Vacuums Logo
pinnacledesignsllc wiernasz Posted on Jan 01, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When should I replace my vacuum roller brush? How long should the bristles be to properly pick up debris? It doesn't seem to pick up on our tile floor any more. (NSS-Pacer-115UE)
Thatvacguy.com
Level 3:
  • Vacuums Master 1,619 Answers
  • Posted on Jan 01, 2018
Thatvacguy.com
Vacuums Master
Level 3:
Answers
1619
Questions
0
Helped
605056
Points
3345
Lay a business card or other straightedge across the bottom plate and see how much of the bristle sticks out past the bottom plate. If the bristles are worn or not sticking out past the bottom plate replace it. Replace the belt if it's over 1 year old.
Ernest
Level 3:
Master:
  • Master 489 Answers
Ernest
Master
Level 3:
Master:
Answers
489
Questions
Helped
183858
Points
2971
If the vacuum is weak, it may not be the brush. Bag and filters need to be clean and empty. No obstruction in the vacuum system. Motor running at full speed. etc etc.
5 Related Answers
Geterdun
  • 184 Answers
  • Posted on Feb 07, 2008
SOURCE: Losing power to stick/floor vacuum
if you have an extension wand, the replacement will cost about $100.00. there is a way to repair both the pwr-cord on the brush assemble and the wand, but it depends on how much damage there is. also you need to check the contacts where the wand connects with the handle,and the prongs on the handle.
let me know if you still need help
Anonymous
  • 152 Answers
  • Posted on Mar 02, 2008
SOURCE: roller brush of vacuum not rotating
u might need 2 change the belt on the attachement there r 2 screws on top take em out after u take off cover there is a plastic cover over the belt take off c if the belt broke the rest is easy
Anonymous
  • 1673 Answers
  • Posted on Jan 11, 2009
SOURCE: how to replace Riccar Roller Brush Bristles.
On the belt end, there is a clip #59 to remove then you can take the brush roll apart, replace the brush strips and put it back together.
Anonymous
  • Posted on Jan 02, 2010
SOURCE: roomba won't pick up debris
I had this problem until I wiped the dirt sensor, which you will find under the rollers.
Anonymous
  • 701 Answers
SOURCE: I have a Eureka Altima vacuum cleaner that doesn't
That means that you need to replace the belt. Here is the belt you need to replace and the manual which has instructions:
Eureka Altima Belts
Owner's Guide
Dyson animal ball, brush stops rotating often. Restart vacuum, brush head runs very short time, shuts off on flat tile floor.
Hello, this is Ava with Think Crucial.
There are a number of reasons why your brush roller has stopped moving. General maintenance to your vacuum is crucial and will help it work at peak performance.
First things first lets focus on the brush roller. Unplug the vacuum and turn it on its side. Look for any noticeable clumps of debris or hair strands that may be caught in the brush roller. Remove these obstructions, probably best to do so with a scissor if it's hair or long pieces of carpet fibers. After removing the debris try manually rotating the brush roller to uncover other hidden clogs. Another thing to take note of is the condition of the bristles on the roll itself. Are they loose or worn down? These are signs that your brush roller is in need of replacing.
While checking out your brush roll you might as well take a look at your vacuums belt. Your belt should be replaced about every three months. After regular usage, the belt will stretch out, lessening the tension on the brush roller. Lesser tension diminishes the brush roller's turn rate and speed. If the belt feels loose then it certainly is affecting your vacuums suction as well as your brush roll not moving at all.
You can purchase a wide variety of high quality Dyson replacement parts for your Dyson vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=dyson
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Have a dyson dc41 brush head wont spin so tried another which i bought this wont spin either the hoover picks up well with the hose what could be the problem be please
Ava B.
Vacuum brush stays on when dyson 44 attachment is attached but not turned on
There are a number of reasons why your brush roller is not working properly. General maintenance to your vacuum is crucial and will help it work at peak performance.
You can purchase a wide variety of high quality Dyson replacement parts for your Dyson Vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
Ava B.
