Question about Toshiba 120GB USB 2.0 Portable External 120 GB Hard Drive
I have a Toshiba PX1399E external drive which is faulty.The red light appears as opposed to the blue light
fire sine
  • 382 Answers
SOURCE: external hard drive not registering with the computer
Sounds like the drive is physically damaged. I would extract the drive form the case, and test it. If the ports on the enclosure are faulty, theres is nothing to do about it except resolder them.......
Your youre concerned about the case and not the content on the drive, verify whether it is under warranty and return it.
Keep me posted.
Posted on Oct 29, 2007
SOURCE: Red and Blue flashing light
i just had this issue. I took a small phillips screw driver out and removed the seagate hard drive from its enclosure. I brought the hard drive to a microcenter to verify if the hard was dead or something in the case. The hard drive was fine. I purchased a $15.00 inland 2.o to IDE/ SATA adapter from microcenter. This let me use my drive as I did before. All of my data that was on the drive is still there.
Posted on Jul 03, 2008
PC Commando
  • 142 Answers
SOURCE: red and blue light alternately blinking. What can i do.
Remove the drive from the enclosure and either install it in your machine as a slave or you will need to buy a new enclosure and put the drive in it.
Posted on Sep 17, 2009
  • 32 Answers
SOURCE: My Toshiba external hard drive powers up but my
Hello there...
Looks like your HDD is having mechanical problem, this could happen due to a shock (dropped or bumped maybe?) which can cause your HDD I/O head loose from its track.
I'm sorry but my advice is prepare a HDD replacement.
hope that helps... :D
Posted on Apr 14, 2010
lock123
  • 6831 Answers
SOURCE: external hard drive blue light is not working
Hello
Okay , so there are some steps to figure out what is wrong with your external.
Firstly , if your computer makes a sound when you plug in your external , go to Start-Control Panel-Administrative Tools-Computer Management-Disk Management , and see if your external drive is listed here with your local drives. If it is listed , right click on the drive and change the drive letter to make it appear in "my computer".
If your drive does not make a connection sound when connecting to your computer and also does not show up , please follow the next step.
Remove the hard drive from the casing if possible and install it in your computer case or another external case.If the drive works , the problem is with the casing and you can ignore the drive.
Now , if the problem is with the casing , there are still 3 possibilities.
  1. The USB cable between the drive and the computer may be damaged.
  2. The circuit board which connects your drive to the interface of the external may be blown.
  3. The power supply (if applicable) may have a blown transformer.
The latter is the easiest to diagnose , does your external light up at all when you plug in the power? If not , then this is probably your problem. On the bottom of the adapter is a label which you will be able to use to have a new adapter made at your local electronics shop and this will cost about $30 max. They will also be able to test the adapter with a clamp meter to see if this is really the problem and this should be free.
The second component you want to test is the USB cable. If you have a printer , swop out the cables and see if your printer functions normally. Most externals use the same connector so you should be able to test it in this manner. If the cable works go on to the last step. If the cable is defective , replace it with a new one which you can find for about $10 at most electronics and chain stores.
The last component to test is the circuit board. This is a bit of a grey zone as you probably won't be able to spot the blown component unless it failed really badly. With the casing already opened , locate the external's circuit board and check to see if you have any blackened components or fluids leaking from some components. If all the other components of the external worked perfectly , then this is the faulty part. It is not really economical to replace the circuit as most of the time it is out of production by the time you need to replace it and it still costs a lot even if it is available so if your drive is working perfectly when connected via sata or IDE on your computer , the best is to buy a new casing and place your old drive in the new casing.
A casing costs about $50 and you could get it at most tech shops and big chain stores like Best Buy.
I hope this solves your problem and please reply if you need more help.
Kind Regards
Andrea
Posted on Sep 29, 2010
Why always the RED LIGHT?
Maybe the detection circuit for the diagnostic lights is faulty, if the disk utility found no issues I would continue using the hardware.
Jun 29, 2012 | Samsung HD502HJ Samsung 500 GIGAByTE SATA...
My Toshiba 1TB External hard drive is not recognized by both of my laptops. When I troubleshoot to find out what is the problem error code 34 appears. Before that when I try to install or update the...
are you attaching any leads to this external hard drive the leads may be faulty if windows is not recognising your external hard drive you might need to replace the leads also to check the error
click start control panel administrive tools computer management then select event viewer depending on what operating sytem you have this may vary
extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured you might be able to uninstall then reinstall some of these files/software
hope this helps
Mar 29, 2011 | Toshiba Computers & Internet
I dropped my Simpletech 250 gb external drive for several times, now when i plugged in to my pc the red light is on but the blue light is not coming out, and i cannot see the external drive in my pc, how...
Take out the hard disk from your case and put it inside a desktop- if there's still some life left in it it will appear in My Computer. If it doesn't appears even there then it's dead for sure and all the data on it is lost.
Jan 30, 2011 | SimpleTech 250GB USB2.0 7200 RPM External...
I have a 320gb toshiba external hard drive, i've been using it around 3 years without any trouble. A few days ago i lost the cable connecting it to the PC. I bought a few cables but no use. Doesn't...
This is because there is a connection problem between the external drive and the computer. If you have changed cables to no avail, you can open the casing of the external drive where you will find the hard disk inside. Unplug the two cables connected to the harddisk and replug it after a minute. Then try again. If it still does not work, then you need to buy just a usb enclosure and plug the harddisk there to be able to use it again.
Hope this helps. Thank you for using FixYa.
Jan 13, 2011 | Toshiba 120GB USB 2.0 Portable External...
My LG BD530 Blue Ray dvd player /usb will accept my 16GB flash drive to view movies as it has a usb plug in. It will not let me play the same movies from my Western Digital 750GB external hard drive. When...
Could very well be that the external hard drive is drawing more power than what the player can deliver - it is enough for a usb stick but not for the external drive. Now if you use an external drive that is self powered I am sure there will be no issue.
Mar 27, 2017 | Televison & Video
Toshiba a200 flashing power light .. blue blue red red HELPPPPPPP
Remove battery and power
Remove memory in lower socket, the one on the system board and try reboot with just power cord. May have bad socket
Dec 11, 2009 | Toshiba Satellite A200-0ET00X Notebook
Twin drives in an external HDD, and it quit, but I can hear them working. The fan also quit too.
http://atulchitnis.net/files/seagate.pdf http://www.seagate.com/staticfiles/support/downloads/firmware
May 20, 2009 | Seagate Barracuda 7200.10 500 GB SATA Hard...
Acomdata External Hard Drive blue light constantly blinking and not recognized by computer
how do I fix my external hard drive, because one day I turned it on and the drive was fine, the next day when I turned it on, it kept on flashing blue, does that mean that the drive is dead. Please help me with this.
Aug 04, 2008 | Acomdata (HD320UFAPE5-72) (HD320UFAPE572)...
Toshiba 120GB USB 2.0 Portable External 120 GB Hard Drive Logo
414 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
