Question about Motorola Mobility RAZR V3x Cellular Phone
Cannot send pxts!!
Hi, I cannot send or receive pxts.....it comes up with a little box that says unsecure application. It also says GPRS ACTIVE..
Cant send mms on my samsung galaxy s 2
You need MMS settings along with active GPRS connection. Call your service provider's helpline and ask them to send MMS and GPRS settings to your phone. Once you receive the settings, install them and reset the phone. Hope this helps you!
Sep 05, 2011 | Samsung Cell Phones
How to active gprs globe nokia 5233
For you to have and activate GPRS Globe on your phone, you have to contact globe department because they'll be the one to send the configuration of GPRS, once you receive it you just have to save it on your phone after that you are good to go.
Jul 19, 2011 | Cell Phones
I master reset my k800phone and my internet isn't working
The master reset erase all settings of applications
You have to reset it again
Call your SERVICE PROVIDER
Ask them send you the GPRS settings of your mobile
When you received them(you will receive them as text message) save them and turn your mobile off for
3 minutes,then turn it on .
The internet will be active againe.
May 31, 2011 | Computers & Internet
How can i set my mobile for GPRS FOR NOKIA xPRESS mUSIC MOBILE
To set GPRS on you Nokia 5310 Call Your Cellular Service Provider Customer Care & ask them to Active GPRS on you Cell They will send you setting for your phone & Help you to active GPRS on you phone.
Thanks.
Hope this will help you.
Aug 18, 2010 | Nokia 5310 Cellular Phone
How to active GPRS
Dear friend,
For activating GPRS, you should contact to your network operator and ask them to send the setting for the same. After you receive the settings install them and restart the cell.
Please rate the answer...
Jun 09, 2010 | Sony Ericsson K660i Cellular Phone
LG KS360
Internet settings are usually found under the Phone Settings – Internet Settings.
- Connection mode Connection orientated / permanent / continuous connection
- GPRS APN live.vodafone.com
- Homepage URL http://live.vodafone.com
- GPRS ID username "none required"
- GPRS password "none required"
- Port (if required by device) 8080 (some older handsets may require you to enter 9201)
- PPP authentication type PAP (default)
- Proxy authentication name "none required"
- Proxy authentication password "none required"
- Proxy login type automatic (default)
- Security Off
- WAP gateway IP address 172.030.038.3 (your phone may require 172.030.038.003)
If you phone is a Vodafone NZ supported handset you may be able to have this sent automatically to your phone.
Mobile settings for sending and receiving PXTs (MMS messages)
The PXT settings can usually be found under Message Settings - MMS setting. You also need to send a message before you can receive one.
- APN live.vodafone.com
- MMS server address http://pxt.vodafone.net.nz/pxtsend
- GPRS ID username
- GPRS ID password
- MMS automatic download On (Automatically downloads full MMS)
- PPP automatic download PAP (default)
- Proxy authentication username
- Proxy login type Automatic (default)
- Security Off
Dec 22, 2009 | LG KS20 Smartphone
Can't receive or send pxts with my lg u400 & can't get vdfne live
you won't. as you said is from 3 , so there's firmware branding, which wont let you use Voda live!
Jul 23, 2009 | LG U400 Cellular Phone
Cannot send or retrieve mms messages
Check if you have active GPRS connection , then only you can send/receive MMS. Ask your service provider for GPRS settings.
Dec 01, 2008 | LG Cell Phones
PXT AND MMS SETTINGS FOR NEW ZEALAND VODAFONE NETWORK
http://wireless.vodafone.co.nz/#Wireless_Data_Portal
Jun 16, 2008 | Cell Phones
Motorola Mobility RAZR V3x Cellular Phone Logo
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
