Question about Hoover Vacuums
Hi! My Hoover Windtunell Pet bagged sweeper keeps saying the bag needs changed (red) when it's just changed.
    Master:
  • 469 Answers
Could be filters a dirty. Clean all filters, then try it
Posted on Jan 01, 2018
Testimonial: "Thank you! The filter is dirty.....Is there more than 1 filter?"
  • Hoover Master
  • 1,570 Answers
You may have a clog in the vacuum somewhere
Testimonial: "I checked the hose and it's not clogged.....Is there another place to check? Thank you!"
  • Thatvacguy.com Jan 07, 2018
    Start where the air is sucked into the vacuum down by the brushroll. There is usually a tube there. Follow the airflow to the bag looking for any restrictions. Most vacuums have at least two filters. If you give me your model number I can check.
dragonsthatk
  • 547 Answers
SOURCE: hoover sweeper model U4263-930 belt change
undo screws on bottom of vac take out brush and belt put belt in then manewver brush in
thank you for useing fixya please rate me
Posted on Feb 12, 2009
  • 430 Answers
SOURCE: Bag was full, changed it, the unit now turns off
Try dialing the control valve to the mid way position. If the unit still shuts down with the bag full light on you have a damaged control valve under the dial on the top of the vac.
This valve failure is common in this model and can only be repaired by someone with original AERUS Electrolux repair parts, generally at an AERUS repair shop.
Posted on Oct 29, 2009
SOURCE: How do you replace the bag on a Hoover Elite 200?
I had the same problem and just figured it out myself. Detach the clamp (attamched to the bag) from the handle. Then slide the bag out from the clamp either left or right. The cloth bag then opnes and you can replace the actual bag inside. Hope this helps.
Posted on Dec 06, 2009
  • 68 Answers
SOURCE: how do i fit the hoover bag
If you remove the top of the vacuum via the clips on the side you will see the empty bucket. Where the hose connects is where you will fit the bag from the inside. On the bag you will see a hole with cardboard around, this will then push over the outlet.
Posted on Jun 10, 2010
SOURCE: hoover windtunnel dirt finder light stays red
I'm not sure about a 3 month old vac, I'd probably go the warranty route. However, for the older vacs thy start getting false positives. The sensor is simply a microphone hooked to a computer chip detecting sounds of dirt entering the bag.
To rig it to start working, you'll need to remove the tool accessory tray and elbow that enters the back of the vac, and attached to the bag. This will reveal the microphone at the elbow, and wire that runs into the bottom area of the vac. When on, a large amount of air comes from the bottom screw and area where the wires enter. My fix was to clean up the microphone contact points a little bit with a screwdriver, and then leave the vac running while putting in dampering in the hole at the bottom, and around the back of the elbow. Cotton balls and electrical tape at the bottom hole, and napkins around the outside of the elbow (wedged between the back of the vac assembly and elbow did the trick). The schematic for the vac is here: http<colon>//www<dot>vacsrus<dot>com/CartGenie/pg_U6485900<dot>asp
Look for micrphone.
Posted on Jun 27, 2010
Bag light wont turn off
Hi there! The vacuum may be still sensing dirt in the cleaner. Try wiping the area down in and around the bag port. Be sure you are replacing the bag with a genuine Hoover Type Q bag. Also, when assembling the bag remember to slide the red bag door lock to the right to lock it on. If the check bag indicator light still comes on there may be an issue with the sensor on the vacuum. We would recommend taking your vacuum in to a Hoover authorized service center for repair. Hope this helps! Service Center Locator
Sep 13, 2014 | Hoover Platinum Collection Upright Vacuum
How to replace a q type bag in a hoover wind tunnel vaccumn
Hi! To replace the type Q bags simply insert bag and slide behind tabs. Then, slide locking tab to right to seal bag to the unit. I have also included a link to the owner's manual where you can see pictures of how to change the bag if needed.
http://hoover.com/file/1550/
Hope this was helpful!
Aug 12, 2014 | Hoover Vacuums
Light keeps blinking
http://www.searspartsdirect.com/partsdirect/user-manuals/uh30010com-hoover-parts-vacuum-manual
WARNING: TO REDUCE RISK OF PERSONAL INJURY - UNPLUG CLEANER BEFORE SERVICING
PROBLEM POSSIBLE REASON POSSIBLE SOLUTION
2. Blown fuse or tripped breaker.
4. Thermal protector activated. (power
light is flashing)
1. Disposable bag is full. ("Check Bag"
indicator illumJnated red)
1. Disposable bag not installed correctly.
3. Brushroll is worn out.
2. Check fuse or breaker in home. Replace fuse/reset breaker.
4. Turn the cleaner off and disconnect it from the electrical
outlet. Then allow cleaner to cool for 30 minutes. If the
thermal protector continues to activate see Needs Service
solution #5.
1. Replace disposable bag - Pg. 9.
1. Review disposable bag removal and replacement - Pg. 9.
3. Replace brushroll - Pg. 10.
Mar 11, 2014 | Hoover UH30010COM Bagged Vacuum
How to install inside on/off switch on hoover windtunnel bagged sweeper
This switch is subject to a recall. Find a local Hoover service center and have it replaced. Completely Free.(YAY!)
Good Luck!
Aug 21, 2012 | Hoover U6437-900 / U6439-900 Windtunnel...
How do you replace the belt on a hoover runabout sweeper.
This link will take you to a site with instructions and illustrations to help you change your belt.
http://www.info-vacuum-cleaner.com/hoover-vacuum-cleaners.php
Hope this helps
Mar 21, 2010 | Hoover U6437-900 / U6439-900 Windtunnel...
My hoover smells of ammonia
I too have a problem with a bad smell coming from my henry hound hoover, but thats probely because i haven't used a hoover bag. I took the cloth filter out,banged all the dust off, then sprayed it with 'RugDoctor' pet stain remover for carpets and upholstery. It still smells a bit, but not half as bad as befor. I have now ordered a reusable,zipable,washable cloth hoover bag especially made for Henry's. It cost £8.80 from ebay with free postage. Hope this helps Nikki.
Oct 30, 2009 | Numatic HHR-200 Henry Hound Bagged...
Sweeper smells stinks whole house up when running
Several questions:
What does the smell seem to be? If rubber, check the belt and brushroll for free rotation. If a musty smell, check the bag, it may need replaced with a new paper bag. If it has an electrical smell, like hot insulation, then the motor needs checked.
Oct 12, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover Light on
ALTHOUGH MOST FILTERS SAY WASHABLE THEY DO STILL NEED TO BE REPLACE AS WASHING THEM SHRINKS THE FILTER AND EVENTUALLY CLOSES THE AIRWAYS. WHICH ALSO IF NOT REPLACE WILL OVER HEAT MOTOR IN MACHINE AND CAUSE MOTOR FAILURE.
Mar 27, 2008 | Vacuums
Hoover elite belt change model number U4245
real simple you have to articulate the belt a little sideways and the belt should slide right between the pulley and the plastic.
Hope this helps.
Feb 06, 2008 | Hoover Elite U5061-900 Bagged Upright...
How to change a Hoover Elite sweeper belt
on the bottom there should be a few screws take them out and a cover should come off the belt is right there. hope this helps
Dec 18, 2007 | Hoover Elite U5061-900 Bagged Upright...
Vacuums Logo
59 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
