Question about Ricoh Office Equipment & Supplies
How do you install the green toner lock lever on a Ricoh 220 copier?
5 Suggested Answers
goalie39
  • 469 Answers
SOURCE: Ricoh Aficio 220 - moved copier to clean behind
Check the power cord, make sure you have not just pulled the copier end out of place. the power cords are often replacable and can pull out of the copier.
Hope this is of some help.
Ed
Posted on May 08, 2009
Copier_God
  • 57 Answers
SOURCE: ricoh 4220 copier. I replaced toner cartridge and
I suggest removing the toner, and visually inspecting it, make sure the sealing tab has been removed, give it a really good shake, as the toner may have settled in storage. re-insert the cartridge making sure it goes in the right way.
If you can hear a slight 'clicking' noise it's adding toner and pumping it into the developer unit, some machines take 2 minutes, some take 6..
Failing that, lift the platen cover and do a few black copies, so you force the machine to add toner.
Goodluck.
Posted on Oct 17, 2009
joel_baleta
  • 155 Answers
SOURCE: how to install new toner of Ricoh FT 4618 copier
lift release lever Green knob then pull insert toner bottle then push inside the toner, then push down the lever.
Posted on Feb 03, 2010
  • 1297 Answers
SOURCE: I have a problem with a Ricoh Aficio 450 copier. The toner cartridge is full, but the screen says add toner. Now the toner slide out will not close.
Clean the toner hopper section and close correctly the lever.
Posted on Jan 30, 2013
I need to replace the green toner lock lever/cam handle on my Ricoh copier. How do you do this?
First buy handle ansd slide holder. What's has happen toner has gotten behind it that's way handle broke or won't close properly. Second there is another lever you push to slide hopper all the way out. Keep it level or you will spill toner every where. Make sure you have a towel or somethings for toner spill to put under toner hopper. Second remove metal bar and then slightly pull up tabs could be three of them be careful is a spring behind it. It will push inter cover out and can spray toner everywhere if you just let it pop out. Once this is done now can remove green handle. And reverse procure
Jan 02, 2018 | Ricoh Office Equipment & Supplies
I moved my aficio 220 and now when i print i get faded results...i changed the toner but its still the same..what might be causing this..please help...
Lift the green lever as if to replace the toner cartridge, underneath you will see a narrow piece of glass. Pull it out of the machine, and clean it.
Jan 09, 2014 | Ricoh Aficio 220 Laser Printer
I just got the Ricoh VT6000 and I can not figure out how to properly load the master
as far as i remember press the green button on the right side of the machine while pushing toslide the scanner. move the green lever to up to insert the master between the two roller the rubber and the foam rollers then down the lever to lock. press the green buttom located on the right side to load the master. while loding move the green lever up down up down to balance the weight on the master to avoid skewing then down to lock. hope i help, good luck
Sep 01, 2011 | Ricoh Priport VT6000 Copier
How to reset toner on Ricoh Aficio 180
If you want to reset the toner bottle, open the front cover, lift up on the green toner handle, push the lever in to slide out the toner hopper, pull out the toner bottle, give it 1 or 2 gentle shakes, and put it back in the hopper. Then push the hopper closed until it snaps into place, push the handle back down, and close the front door.
May 25, 2010 | Ricoh Aficio 180 Laser Printer
How to install new toner of Ricoh FT 4618 copier
Jan 07, 2010 | Ricoh Office Equipment & Supplies
How do you remove drum unit
Open right cover, remove toner bottle and holder.....just continue to hold down the green lever as if to install toner while you slide the unit completely out, tilt upwards to remove it (bottle, holder and all). Be careful, there will be some (possibly a lot of loose toner). Reverse this to reinstall. Then simply squeeze both sides of the base of the Drum unit to slide the assembly out
Aug 06, 2009 | Ricoh Aficio 2015 Copier
How do I change the waste toner bottle for a ricoh sp c410?
Drill a 3/4" hole in lower left side of waste toner bottle. Waste toner is very fine and will get all over the place – you also may want a breathing mask. Take outside and dump waste in large ziplock bag and dispose properly. Put a large piece of shipping tape and cover hole. Put back into ricoh c410. This wi;; save you about $50 and less plastic in our landfills. SG
Jan 13, 2009 | Ricoh Aficio SP C410DN Laser Printer
Waste toner disposal procedure
It's not recommended to empty this as it contains 4 colored toners and you would heve to ensure that the light sensor sees completely clear in the view area. Replace the bottle with type 155 waste toner bottle (about $25) from on line supplier. To do this is simply a matter of opening the right side cover and sliding the green lock lever to the unlock position. Then remove the bottle and replace. Don't forget to slide the green lock lever to the lock position and close the cover.
Nov 18, 2008 | Ricoh Aficio CL2000 Laser Printer
How to clean lens on our ricoh CL3500N Laser printer
Toner spills can be cleaned with a cotton pad and alcohol. If excess toner appears do the following:
You should replace the PCU if prints show any of the following symptoms.
  • Colors are missing, faint, or partially blurred.
  • Toner smears appear.
  • White or color rivers appear.
  • White or colored streaks appear
    1. Important: Switch off the device and disconnect it at the mains.
    2. Open the right side cover.
    3. Pull the green levers as shown to release the inner cover.
    4. Lift the inner cover upwards.
    5. Squeeze the green lever on the black PCU.
    6. Pull the unit carefully out of the device and dispose of it in accordance with your local environmental policy.
    7. Place the new PCU on a flat surface.
    8. Peel off the tape from around the new PCU.
    9. Remove the top cover from the PCU. DO NOT remove the bottom cover at this stage.
    10. Rest the new PCU in the device as shown.
    1. Push the PCU into the device while holding the bottom cover. You will hear a click when the PCU has locked into place.
    2. Lower the inner cover.
    3. Push the two green levers as shown to secure the cover.
    4. Close the side cover.
    5. Connect the device at the mains, switch it on and wait for the self-test operation to finish.
    Please remember to rate all users who assist you for free :)
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Aug 07, 2008 | Ricoh Aficio CL3500N Laser Printer
23 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
