SOURCE: drivers/netopia/usb/2kxp
You can go to the adapters website and find the drivers for it, then you can burn it on a cd or put on a usb flashdrive.
If you cant find it let me know and I will get them for you.
Thanks
SOURCE: my father in law has a 1980 410d john deere
did they rebuild the hydralic pump and if so they need to do it again and check the valves in it
SOURCE: need to replace battery on 2002 rav 4 where is
Not a labor intensive problem! Stop scaring people pal. Open the hood and the battery is located on te left side of the engine compartment in the back under a overlapping cowling(piece of plastic held down by plastic grommets) Just take a flathead screwdriver or a quarter and turn these plastic screws counter clockwise 1/2 turn...push the middle down and it will pop up. then remove the cowling and loosen the holding mechanism for the battery. A simple pliers will do. All told this is a very easy job that should take no more than 15 minutes.