1helpful
How can I get the brush roller to work
HI, it's Jim from Crucial Vacuum!
First things first, unplug your vacuum and turn it over. Check your brush roll for any large amount of debris. This usually comes in the form of carpet fibers, or hair strands wrapped around the brush roll. Try manually rotating the brush roll, this will help unclog any hidden debris.
Take off your vacuums bottom plate, this is usually held on by two screws on opposing sides of the bottom of your vacuum. Remove the brush roll and examine the belt to see if it is applying tension to the brush roll. If the belt is loose this would cause the brush roll to not work properly.
What's the quality of the bristles on the roll? If they look worn down, or loose then it's time to replace the brush roll itself.
You can purchase replacement parts for your vacuum direct from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jim Thompson
Crucial Vacuum Customer Care
Jan 28, 2015 • Vacuums
Why wont brushes rotate
Hi, it's Allie from Crucial Vacuum!
There are several things that may affect the performance of your unit and cause this to happen. The roller brush may stop working properly because of the belts, the roller brush or the filters in your unit.
Belt are recommended to be changed every 3 months, not replacing the belts can cause them to stretch out and the roller brush won't work properly. If the belts are in optimal conditions and do not need to be replaced, this may have been caused by your unit's rollerbrush.
Roller brushes can be cleaned and maintained to avoid frequent replacement. Make sure that there are no hair strands or debris tangled up in the brush roll's bristles, this may cause the roller to not work. Monthly care of your brush roller will help to keep you vacuum working properly.
Last, make sure to check your filters, if the filters have not been washed (if washable) or have not been replaced, it can affect the suction and performance of your unit.
You can purchase direct your replacement belts, brush roll and filters from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
Alejandra (Allie) Sepulveda-Rivera
Aug 19, 2014 • Vacuums
Why doesnt bissell carpet cleaner brush turn properly
You can purchase a wide variety of high quality Bissell replacement parts for your Bissell vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/collections/vendors?q=Bissell
Ava B.
Dyson DC18 All-floor Vacuum bristles won't turn
Ava B.
Dyson dc15 brush bar turns intermittently depending on angle of vacuum
Ava B.
Brush roller won.t turn. It turns for a sec. then shuts off. I have cleaned all clogs. This is a shark navigator. Can I remove bottom of vac to access the roller? The manual doesn,t mention this as a...
There are a number of reasons why your brush roller has stopped moving. General maintenance of your vacuum is crucial and will help it work at peak performance.
First things first let's focus on the brush roller. Unplug the vacuum and turn it on its side. Look for any noticeable clumps of debris or hair strands that may be caught in the brush roller. Remove these obstructions, probably best to do so with a scissor if it's hair or long pieces of carpet fibers. After removing the debris try manually rotating the brush roller to uncover other hidden clogs. Another thing to take note of is the condition of the bristles on the roll itself. Are they lose or worn down? These are signs that your brush roller is in need of replacing.
While checking out your brush roll you might as well take a look at your vacuum's belt. Your belt should be replaced about every three months. After regular usage, the belt will stretch out, lessening the tension on the brush roller. Lesser tension diminishes the brush roller's turn rate and speed. If the belt feels loose then it certainly is affecting your vacuums suction as well as your brush roll not moving at all.
You can purchase a wide variety of high quality Shark replacement parts for your Shark vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/collections/vendors?q=Shark
Ava B.
Hello, I have a Eureka Sanitaire upright vacuum. It is not picking up as well it usual and I notice it no longer has that deep motor sound. What do you suggest?
Does there seem to be good air-flow and suction? If not, look for a blockage somewhere. Otherwise (and more likely because of what you say about the sound), look to the brush roller. Does it rotate when the machine's switched on? If so, maybe the bristles are worn and no longer make contact with the carpet properly. If not, the belt that drives the brush roller is broken and must be replaced. Your Owner Manual will tell you how to do this.  Good luck!
Top Vacuums Experts
AskDyson
AskDyson
Anonymous
Are you a Vacuum Expert? Answer questions, earn points and help others
