Question about Panasonic BL-C131 Network Camera
I have a BL-C131 camera and I need to change the port number. Currently the camera is on port 50000 but this is blocked on my office firewell. how can i change the port and what port should i keep to get away with firewall issue?
Good question. It is easy to change the port if you can actually log on to the camera. (Setup/Network(IPv4)/Connection Mode. Then choose either static or DHCP and change the port number.However, I suspect you are asking this because the office firewall will not allow you to connect to the device. Thats a problem, because this camera is a web server and you need to access it through its IP address to change its address!! I have hit this problem with another web server camera and I was able to use port 8080 in that case. What I did was set up the camera at home on my router and locked in the new port number and then used DHCP to let the work network assign a different IP address. However, many network administrators block whole ranges of ports. I presume you have tried simple Port 80? You may need to ask your network Admin what ports are open. There will always be some. I have encountered a problem recently with Viewnetcam and my IP provider...Verizon... which is blocking a whole range of incoming port numbers because their terms of service are that you cannot operate a web server on your residential network so they block all traffic that is trying to access it.
Posted on Nov 14, 2009
My router name was change, i cant log in. Camera lights keep blinking. How do i solve this?
You will need to log into your router and check your configuration. I am assuming you are using a wifi connection. For more info, please provide the make and model numbers for your modem/router and camera. Goodle is a great source of info as well. Hope this helps.
Sep 08, 2013 | Panasonic BL-C131 Network Camera
How to configure the UPNP in panasonic camera?If we need access from the internet should we register in viewnet.com?
To access your camera from the Internet you will need to configure uPnP (or configure port forwarding manually) and register with some kind of dns service like viewnetcam (or know your home's external IP address assigned by your Internet Service Provider).
1. To configure uPnP on your camera, look in the network settings for an automatic network configuration option - this will trigger the camera to talk to your router using uPnP to set up port forwarding. The default for one camera is to use port 80 for the outside port and something like 192.168.1.253 for the internal network address (internal to your home only). uPnP will try to configure the second and third cameras to external ports 50000 or 50001. My router failed to configure the 3rd camera so I had to manually add a port forwarding option from my router's admin pages. To note, you can configure all port forwarding manually from within the router admin pages. Just list the internal network address to your camera (like 192.168.2.253) and specify a different port for each camera (like 50000 to 50000). You can then access your camera by typing in 192.168.2.253:5000
2. Then, you should register with viewnetcam.com. Adding your cameras on viewnetcam will give you access to them from outside your house without you having to know the IP address to your home network. You will simply type in your viewnetcam url with ":" and the port number (like username.viewnetcam.com:50000).
Note: When trying to access your camera from outside your home (or even pinging your router from outside your home), you need to know the IP address of your home. This is assigned by your Internet Service Provided and can change every time you reboot your modem. Services like viewnetcam keep track of the IP address to your home and update it automatically when it changes (your camera will communicate with Viewnetcam servers occasionally to update the IP address). All you have to remember is one constant URL (the viewnetcam url) and you can get to your cameras!
Aug 14, 2010 | Panasonic BL-C131 Network Camera
How to record transmission of BL-C131
To view over the internet,
1. setup a wifi with internet active.
2. Insert the CD which came with the cam into your laptop which is connected to the wifi as well. Follow instructions. It is simple. If you need help, click here.
3. Make a new DDNS account if you don't have a static public ip (if you don't know what that is, you dont have one).
You are ready to go.
Cheers
TeaCii
Make more money with your website.
Real Guard to watch your cctv for a dollar.
Apr 05, 2010 | Panasonic BL-C131 Network Camera
BL-C131 port forwarding.
So you've configured port forwarding on the router. Do you have any anti-virus applications installed or have your set an exclusion in Windows firewall?
Feb 01, 2010 | Panasonic BL-C131 Network Camera
BL-131C camera - amber light flashes every 2 sec
The good news is you can download the instruction manual from the Panasonic support website - the bad news is - its not free.
Nov 27, 2009 | Panasonic BL-C131 Network Camera
BL-C131 died during firmware upgrade
Seems to be a common problem for these cameras even without doing firmware upgrade. The finnish importer Kaukomarkkinat Oy will not acknowledge it and will only sell new ones to customers complaining about this.
Aug 26, 2009 | Panasonic BL-C131 Network Camera
When i switch to wireless mode, camera stays in;privacy mode
Unfortunately the electronic operating instructions are not available from the support website and have to be purchased from Panasonic.
I think it will be a case of re-setting the camera to factory settings and re-program the webcam again
http://www2.panasonic.com/consumer-electronics/support/Computers-Networking/Network-Cameras/PetCams/model.BL-C131A
Aug 25, 2009 | Panasonic BL-C131 Network Camera
Forgot factory default name and password for my Pansonic BL-C131
There's a reset button. It'll clear the user config. There is no default account.
May 10, 2009 | Panasonic BL-C131 Network Camera
I dont have the installation cd and i dont know how to get the drivers
  1. Goto: http://panasonic.net/pcc/support/netwkcam/download/
  2. Select download site. I clicked on the USA flag.
  3. Scroll down and find your model: BL-C131A
  4. Click on one of the icons to the right of the model number to download either firmware, drivers, or manuals for this camera. In this case, I'd click on the All column to see everything available for your camera
Mar 20, 2009 | Panasonic BL-C131 Network Camera
Panasonic BL-C131 Network Camera Logo
642 people viewed this question
Top Panasonic Computers & Internet Experts
micky dee
Computer Repairing
Computer Repairing
Are you a Panasonic Computer and Internet Expert? Answer questions, earn points and help others
