Question about HP PSC 1350v All-In-One InkJet Printer
Scan button on printer pulls an error message when pressed
I have a HP psc1350v all in one printer scanner copier. I had to reinstall the software drivers. Now I can get the scan button to work. It pull up an error message telling me to restart the computer or reinstall the software. I have done this many times and still get the same error message. When I click on scanners and other hardware from the control panel it scans just fine. I only get the error if I use the button on the printer or use the radio button in HP Image Zone. What can I do to fix this?
    Scholar:
  • 142 Answers
This may caused because you manually disable HP PCS startup. Check if tray icon is presented. Also find if any settings and reset it to defaults. This Guide may help.
Posted on Jul 30, 2009
    Problem Solver:
  • 7 Answers
You must reinstall the windows and after that install the software drivers and it will work
Receive the message "no scan options" when
browse through your printer installation cd and go to setup folder, then to destinations folder, and then right-click on the destinations.msi (microsoft installer package) and then click on repair. hope that helps
or
have you tried uninstalling and reinstalling the software?
hope that helps. ciao.
Feb 27, 2011 | HP PSC 1610 All-in-One Printer, Scanner,...
HP Laser Jet 3055 is showing scanner error 6 and Comm. error 386, 232, & 388
This is due to a hardware failure, the scanner assembly and the formatter board will need to be replaced.
NVRAM INIT
1. Turn off the all-in-one
2. Press and hold down the * and enter buttons.
3. Continue to hold down the buttons while you turn on the all-in-one. Hold the buttons throughout the entire power-on sequence.
4. When Permanent Storage Init. appears on the control-panel display, release the buttons.
5. Allow the all-in-one to return to Ready before using it. storage init. appears, and then release the buttons.
if this does not work contact hp 1800-334-5144.
Al
Eliteprintersolutions@gmail.com
Jun 14, 2010 | Office Equipment & Supplies
The scanner stopped working. Error message said
completely uninstall the software and the device itself and then reinstall it using the add hardware manager located in the control panel.
Apr 03, 2010 | HP Officejet 5610 All-In-One InkJet...
Scanner function will not work.error message--"no scan options". have reinstalled software plus downloaded software from hp website.
Cobbled together a MS scan option that works with the L7580. Not very seamless but I'm scanning, viewing, saving and emailing OK.
Still wish I could get the darn L7580 to work via the "scan" button!
John Boggess
Jan 05, 2010 | HP Officejet Pro L7580 All-In-One InkJet...
My hp deskjet printer can not copy or scan
Error message?
Just put something on the scanner glass and press the print button in the printer itself, leave the computer alone.
Did it work? if so... there's something wrong with the HP software, re-install.
That machine takes copies without the computer on, so, it should work.
Sep 12, 2009 | HP DeskJet F380 All-In-One Printer
Cannot scan wirelessly from HP Photosmart 4580 wirelessly
I reinstalled the printer software and reconnected the wireless connection and it now works well. I read somewhere that registry cleaner software may remove HP files that are required so this time after the registry cleaner scan, I unchecked any HP entry or printer entry and the scanner is still working, however, only from the pc to the printer, I still cannot scan using the buttons on the printer.
Jun 06, 2009 | HP Photosmart C4580 All-in-One InkJet...
HP Officejet 6310 scans once but then says scanner failure
hi,
that error message is nothing to do with the software part, it actaully hardware issue try the following,
1) unplug the machine and connect it to wall outlet directly,
2) unplug the power cord from the printer and press and hold ON for 1 min and release the ON button and plug it back..
3) Disconnect the power cord from the product.Press and hold # and 6 while reconnecting the power cord to the product, and then release both buttons and if printer turns off, turn it back ON and wait until it cmopletes its instialization and if still persists, it a hardware failure...............
regards,  raj_p5983
Jan 19, 2009 | HP Officejet 6310 All-In-One InkJet...
No scan option
uninstall printer software and then reinstall from cd that came with it if you have it if not you can download from hp solution center.
Dec 29, 2008 | HP Photosmart 2575 All-In-One Printer,...
No Scan Options Error Message
Vista?
Pressing of scan button feature is no longer supported by hp drivers, if installed correctly one scans using scanners and fax
When the scan button is pressed on the printer, nothing happens. The scan button does not work correctly. Solution Scan documents using Windows Fax and Scanning or Paint. Scanning with Windows Fax and Scanning
  1. Click the Start (c00845897.gif ) icon.
  2. Click All Programs .
  3. Click Windows Fax and Scanning .
  4. Click New Scan .
  5. Click File and then click Scan .
Scanning with Paint
  1. Click Windows .
  3. Click Accessories .
  4. Click Paint .
  5. Click File and then click From Scanner or Camera .
  6. Click Scan .
Cause The drivers in the Windows Vista operating system do not support button press functionality on the printer. link to above info from HP
Dec 11, 2007 | HP OfficeJet 6210 All-In-One InkJet...
HP PSC 1350v All-In-One InkJet Printer Logo
103 people viewed this question
Seeker5211
Seeker5211
