SOURCE: I just bought the ww78 Weight WAtchers scale and
I have loaded a copy at this web site
http://docs.google.com/fileview?id=0B_umxTtnIOPDYmI4ZWZiZjctOWZjOS00ZjQ0LTlkYzEtYzkwZmQ2Y2Y5ZWEx&hl=en
SOURCE: How do I change the setting from KG (currently
There is a switch on the base of the scales that you can change over to set Lbs or Kgs.
SOURCE: Conair #WW78 scale doesn't reweigh
;i have a problem with the conair ww78. It does not reweigh. It shows the same weight each and every day. What is the problem and how can it be fixed?
SOURCE: Weight Watchers bathroom scale, Model WW60X
I got it! Press "set". You should see "start goal" in the bottom right. Press the user # you want to save as and press "set" again. The display will blink then display "0.0". Step on the scale to get your current weight. Once it's read you current weight, press "set". A goal weight will display. Press "User 1" to make your goal weight go up and "User 2" to make it go down. Press "set" when the display shows your goal weight. That's it. Now all you have to do is press your user # and wait for "0.0" to display before stepping on the scale.
SOURCE: HOW DO I RESET A WEIGHT WATCHERS DIGITAL FOOD SCALE?
www.weightwatchers.com/.../1108-usa-revised_booklet...Try this connection . It should give you a good start.
