Question about Roxy Envi MTX Snowboard
My fuse keep on blowin mybe a short on the system
  • 121 Answers
There aren't any fuses on this snowboard!
Posted on Oct 15, 2009
What could be causing the front axillary fuse to keep blowing? Even bigger fuses blow.
fuses blow from over current( dead short) they are rated at lower than what is required so that the wire doesn't burn
If you keep putting in bigger fuses without fixing the dead short, eventually the wire will melt the plastic insulation off and the vehicle will burn
Apr 29, 2016 | 2005 Buick Rendezvous
My nissan altima 2006 2.2 fuel fuse keep blowin any one knows why plese help
Check your fuel pump relay. It"s probably heating up and shorting out the system
Nov 16, 2015 | 2006 Nissan Altima 2.5
Y does da fuse for the ac keep blowin out wen i cut on da ac
You have an electrical short. The fuse is preventing a fire. Keep the fuse out until you can have a mechanic fix it.
Mar 23, 2015 | AC Cars & Trucks
96 protege keeps blowin endine fuse 10amp
Which fuse is that ? Where is it located ?
Apr 11, 2013 | 1996 Mazda Protege
V star 1100 headlight fuse blows repeatedly
Hi, Anonymous you have a dead short which is usually the easiest to find. Using a test light connected to the hot side of the blown fuse holder, start probing the wire leaving the fuse holder about an inch away the test light should illuminate, keep probing towards the ignition switch until the test light no longer illuminates you are now very close to the short. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
http://www.starbikeforums.com/forums/49-v-star/2280-headlight-fuse-keeps-blowing.html
Re Grrr Headlight keeps blowing fuses Road Star Forum Yamaha Road Star
Newbee Star 1100 keeps blowin fuses
http://www.sloneservices.com/SilverBack/Other-Stuff/V-StarShopManual99-07.pdf
Jan 31, 2013 | Yamaha V Star 1100 Classic Motorcycles
92 grand marquis i have 1 wire and fuse that keeps gettin hot and the fuse keeps blowin. the wire has melted down into where it connects to the back of the fuse box. It get very, very hot at the connection...
you have a slow short in system this can cause a fire you need to determine what circuit it is and check for either a defective part also bad electrical connection you will need to possibly replace the wire or insulate it after cause is found
Jun 30, 2012 | 1992 Mercury Grand Marquis
No lights workin
Disconnect the plugs from the light bulbs. if the fuse stops blowing when you turn on the ignition it is a bulb. It may have blown and shorted the element out inside itself. If the fuse still blows it is probably a wiring problem. Also check rear light bulb for same thing as it is on same circuit.
Jan 19, 2010 | 2001 Honda CBR 929 RR Fireblade
MY AMP KEEPS BLOWIN THE FUSE...i CHANGED THE GROUND AND HOT WIRE TO BIGGER GUAGE WIRE AND THE PROBLEM STILL THERE ..........THE AMP IS A ALPINE MRV-307
Hello creelb22,
Fuses usually blow because of a short of too much current.
Test your wiring (including the speaker wires) and make sure they are not shorting or grounding against the vehicle chassis. Also make sure that the speaker voice coils are not shorted.
Hope this helps.
Jul 25, 2009 | Alpine MRP-F300 Car Audio Amplifier
1996 Jeep Grand Cherokee...Blowing ASD fuse
My daughters jeep had the same problem. We fixed by finding the wires that run beside the manifold down under the car. The conduit that have the wires in it was worn away because of resting up against the manifold, causing the wires to short the system out. Once I replaced the conduit and taped the wires it has not shorted out again. By the way, the Jeep dealer couldn't find the problem.
Feb 21, 2009 | 1996 Jeep Grand Cherokee
Fuse problems
output leads shorted by chance?
Jul 05, 2007 | Scosche Industries Scosche High...
Roxy Envi MTX Snowboard Logo
47 people viewed this question
Top Roxy Winter Sports Experts
Arnie Burke
Arnie Burke
Todd Arndt
Todd Arndt
Are you a Roxy Winter Sport Expert? Answer questions, earn points and help others
