Question about Whirlpool GEW9250 Electric Dryer
Dryer will not spin
I have a simpson eziloader 4kg dryer I have replaced the safety switch as a clip was broken. It still wont spin, it just makes a wurring noise. Have taken the back off and checked - everything seems inplace. Where is the safety fuse located?
    President:
  • Whirlpool Master
  • 1,922 Answers
Are you sure the drum belt isn't broken,the whirring noise your hearing sounds to me like the motor is turning
Posted on Jul 30, 2009
We have put a new belt and bearing on my 4kg Simpson eziloader dryer and spring is in place it works for a while and then the belt comes off again what could the problem be
I would check the pulley on the motor, and the belt tensioner that the belt winds through. My initial thought is that when installing the belt onto the tensioner it may have been bent. GOOD LUCK FRIEND.
Nov 16, 2014 | Dryers
Hi I have a Simpson 4kg eziloader dryer that keeps tripping the power mains . Would this be the timer ?
The heating element uses the most power. Was the home wired by a licensed election ( the dryer plug)? if it was it should have #8 or #10 wire depending on the load. the breaker is sized to the wire (so don't change it). you may have a clogged vent pipe. this will reduce air flow and make the dryer work harder possibly tripping the breaker. You should probably start by making sure you vent is clear and free from debris, debris in the vent could cause a fire.
Sep 10, 2014 | Dryers
Is it an electric dryer? I had this same issue with an electric dryer and we replaced it because it was old and the new dryer did the same thing!! obviously the new dryer couldn't be the problem so I looked into the only aspect that didn't change. the fuse box and outlet. I opened the fuse box and realized that one of the positive sides of the 220 wire came loose and many electric dryers are use one side to run the motor/electronics and the other side to run the heating coil. I would advise you not to mess with your fuse box unless you are sure of what you are doing and the risks. It is best left to a trained professional.
Apr 13, 2014 | Dryers
Simpson 4kg eziloader dryer wont turn on can hear faint noise when i switch it on though
If the faint noise is the motor running, the belt is broken.
Jan 03, 2014 | Dryers
Hello My simpson Eziloader Dryer will not spin I replaced the drum belt but still not fixed, if I turn it manually and close the door really quicly it will start turning but then stops soon after. Please...
need the cap replacing,........... should ba a silver can shaped cap. sited next to the motor
. it will have 2 or 4 wires connected at the top......................
cheers
Mar 24, 2011 | Dryers
I have a simpson eziloader dryer modal 39S500 the belt broke. i need a diagram on how to replace it. I also have to replace the bearing.
Hi I have a simpson eziloader 5kg Model: 39S500. I've just replaced the drum and put it all together but I have a spring that I'm not sure where abouts it goes can anyone help thank u
Mar 15, 2010 | Dryers
How to turn on the simpson eziloader dryer
The timer is the "on" switch.
Things that can stop it starting.
Door switch- is the depresser pin contacting.
Broken main belt.
Faulty - motor- timer- door switch- belt switch ( if fitted) wireing.
Aug 29, 2009 | Dryers
Simpson Eziloader frontload washer clunks 3 times and ends
The motor controller or ECU is to blame.
Have them checked & replace as necessary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 14, 2009 | Washing Machines
Dryer won't start, Simpson Eziloader 4kg
Yes, the knobs don't like to be turned counterclockwise. Spin the knob clockwise to reinstall tightly, then move to set a dry time. Make sure half load button is pressed.
Jan 24, 2008 | Whirlpool GEW9250 Electric Dryer
Whirlpool GEW9250 Electric Dryer Logo
1,123 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
