 2008 | Microsoft Office 2003 Basic Edition...
85 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
