Small bulb replasment in Akai receiver
I don't know any specifics for this bulb which illuminates the front tunning panel. and i don't know how many ampers the fuse must be for this ciruit.
  • fylysenko Jul 30, 2009
    thank you for responding!
    the receiver's model is
    Akai AA-8080.
    i'm going to try as soon as I get the Christmas light.
  • fylysenko Aug 01, 2009
    i installed 3ampers fuse and the Christmas light was working as it should. then i tried some other bulbs i could find. the 3.5 volt bulb and the 6 volt bulb burned down immediatelly. the 12 volt bulb didn't, but the light is to dim. so, i soldered the Christmas light in again in order to watch and to try the sound.
    works fine so far and there's no humming sound at all.
    today i'm going to buy some 9 volt bulb. i think it would fit. thank you a lot for all your information and for your helpfull advises.
3 Suggested Answers
robotek
  • 1512 Answers
SOURCE: rebuilding a '70s marantz receiver
How did you go getting the model number for me. I can help:)
regards
robotek
Posted on Jul 09, 2008
Bat1956
  • 585 Answers
SOURCE: I'm looking for some of
I recently converted my 525 to LED, (yes, custom work) but I know what lamp you need. You can find it at MCM Electronics. www.mcmelectronics.com/product/DISTRIBUTED-BY-MCM-14LH-T1-/25-995
If you find my suggestions to be helpful, please share with us some details so that others may benefit from knowing the whole story. Thank you!
Posted on Dec 29, 2008
Got a 98 k1500 4wd changed the turn indicators on the pass side one was out and the other broke front of truck put the wrong bulbs at first and all lights flashed.. checked the number on the other side put...
There is a small fuse in the cab fuse block ,for the insterment panel that is verry easy to miss if you don,t look close ,it is hidden kind of at the top of the fuse block behind the wires,
Nov 29, 2012 | 1998 Chevrolet K1500
MPH and RPM lights on instrument panel don't always illuminate
If the are not working you need to take the instrument panel out and twist the bulbs out. befor you buy take the ones out that are working and put them in the place where they are not. If they work then you know it is just a bulb or lamp. Now since you have it out replace all of the lamps
Nov 16, 2012 | 1995 Chevrolet Camaro
Driver's side panel won't illuminate
most of the switches and instument panels in my 02 outback have tiny miniture lite bulbs incorporated into every switch including the driver side door window control if you remove the switch panel and turn it upside down youll notice very small round caps with a cross cut in each cap . use a small fat head tip screwdriver to turn the cap ,there you will find the bulb which will be black and burnt out.
May 14, 2012 | 2002 Subaru Outback
My Akai tv is dead ?
My Akai tv is dead I just replased the power supply.and it stell wont power on what can i do?
Feb 07, 2011 | Akai LCT2701TD Television
52" samsung
the problem of your tv is the backlight...a backlight is a set of cold cathode bulb that is inplace at the top and bottom of your monitor..this light illuminate the screen once this light is busted your screen will go black.this lamp is replasable...you can replace them once they are busted...
hope this could help you..good luck!
your rate is important to this help..pls
May 21, 2010 | Samsung 52 in. Flat-Panel LCD HDTV
I have an Akai AT 580 Tuner and the light bulb is blown
Check audiokarma.org first. Then audioasylum.com.
A wonderful wealth of knowledge.
Oct 24, 2009 | Audio Players & Recorders
My Kenmore Elite HE 4t has a bulb illuminated on the front panel. The bulb is the "Control Locked" bulb and the washer does not work! Please help. I have tried unplugging it for awhile.
The reset or cancel button does not control the locking feature. Unplugging the appliance also will not reset it. The following link explains how to correct a control panel lock issue on a Kenmore Elite:
http://www.fixya.com/support/r2469429-kenmore_elite_amp_whirlpool_duet
The control panel lock is actually a designed safety feature that allows you to lock the control panel to keep small children from manipulating the controls. It can be inadvertently set by leaning against the control panel buttons, or following a power outage.
If you have questions, please let me know. I hope this helps you.
Oct 02, 2009 | Washing Machines
AKAI PDP4206EA 42" DARK PICTURES ON COMP 1 AND 2. BLACK AND WHITE ON COMPOSITE. TUNER NOT TUNNING CABLE CHANNELS. ONLY LOOKS GOOD THROUGH VGA. WHAT COULD THE PROBLEM BE?
this is a shot in the dark but as the set been dropped? have you tried tapping around the case to see if this ulters the brightness. you might have a hairlined crack in the main pcb or dry joints.good luck .farr64
Apr 29, 2009 | Akai PDP4206EA Television
Bulb illuminating lcd display panel failed
go to an electronics store. You need a 12 volt bulb that solders onto a small removable circuit board located directly behind the display.
Dec 08, 2007 | JVC RV-B55 Cassette/CD Boombox
Lights out (front panal lsd lights)
I doubt that any fuse blown ot because the unit still works. The LCD panel in these units are very delicate and can easyly break, also there is a small bulb in there that illuminated the backpanl of the LCD. good Luck
Mar 23, 2007 | Kenwood VR-605 Receiver
53 people viewed this question
 Grubhead
Grubhead
